Posted: Fri Jun 17, 2011 7:54 am Post subject: ADHARS Location |
This is what I did. The bottom of the shelf is made from ¼” fiberglass fiber core board (out of the scrap bin of a Lancair builder). The hardest part was getting the dimensions of the sides just right so that the shelf was level with the plane axis. Note the copper wire used for the hinge pins instead of steel pins and the ADHARS mounting hardware is non-magnetic stainless steel. The shelf is very ridged. The hinge material makes for easy shelf removal/install.
Carl
Prepping the fuselage for paint.
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Kelly McMullen
Sent: Friday, June 17, 2011 11:18 AM
Subject: ADHARS Location
Vans sells a kit shelf for ADHARS. It clearly is intended by Vans to be placed alongside the elevator bellcrank behind the battery. I know some (Dynon) ADHARS have incorporated the magnetometer in the same unit, so need a magnetically benign location. Given the steel bolts, etc in the bellcrank, probably not so good a place.
IIRC some have built a shelf near the top of fuselage one bulkhead behind the rear of the baggage compartment. I don't remember who's website I saw this on, but would like to copy it. Can someone give me a link to such a fabrication?
Kelly
40866
Not sure from day to day what stage I am at...somewhere between fuselage and FWF. | Quote: | | http://www.matronics.com/Navigator?RV10-List | 0123456789
104.68 KB |
5324 Time(s) |
80.18 KB |
5324 Time(s) |
n223rv(at)wolflakeairport Guest
Posted: Fri Jun 17, 2011 11:16 am Post subject: ADHARS Location |
Kelly McMullen
Posted: Fri Jun 17, 2011 12:41 pm Post subject: ADHARS Location |
Thank you. That is very helpful for ideas.
On Fri, Jun 17, 2011 at 8:50 AM, Carl Froehlich <carl.froehlich(at)verizon.net (carl.froehlich(at)verizon.net)> wrote:
Carl
From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) [mailto:owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)] On Behalf Of Kelly McMullen
Kelly
40866
Not sure from day to day what stage I am at...somewhere between fuselage and FWF.012 34567 89
#avg_ls_inline_popup{position: absolute;z-index: 9999;padding: 0px 0px;margin-left: 0px;margin-top: 0px;overflow: hidden;word-wrap: break-word;color: black;font-size: 10px;text-align: left;line-height: 130%;} [quote][b]
A&P/IA, EAA Tech Counselor
KCHD |
larkrv10(at)yahoo.ca Guest
Posted: Fri Jun 17, 2011 7:44 pm Post subject: ADHARS Location |
Kelly, Ivan Kristensens got a real good set of photos on his web site that I intend to use for my build.
Rick
#40956
Wings on hold during "Assembly Facility Insulating"
--- On Fri, 6/17/11, Kelly McMullen <apilot2(at)gmail.com> wrote:
Received: Friday, June 17, 2011, 3:17 PM
Kelly
40866
#yiv1412773691 #yiv1412773691avg_ls_inline_popup{padding:0px 0px;margin-left:0px;margin-top:0px;overflow:hidden;word-wrap:break-word;color:black;font-size:10px;text-align:left;line-height:130%;} | Quote: |
=nofollow target=_blank>http://www.matronics.com/Navigator?RV10-List
| [quote][b]
Posted: Sat Jun 18, 2011 3:15 am Post subject: ADHARS Location |
pilotdds(at)aol.com Guest
Posted: Sat Jun 18, 2011 5:06 am Post subject: ADHARS Location |
stein sells a shelf for this area ,alittle pricey but well made
