Fwd: Nose Wheel NW511.25
Kelly McMullen
PostPosted: Tue Jun 07, 2011 5:52 am    Post subject: Fwd: Nose Wheel NW511.25 Reply with quote
From the source:
---------- Forwarded message ----------
Date: Tue, Jun 7, 2011 at 6:22 AM
Subject: RE: Nose Wheel NW511.25
To: Kelly McMullen <apilot2(at)gmail.com>
Kelly,
You can refer to the General Wheel and Brake data in our Technical section
at
http://static.veracart.com/matco/item_pdfs/2665/document1.pdf
The AN4 bolts use 80 in-lb.
Thank you,
George R Happ
MATCO mfg
801-335-0582 801-335-0581 (F)
www.matcomfg.com
Technical Support Disclaimer: While we strive to ensure that the
advice/information provided through our support is correct, MATCO mfg does
not accept any responsibility for errors or omissions. Any advice or
information that MATCO mfg gives you via any form of communication is not a
guarantee that it will correct your problem. It is only offered as
assistance to you.
MATCO mfg will not be held responsible for any loss or damage as a result of
our advice or information supplied.
3D-NW511.25.pdf
 Filename:  3D-NW511.25.pdf
 Filesize:  36.55 KB
 Downloaded:  271 Time(s)
Kelly McMullen
A&P/IA, EAA Tech Counselor
KCHD
Kelly McMullen
PostPosted: Tue Jun 07, 2011 7:01 am    Post subject: Fwd: Nose Wheel NW511.25 Reply with quote
BTW, I double checked with Matco in that the drawing had an erroneous 50 in-lb.
They confirmed the 80-in.lbs and have revised their drawing and other references to the correct 80 figure.
On Tue, Jun 7, 2011 at 6:49 AM, Kelly McMullen <apilot2(at)gmail.com (apilot2(at)gmail.com)> wrote:
>From the source:
From: TECH <tech(at)matcomfg.com (tech(at)matcomfg.com)>
To: Kelly McMullen <apilot2(at)gmail.com (apilot2(at)gmail.com)>
Kelly,
at
Thank you,
George R Happ
MATCO mfg
801-335-0582 [url=tel:801-335-0581]801-335-0581[/url] (F)
www.matcomfg.com
assistance to you.
#avg_ls_inline_popup{position: absolute;z-index: 9999;padding: 0px 0px;margin-left: 0px;margin-top: 0px;overflow: hidden;word-wrap: break-word;color: black;font-size: 10px;text-align: left;line-height: 130%;} [quote][b]
Kelly McMullen
KCHD
