Rudder Stops?
dave.saylor.aircrafters(a
PostPosted: Mon May 30, 2011 7:02 pm    Post subject: Rudder Stops? Reply with quote
Does somebody remember who sells the plastic rudder stops? Mine broke.
Dave Saylor
AirCrafters
140 Aviation Way
Watsonville, CA 95076
831-722-9141 Shop
831-750-0284 Cell
Kellym
PostPosted: Mon May 30, 2011 7:22 pm    Post subject: Rudder Stops? Reply with quote
http://www.flyboyaccessories.com/store/index.php?main_page=product_info&products_id=409
Not sure if that is the same I got. One I have will require significant
trimming when I get the tail back on and can determine what gives
correct range of travel.
Dave Saylor
AirCrafters
140 Aviation Way
831-722-9141 Shop
831-750-0284 Cell
Kelly McMullen
KCHD
pilotdds(at)aol.com
PostPosted: Mon May 30, 2011 8:08 pm    Post subject: Rudder Stops? Reply with quote
try Craig Vincent at 209-609-6730.He is at TCY
rleffler
PostPosted: Tue May 31, 2011 1:37 am    Post subject: Rudder Stops? Reply with quote
I got mine from Craig. As is, you will only get about 25 degrees of travel. Trimming is on my to do task list to get the desired range of travel.
bob
Bob Leffler
N410BL - Phase I
http://mykitlog.com/rleffler
PostPosted: Tue May 31, 2011 5:13 am    Post subject: Rudder Stops? Reply with quote
Thanks everyone, Craig has the ones I was thinking of.
Dave Saylor
AirCrafters
140 Aviation Way
831-722-9141 Shop
831-750-0284 Cell
bob
