pbuttles(at)charter.net Guest
Posted: Wed May 25, 2011 4:04 pm Post subject: 914 EGT probe adaptors |
Has any one had this problem ?
I am having a problem with the brass fitting, that attaches the EGT probe to the exhaust pipes. I have had 4 fittings fail. And when they fail, the probe gets loose and I get error readings on the EIS. I have contacted EIS and told them of the problem and they say they have not heard of the problem. I asked them to contact their supplier of the fitting to see if he can make one out of stainless steel. They are researching.
The fitting is 1/8th pipe thread compression on 1 side, and 8mm on the other side (the side that threads into the exhaust pipe). The 8mm side bends and the threads strip out....almost vanish. I think it might be a combination of heat on the brass along with vibration. I believe the exhaust pipe itself is stainless ....isn't it? So it seems to make sense to use a stainless fitting.
Tracy Buttles
