N13472(at)aol.com Guest
Posted: Wed May 18, 2011 8:43 pm Post subject: Air compressor |
Question can you use a Russian cylinder and piston on a Chinese's lower
unit?
Tom Elliott
CJ-6A NX63727
777 Quartz Ave
PMB 7004
Sandy Valley NV
89019
Cell 702-595-2680
gill.g(at)gpimail.com Guest
Posted: Thu May 19, 2011 9:50 am Post subject: Air compressor |
Tom,
No, balance is will be wrong. Also, there is no real advantage, valves &
bore are same size, only exhaust nuts are larger. One advantage is sodium
cooled exhaust valve which can be overcome by using modern high temp alloy
valves.
Gill
Posted: Thu May 19, 2011 10:34 am Post subject: Air compressor |
Gill,
I think Tom's talking about the air compressor components. Not an
engine cylinder.
Dennis
On 5/19/2011 12:46 PM, Gill Gutierrez wrote:
Tom,
No, balance is will be wrong. Also, there is no real advantage, valves&
valves.
Gill
Posted: Thu May 19, 2011 11:28 am Post subject: Air compressor |
You are right
Gill
