Ignition wire routing on IO-540 with lightspeed ignition
Mike Whisky
PostPosted: Mon May 02, 2011 11:26 am    Post subject: Ignition wire routing on IO-540 with lightspeed ignition Reply with quote
Hello builders,
I am trying to find my way back into building and plan to finalize the FWF wiring.
How did other route the ignition wires from the Lightspeed ignition coils to the spark plugs. I have an TMX-540 with single Lightspeed ignition.
It would be great to see some pictures.
Many thanks
Mike
RV-10 builder (flying)
#511
Tim Olson
PostPosted: Mon May 02, 2011 11:54 am    Post subject: Ignition wire routing on IO-540 with lightspeed ignition Reply with quote
I just enlarged the hole in a standard eyeball pass through
and put all 3 cables through that, and RTV'd them in
so they wouldn't vibrate. Then used standard spark plug
baffle pass throughs on the baffling, and RTV'd them there
too since they're smaller cables than plug wires are.
Nothing too fancy.
Tim Olson - RV-10 N104CD
On 5/2/2011 2:26 PM, Michael Wellenzohn wrote:
Hello builders,
Many thanks
Mike
RV-10 builder (interior,avionics, wiring)
#511
http://forums.matronics.com/viewtopic.php?p=338651#338651
n223rv(at)wolflakeairport
PostPosted: Mon May 02, 2011 12:25 pm    Post subject: Ignition wire routing on IO-540 with lightspeed ignition Reply with quote
Here is what I did.
-Mike Kraus
On May 2, 2011, at 3:26 PM, "Michael Wellenzohn" <rv-10(at)wellenzohn.net> wrote:
Hello builders,
Many thanks
Mike
#511
 Filesize:  113.7 KB
 Viewed:  5676 Time(s)
 Filesize:  148.55 KB
 Filesize:  130.69 KB
aerosport1
Michael here is what I did same as Tim on the fire wall and then into the
Baffling I used silicone grommets.
See Pictures
Geoff Combs
President
614-834-5227p
614-834-5230f
www.aerosportmodeling.com
 Filesize:  562.68 KB
 Filesize:  440.4 KB
Geoff Combs
RV-10 QB N829GW
Flying 500 hrs
40033
gnolin(at)sbcglobal.net
PostPosted: Mon May 02, 2011 4:21 pm    Post subject: Ignition wire routing on IO-540 with lightspeed ignition Reply with quote
Mr. Combs,
Where did you get the great looking round covers for the upper engine mounts. I've used a lot of RTV and still mine engine mounts are not sealed very well.
G. Hank Nolin, P.E.
832-640-6284
Alias- RV10 Soon.
--- On Mon, 5/2/11, Geoff Combs <g.combs(at)aerosportmodeling.com> wrote:
From: Geoff Combs <g.combs(at)aerosportmodeling.com>
Subject: RE: Ignition wire routing on IO-540 with lightspeed ignition
Date: Monday, May 2, 2011, 3:14 PM
See Pictures
Geoff Combs
President
614-834-5227p
614-834-5230f
