Baggage door opening...
bjudge(at)gmail.com
PostPosted: Sun May 01, 2011 7:50 pm    Post subject: Baggage door opening... Reply with quote
Greetings Fellow RV-8 drivers,
This one goes in the fessing up for the greater good category.
Today I flew back home from Las Vegas(Henderson) to Gillespie field in San Diego.  I was tooling along at 12,500 fat, dumb and happy as they say when I realized that my baggage door latch was hanging out in the slipstream. It usually isn't visible. I've got an after market carbon fiber door and it has a latch that is somewhat different from the standard door but all the same, I think this could easily happen to a standard RV-8 door.
So I knew well in advance that my baggage door would probably open on landing due to different airflow and sure enough, below about 80 knots the thing opened. Adding throttle would close it but interestingly a slip with right rudder didn't close it.
I landed as uneventfully as possible. There was no damage to the door or plane.
The latch has been very dependable for 600 hrs so I must have left it open.
Lesson for everyone: the plane won't fall out of the sky if the front baggage door comes open.
Lesson for me: Check the baggage latch dummy.
Bill Judge
N84WJ, RV-8 600 hrs.
rv-8.blogspot.com
Site Admin
PostPosted: Sun May 01, 2011 8:21 pm    Post subject: Baggage door opening... Reply with quote
Thanks for the pirep, Bill.
I took off with the keys still in the baggage door lock once. It was latched, but still, the keys banging around make quite a racket. Thankfully, they didn't come out of the lock or I'd of never found them! Smile
Matt
Bill Judge
<http://rv-8.blogspot.com>rv-8.blogspot.com
Matt G Dralle | Matronics | 581 Jeannie Way | Livermore | CA | 94550
tcone1(at)comcast.net
PostPosted: Sun May 01, 2011 8:48 pm    Post subject: Baggage door opening... Reply with quote
You should also be thankful it wasn't on a formation flight...there's a
callsign in there somewhere.
rice737(at)msn.com
PostPosted: Mon May 02, 2011 5:03 am    Post subject: Baggage door opening... Reply with quote
Good to know.  My policy is to never, never take the keys out of the baggage door while it is open or unlock.  My ignition key is on the same ring, so there is know way for me to leave it unlock and start the engine at the same time.      I hope!!!
Date: Sun, 1 May 2011 20:47:22 -0700
Subject: Baggage door opening...
To: rv8-list(at)matronics.com
Bill Judge
rv-8.blogspot.com
List
A>
petercowper(at)att.net
PostPosted: Mon May 02, 2011 10:27 am    Post subject: Baggage door opening... Reply with quote
"I took off with the keys still in the baggage door lock once."
As long as we are giving tips . . . years ago when I was a service station
dealer rep for Union 76, my service station dealers used to put the restroom
keys on items too big to go in customer's pockets. A pink fluffy puffball on
the men's chain tended to always get the key returned.
Pete Cowper
RV8 #81139 (working on cockpit side rails)
