cjhukill(at)cox.net Guest
Posted: Fri Apr 29, 2011 5:31 am Post subject: Rudder gust lock |
I am trying to figure out how to create a rudder gust lock that is on the rudder, not the pedals. I would rather control the movement at the source rather than 20 feet away at the pedals. My RV8 has a 1/8 inch thick angle longeron that runs aft at the same height as the rudder horn, to which you mount the external rudder stops. A couple of U shaped pieces of stainless rod connecting the horn to the stops acts as a ground lock. The problem with the 10 is there is no longeron down by the rudder horn to mount a similar type of bracket. I could make a bracket that mounts through the skin and into the aft bulkhead of the tailcone at the proper height to mate up to the horn, but I would like to hear if anyone else has used a similar approach, and could send me a picture of the results.
Chris Hukill
dlm34077(at)q.com Guest
Posted: Fri Apr 29, 2011 6:15 am Post subject: Rudder gust lock |
two alumium angles (1/8") 24" long); padded with foam (attach foam with RTV) single long bolt thru the center of each angle; paint RED; use wing nut on bolt. This will securely lock rudder when inserted at/around the lower hinge.
If desired make a smaller one for the aileron and/or elevator.
I use the belts for control lock, except rudder, for short periods; otherwise I use individual control locks on each surface.
light weight but very secure.
sean(at)stephensville.com Guest
Here's a link to Robin's rudder gust lock pictures...
http://forums.matronics.com/viewtopic.php?t=58911
-Sean #40303
On 4/29/11 8:51 AM, Robin Marks wrote:
| Quote: | Chris, this is exactly what we did on my -10 and I think it's an
excellent solution. Very simple to install & remove, extremely light &
compact. Just hang a huge Remove Before Flight ribbon off of it and
you are set. Mine clips on to my pitot tube cover when not in use so I
pull both out at the same time.
Sorry I am on the road and do not have any photos to share. I have
posted images in the past so they should be in the archives. Ping me
in 3 days if you want a photo posted.
Robin
On Fri, Apr 29, 2011 at 9:27 AM, Chris Hukill <cjhukill(at)cox.net
Chris Hukill
get="_blank">http://www.matronics.com/Navigator?RV10-List
robin(at)PaintTheWeb.com Guest
Posted: Fri Apr 29, 2011 6:33 am Post subject: Rudder gust lock |
Thanks Sean!
OK, on all my other RV's we built gust locks that "dropped" down instead of the way this one is done with one down leg & one leg going up. This was a test unit that worked well so I moved on to other items on "the list". At some point we may fabricate a new unit that just "drops" into place. There is no benefit to the one up one down design. Regardless it works GREAT in either configuration but the drop into place design has gravity working for you and is a touch easier to install.
Robin
On Fri, Apr 29, 2011 at 10:13 AM, Sean Stephens <sean(at)stephensville.com (sean(at)stephensville.com)> wrote:
[quote] --> RV10-List message posted by: Sean Stephens <sean(at)stephensville.com (sean(at)stephensville.com)>
-Sean #40303
| Quote: | Chris, this is exactly what we did on my -10 and I think it's an excellent solution. Very simple to install & remove, extremely light & compact. Just hang a huge Remove Before Flight ribbon off of it and you are set. Mine clips on to my pitot tube cover when not in use so I pull both out at the same time.
Sorry I am on the road and do not have any photos to share. I have posted images in the past so they should be in the archives. Ping me in 3 days if you want a photo posted.
Robin
On Fri, Apr 29, 2011 at 9:27 AM, Chris Hukill <cjhukill(at)cox.net (cjhukill(at)cox.net) <mailto:cjhukill(at)cox.net (cjhukill(at)cox.net)>> wrote:
Chris Hukill
le, List Admin.
Deems Davis
Posted: Fri Apr 29, 2011 7:50 am Post subject: Rudder gust lock |
I did something similar to Robin, but with the ' drop down' . One word of caution, when I initially installed the gust lock, I installed it only on one side, and I did not put 'retainer pins/clips' to hold in place, During a trip, we experienced some extremely strong winds one evening (40-50 mph gusts) and with the drop down retainer 'crept' upward bit by bit until it allowed some movement in the rudder, and then it progressively crept up until the movement was large enough to pull the attachment bracket off the plane.
The solution for me, was to replicate the gust lock on 'Both' sides of the rudder, and to add retaining clips to the drop in brackets that do not allow for any 'creep'. The retainers are just some 3/16" ss rod bent in a wide "U" and drilled for some retaining clips which are wired together ( so as not to loose them) with a Remove before Flight flag. It's rock solid now and haven't had any subsequent issues.
Attached is an early picture before I added the other side and snugged up the retaining pins.
Deems
[img]cid:part1.02000008.00030309(at)cox.net[/img]
297.47 KB |
5196 Time(s) |
28.4 KB |
5196 Time(s) |
fehdxlbb(at)gmail.com Guest
Posted: Fri Apr 29, 2011 8:26 am Post subject: Rudder gust lock |
Group,
Could the angle be mounted on the inside of the fuselage skin with a slit in the skin for the tab to stick out the side...structurally speaking?
Thanks!
Jim
[url=tel:40603]40603[/url]
-----Original message-----
| Quote: | From: Deems Davis <deemsdavis(at)cox.net>
Sent: Fri, Apr 29, 2011 16:00:18 GMT+00:00
Subject: Re: RV10-List: Rudder gust lock
Deems
297.47 KB |
5192 Time(s) |
Posted: Sat Apr 30, 2011 6:35 pm Post subject: Rudder gust lock |
Thanks guys for the response. Robin's method is just the ticket, however I'm not sure how much of the tailcone structure I need to pick up, so I don't damage anything in winds like we had all day long yesterday, here in Vegas. If I was building the tailcone now, and things were accessible, I would put in some serious reinforcement to carry the load, but now as an afterthought, I think an external bracket could be made that goes forward and bolts to the little stiffener that attaches to the aft bulkhead. The bracket could then go down to line up with the horn, and catch a couple of inches of the aft bulkhead along the way. Or maybe just one that runs up and down the bulkhead a few inches is strong enough? A bracket on both sides with retaining clips is also a good idea.
Chris Hukill
finding projects for the new mill
