Need pickup
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Stratus-List
steerr(at)bellsouth.net
PostPosted: Thu Apr 28, 2011 9:17 am    Post subject: Need pickup Reply with quote
Hello. My Stratus Subaru engine has never started on the primary
ignition, so I'd start it on backup and then switch to primary. That
worked for a while (a few hours), but then it stopped running on the
primary. I replaced the ignition module in the distributor with a TP45,
but that didn't help. I should have checked the pickup coil when I had
the distributor out and on the bench, but didn't. I now discover that
the pickup coil is open, which may have been the problem all along.
Does anybody know where I can get a replacement pickup coil? Frank has
suggested Ram Performance and I'm going to give him a call. Any other
sources, other than a junk yard?
Thanks for your help
Bill
Zenith CH601HD, Stratus Subaru
- The Matronics Stratus-List Email Forum -
http://www.matronics.com/Navigator?Stratus-List
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Stratus-List All times are GMT - 8 Hours
