Posted: Tue Apr 26, 2011 3:41 pm Post subject: [Probable Spam] Nose Gear |
Hi Joe,
You could build your own bearing blocks. I'd recommend you not put in the
vee each side. It only adds to the
resistance in the steering or rudder action in the air. Without the Vee,
the rudder action is smooth and you can get a serious
slip going with little effort. I seldom use the rudder in cruise. The nose
gear steering arms should be bottomed out on the nylon
when in flight. Just my opinion as an HDS owner/builder.
http://www.macsmachine.com/images/gear/full/stratstops.gif
This is another way of keeping engine air and CO2 out of the cabin.
http://www.macsmachine.com/images/controllinkages/full/steer-rod-air-barrier
.gif
You can check out the comparable hardware on my site and if you mess
something up, try scratch-building
the replacement parts yourself.
