Lightening up Z12
rvg8tor
PostPosted: Wed Apr 20, 2011 11:59 am    Post subject: Lightening up Z12 Reply with quote
I am going to ask this question a different way. In Z12 there are 2 alternators, on plays a standby roll and will only produce power when the main alternator goes out or is turned off. Given that only one alternator operates at a time only one ammeter would be needed to monitor the electrical load coming from the alternator providing the power.
This reduces parts count; takes out a shunt and switch required to look at two shunts with on meter and or removes extra ammeter.
So does anyone see any flaws in this logic?
Cheers
Mike "Nemo" Elliott
RV-8A QB (Engine)
www.mykitlog.com/rvg8tor
PostPosted: Wed Apr 20, 2011 4:57 pm    Post subject: Lightening up Z12 Reply with quote
the power.
That will work
rvg8tor
PostPosted: Fri Apr 22, 2011 10:50 am    Post subject: Re: Lightening up Z12 Reply with quote
Since I would like to share one shunt, the shunt would have to come after the ANL for the main alternator and the fusible link for the standby alternator. Is there any issue with the placement of the shunt before or after the wire protection? Attached is a drawing of the proposal. The connection between the shunt and ANL will more than likely be copper bar stock.
You can see the standby B lead fusible link attaches to the shunt along with the B lead from the main alternator.
Also can you think of a failure mode in which the main alternator might be putting out a low amount of power that would still trip the 13V set point of the standby regulator? I am trying to think if there is a failure mode in which both alternators would be putting out power.
Thanks for the help.
the power.
That will work
Electrical System - Power Distribution Shared Shunt.pdf
Z12 Modified
 Filename:  Electrical System - Power Distribution Shared Shunt.pdf
 Filesize:  188.36 KB
 Downloaded:  544 Time(s)
Mike "Nemo" Elliott
RV-8A QB (Engine)
PostPosted: Fri Apr 22, 2011 1:02 pm    Post subject: Lightening up Z12 Reply with quote
At 02:50 PM 4/22/2011, you wrote:
the proposal.
You can see the fuseable link attaches to the shunt along wiht the B
What you show is fine.
rvg8tor
PostPosted: Sat Apr 23, 2011 6:00 am    Post subject: Re: Lightening up Z12 Reply with quote
Thought I would follow up with a picture. I decided to attach the standby alternator B lead on the downstream side of the ANL since it was more substantial than the screw on the shunt. If the screws on the shunt were to work loose there is a tight enough fit that the copper bar should stay in place and provide some conductivity. In the drawing in the second post of this thread, the standby B lead was attached at the shunt.
Ring on terminal on the left is the standby B lead and the main is on the right of the ANL. Yellow fat wire goes through firewall to battery master relay (switched side), main bus feed is off the same side of the battery relay.
Cheers
Mike "Nemo" Elliott
RV-8A QB (Engine)
