cjhukill(at)cox.net Guest
Posted: Tue Apr 19, 2011 6:09 am Post subject: door pins |
<?xml:namespace prefix = o />
While rigging the pins, I had no real friction when the bolts that hold the aluminum guides to the fuselage were loose. When they were tight however, the friction was there. The fix was to put some epoxy/cabosil between the blocks and fuselage, install the bolts , but do not tighten, close the door with the pins engaged (with mold release on them) and let harden.
The results were that the blocks are now aligned with the pins and the pins engage with no friction.
Chris Hukill
