Matt Dralle Site Admin
Joined: 08 Nov 2005 Posts: 27557 Location: Livermore CA USA
Posted: Sun Apr 17, 2011 2:25 pm Post subject: "Worn Out" CT-Q67 Cable Assembly (Warning!) |
Dear Listers,
At 170 hours on my RV-8 now, the Prop control had become increasing more difficult to move starting around 100 hours. The Mixture and Throttle have worked fine and continue to. All three controls use the standard "Green" control cables from Vans, typically a "CT-Qxx" part.
A couple of weeks ago, I disassembled the Governor end of the assembly and made sure that there was no binding or issues on that end. I even lightly lubed up the various moving bits. Yesterday, the Prop control became so difficult to move that I had trouble cycling the prop during run up. I pulled the whole throttle quadrant installation apart today to have a look. I got the cable completely out of the airplane and there are NO outward signs of wear or abuse of *any kind*. But even with the cable completely out of the plane and nothing connected to either end, it is almost impossible to move the cable!! I have a new CT-Q67 cable assembly for my front-mounted governor installation and I'm going to install that next.
But, I wanted to give everyone a heads up on these CT-Q controls. These things are built like they go on a Caterpillar Tractor, so I can't figure out why they would wear out like this.
If one of these controls starts getting stiff and tight, its probably not going to get any better. Replace it before it becomes a safety issue! Not a big deal on the Prop control, but on a throttle or mixture it could be a serious concern.
Best regards,
Matt
RV-8 #82880 N998RV
Status: 170+ Hours Total Time Since May 2 2010 Test Flight!
_________________ Matt Dralle
kcflyrv(at)comcast.net Guest
Posted: Sun Apr 17, 2011 2:55 pm Post subject: "Worn Out" CT-Q67 Cable Assembly (Warning!) |
Matt,
I had a similar experience with my prop cable and talked to my local A&P. He
suggested the following:
Take a short piece of rubber tubing with an I.D. the same as the O.D. of the
prop cable.
Slip it over the disconnected cable (governor end) and put a small hose
clamp on it to make it a snug fit.
Spray some Gunk spray lube in the short piece of rubber tubing. Hold the end
up so a small amount of liquid lube is in the tubing.
Take your compress air supply and spray it into the end of rubber tubing,
holding it tight in your hands; forcing the lube into the prop cable
housing.
Be sure to put a rag around the other end to avoid a big mess.
I did this and my prop cable operates like new now.
Ken Cantrell
RV-6, 1054 hours.
chaskuss(at)yahoo.com Guest
Posted: Mon Apr 18, 2011 3:56 am Post subject: "Worn Out" CT-Q67 Cable Assembly (Warning!) |
Matt,
If you would like a cleaner method to accomplish what Ken suggested below, simply buy a motorcycle cable oiler from your local motorcycle shop or online. See
http://www.jpcycles.com/product/9100065
These work great and are inexpensive.
Charlie Kuss
--- On Sun, 4/17/11, Ken Cantrell <kcflyrv(at)comcast.net> wrote:
[quote] From: Ken Cantrell <kcflyrv(at)comcast.net>
Subject: RE: "Worn Out" CT-Q67 Cable Assembly (Warning!)
To: rv-list(at)matronics.com
Date: Sunday, April 17, 2011, 6:52 PM
"Ken Cantrell" <kcflyrv(at)comcast.net>
Matt,
my local A&P. He
as the O.D. of the
prop cable.
a small hose
rubber tubing,
prop cable
housing.
mess.
Ken Cantrell
RV-6, 1054 hours.
