smokey_bear_40220(at)yaho Guest
Posted: Fri May 12, 2006 8:09 pm Post subject: Thrust, props and parts |
Hey Rick,
Several things:
First, for prop efficiency, what gearing did you
change to from the 2.23 : 1 you had? Did that help?
I know I am running my prop way under the most
efficient rpm, takeoff and cruise. Did you try a 2:1
ratio?
I often takeoff at 5000 RPM or less to save the
engine, but that last 10% rpm makes a real difference
in performance, especially the last 300 rpm. I know
the turbo helps there, but I think that the prop is
just getting into its element at the engine RPM limit.
Wish I had a set of 2:1 gears, if that is what you had
and they worked for you. I'd like to fly the prop in
a more efficient range. I assume the Soob torque can
handle it, though it is mostly more rpm and less
pitch.
Second, put me down for your gas caps, trim assist and
oil cooler. Still considering some of the rest
available. I'll have to finalize soon as I can get
time with the Fox and think about it. I'll try to
keep it to one more shippment, unless you need the
space or $ now.
Third, spinners. Who was it that was flying along and
heard a bang and the engine smoothed out? After
landing found the spinner was gone? Usually we add
parts to make things better, but sometimes "divorce"
helps.
Kurt S. S-5
--- wingsdown <wingsdown(at)comcast.net> wrote:
| Quote: | Exactly. Static thrust only gives that relationship
to other props at that static RPM..............
| Quote: | This list most likely provides more real un-hyped
numbers than any company will ever supply
particular to the aircraft we fly. 22s on a Hummer.
That gives me a great idea. Spinners for aircraft
rims...I think they are 100 percent efficient and
minimal flex under static loads.
Rick
wingsdown(at)comcast.net Guest
Posted: Sat May 13, 2006 4:58 pm Post subject: Thrust, props and parts |
Indented responses
