Posted: Fri May 12, 2006 7:22 pm Post subject: Check Valves |
| Speaking of John, I'll bet he could tell us, as many others could
the reason why the only fuel check valve, working in our pressure
range, in our fuel mixture (ring-a-ding fuel), that I could only
locate ONE check valve and its $ 50.00 EACH!
| Cheap skate Ohio Ralph
What do you want a check valve for? If you have a Mikuni and a Facet,
you already have four, two in each pump.
KISS
_________________ John Hauck
Titus, Alabama |
