JOE HOWSE
Joined: 10 Jan 2006 Posts: 140 Location: DUNCAN BC CANADA
Posted: Sat Apr 16, 2011 5:40 pm Post subject: brake pressure 18T |
What should the max pressure be at the wheel brake line
with full deflection of brake lever
Joe
_________________ J.C. HOWSE |
wlannon(at)persona.ca Guest
Posted: Sat Apr 16, 2011 6:08 pm Post subject: brake pressure 18T |
Joe;
The CJ is 8 - 9 Atm's (118 to 132 psi) but I don't know if the 18T is the same.
Walt
Posted: Sat Apr 16, 2011 7:48 pm Post subject: brake pressure 18T |
The YAK normally is 50 Kgf/cm2
Doc
On Apr 16, 2011, at 9:02 PM, Walter Lannon <wlannon(at)persona.ca (wlannon(at)persona.ca)> wrote:
[quote] Joe;
Walt
Posted: Sat Apr 16, 2011 8:22 pm Post subject: brake pressure 18T |
Sorry hit send to soon. The YAK 52 & 50's main tank ATM is generally 50 Kgf/cm2. The gauge reads it as 5 with a subscript to read X 10 so saying all that.. The gauge reads 5 but actually means 50 ATM or 735 psi that is transmitted through the system. So the question is what is the pressure drop across the brake differential valve? Unfortunately, I can't find that in the manual tonight!
Doc
[quote] Joe;
Walt
Posted: Sun Apr 17, 2011 4:24 am Post subject: brake pressure 18T |
The brake reducing valve reduces the pressure by an 8 to 1 ratio. In
other words, the pressure as measured at the input to the brake bladder
is 1/8 the pressure in the main system.
Dennis
On 4/16/2011 10:43 PM, Roger Kemp M.D. wrote:
[quote] The YAK normally is 50 Kgf/cm2
Doc
<mailto:wlannon(at)persona.ca>> wrote:
> Joe;
> the same.
> Walt
