Dennis Thate
Posted: Tue Apr 12, 2011 12:09 pm Post subject: High Temperature Silicone |
I'm looking for a High Temperature Silicone to use on my Rotax exhaust springs. Can someone recommend a product and supplier.
_________________ Both optimists and pessimists contribute to our society. The optimist invents the airplane and the pessimist the parachute. ~Gil Stern |
Posted: Tue Apr 12, 2011 12:29 pm Post subject: High Temperature Silicone |
Dennis T/Gang:
I use ordinary silicone seal on my exhaust springs and it works great. I
have used permatex copper silicone gasket maker before, but could tell no
difference from what I am using now on the Titan Exhaust System on my
912ULS.
_________________ John Hauck
Titus, Alabama |
Dana
Posted: Tue Apr 12, 2011 2:13 pm Post subject: High Temperature Silicone |
At 04:09 PM 4/12/2011, Dennis Thate wrote:
| Quote: | | I'm looking for a High Temperature Silicone to use on my Rotax exhaust springs. Can someone recommend a product and supplier. |
The orange stuff, made by Loctite or Permatex, available at any auto parts store.
-Dana
You're never too old to learn something stupid.
Posted: Tue Apr 12, 2011 2:23 pm Post subject: High Temperature Silicone |
Dennis T/Gang:
I use ordinary silicone seal on my exhaust springs and it works great. john
h
all
i will second this,,,, as i remember, you can cure regular silicone at
400 deg... and out on the springs there is plenty of cooling down from the
exhaust gas temps.
i safety wire through the springs then also between center points from
spring to spring, and pull the springs slightly out of column. then add
the silicone, this greatly reduces the viberatons.
boyd young mkiii
Posted: Tue Apr 12, 2011 2:36 pm Post subject: High Temperature Silicone |
boyd young mkiii
Boyd Y/Gang:
I used to use safety wire on my two stroke exhaust systems. Was very time
consuming.
On the 912 exhaust I don't use wire, but squeeze the silicone seal from hook
to hook forcing it into the full length of the coil. Each hook and loop
gets a good dose to keep any parts that should break from going through the
prop.
I recently installed SS springs. They are said to last much longer than the
standard spring, but cost nearly $5.00 each.
Titus, Alabama |
zeprep251(at)aol.com Guest
Posted: Tue Apr 12, 2011 3:12 pm Post subject: High Temperature Silicone |
John,
Did you get those springs from JBM?
G.Aman mk3 jabiru 2200a
Posted: Tue Apr 12, 2011 3:51 pm Post subject: High Temperature Silicone |
Gary A/Gang:
Sure did. They are very impressive looking.
Titus, Alabama |
Posted: Tue Apr 12, 2011 4:02 pm Post subject: High Temperature Silicone |
Here's their web site:
http://jbmindustries.com/
Titus, Alabama |
Richard Pike
Posted: Tue Apr 12, 2011 5:22 pm Post subject: Re: High Temperature Silicone |
| Dennis Thate wrote: | I'm looking for a High Temperature Silicone to use on my Rotax exhaust springs. Can someone recommend a product and supplier.
Thanks |
Spend a half a day modifying your exhaust and never worry about springs again. Buy some exhaust pipe clamps and cut off the ends where the bolts go through and weld those pieces to your exhaust. Pick up some 5/16" bolts at Lowes and drill holes in them for cotter pins. Get 4 stiff springs that will fit over the bolts and forget about silicone.
Once every 2 or 3 years buy new bolts because the old ones will chafe and wear grooves in them, but they will still be 1/4" thick. Even grade 3 steel 1/4" in diameter is a lot more reliable than brand new Rotax springs. Been doing this for years now, have almost $15 invested in it. Bullet proof. WooHoo!
Richard Pike
MKIII N420P (420ldPoops)
41.55 KB |
11911 Time(s) |
pj.ladd(at)btinternet.com Guest
Posted: Wed Apr 13, 2011 3:02 am Post subject: High Temperature Silicone |
springs>>
Hi Dennis,
I am intrigued by this. What is the silicone supposed to do?. As far as I am
aware the springs do nothing but hold the two sections of the exhaust
tightly together at the ball joint.
When I was running a 503 i had the springs on, wired of course to stop them
falling through the prop. When they got rusty I painted them with black
Radiator paint or whatever heat resistant paint I had about, or replaced
them. They are so cheap it was hardly worth the bother.
What else do they do that makes it worthwhile taking extra trouble?
Intrigued
Pat
Dana
Posted: Wed Apr 13, 2011 3:25 am Post subject: High Temperature Silicone |
Pat, the silicone damps the vibration. Without it, the springs vibrate all the time, resulting in much shorter life due to metal fatigue and wear at the ends.
-Dana
At 06:59 AM 4/13/2011, Pat Ladd wrote:
| Quote: | --> Kolb-List message posted by: "Pat Ladd" <pj.ladd(at)btinternet.com>
I'm looking for a High Temperature Silicone to use on my Rotax exhaust springs>>
Hi Dennis,
I am intrigued by this. What is the silicone supposed to do?. As far as I am aware the springs do nothing but hold the two sections of the exhaust tightly together at the ball joint.
When I was running a 503 i had the springs on, wired of course to stop them falling through the prop. When they got rusty I painted them with black Radiator paint or whatever heat resistant paint I had about, or replaced them. They are so cheap it was hardly worth the bother.
What else do they do that makes it worthwhile taking extra trouble? |
Smallpox has been largely destroyed - should the virus be given endanged species status?
Posted: Wed Apr 13, 2011 5:34 am Post subject: High Temperature Silicone |
the silicone damps the vibration>>
hi . thanks for the info. I dont know what quantity of of the silicone you have to buy but for the cost of replacing the springs every couple of years I wouldn`t have thought it was worth while.
Cheers
Pat
Roger Lee
Posted: Wed Apr 13, 2011 5:57 am Post subject: Re: High Temperature Silicone |
You can use, and many do, the Permatex Copper or Black silicone. They are rated for 600F-700F which is more than enough. You can buy these at most hardware or automotive stores. There are two ways to apply this and it strictly depends on you.
One is to lay a bead 1/2" wide and a 1/4" tall down each spring and work it into the coils. If you don't apply a big enough bead and it is thin and narrow it will not function properly because it has no body and strength. The second accepted method is to actually fill the spring with the silicone. I prefer the beed. This in fact does help with the pulsation coming from the exhaust system which causes premature spring failure and excessive wear on the springs where it loops connects over the loop. The silicone is not a replacement for safety wiring the springs, but in addition to.
This is in the Rotax manual, there was an SB out on it many years ago and should be a standard practice with trained Rotax mechanics. This subject is usually discussed in the Service or Line maint Rotax class
_________________ Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Cell 520-349-7056 |
Posted: Wed Apr 13, 2011 11:47 am Post subject: High Temperature Silicone |
addition to.
Roger Lee
Roger L/Gang:
Not to be argumentive, but I haven't used safety wire on exhaust springs in
many years. The silicone seal (ordinary/normal) works great and captures
hooks and coils should they break, preventing them from going through the
prop on our pusher Kolbs. Springs are heat treated and very hard. They
will put a ding in a warp drive prop that will have to be repaired.
If the hooks/loops and coils are sealed up with silicone seal, the broken
parts will stay in place and not through your prop.
Titus, Alabama |
