dvonruden(at)generalequip Guest
Posted: Sun Apr 10, 2011 6:03 pm Post subject: Engine Primer |
While trying to start the engine on my CJ today, the primer failed. Worked normal last time before winter hit Minnesota. Would not pump anything. Just gas trying to come out at the top of the primer. The good news is it will have its annual inspection this week. Have the repair manual. Anything specific we should look at as being the cause of the problem?
Dennis
Dennis Von Ruden
President
620 Alexander Drive S.W.
P.O. Box 334
Owatonna, MN 55060
800.533.0524 voice
+5074515510 voice
877.344.4375 fax
+5074515511 fax
dvonruden(at)generalequip.com (dvonruden(at)generalequip.com)
www.generalequip.com
ALL INFORMATION IN THIS EMAIL, AND/OR ATTACHMENT(S) IS CONFIDENTIAL. If you received this e mail in error, and are not the recipient(s) or responsible for receiving this e mail for the recipient, please inform the sender immediately, delete the e mail and any attachment(s) associated.
This email has been scanned by Barracuda - Email Security System.
3.42 KB |
2549 Time(s) |
Posted: Mon Apr 11, 2011 3:46 am Post subject: Engine Primer |
If the fuel is coming out of the primer pump around the knurled nut and
the shaft of the pump, it may very well be the flat O-ring on the end of
the pump. Easy to replace and readily available. Loosen the knurled
nut. Turn the primer handled to the left and extract the pump. You
will see the flat O-ring on the end of the shaft. I'm sure Doug has them
in stock.
Dennis
On 4/10/2011 9:00 PM, Dennis Von Ruden wrote:
| Quote: | While trying to start the engine on my CJ today, the primer failed.
problem?
Dennis
Dennis Von Ruden
President
GNE_Logo
P.O. Box 334
Owatonna, MN 55060
800.533.0524 voice
+5074515510 voice
877.344.4375 fax
+5074515511 fax
dvonruden(at)generalequip.com <mailto:dvonruden(at)generalequip.com>
www.generalequip.com <http://www.generalequip.com/>
