Wiring size ?
peterandbettyharrod(at)bt
PostPosted: Mon Apr 11, 2011 5:30 am    Post subject: Wiring size ? Reply with quote
I am currently building XS Hi-top and looking at Europa Flyer 47 wiring diagram with EXP-Bus module.
Help with sizes of wire required on this diagram would be greatly appreciated.
Regards, Peter
graeme bird
PostPosted: Mon Apr 11, 2011 12:41 pm    Post subject: Re: Wiring size ? Reply with quote
I can help with wire gauges if needed. I dont know the diagram you are referring to.
I would recommend Raychem wire from Farnell or RS components
22 AWG fro signal wiresl
20 AWG for low power circuits (low amps)
18 AWG for higher currents (to 20A)
16 AWG for 30A
I have most of a reel of 18 AWG left from my wiring.
Graeme Bird
kit4 (Wagstaff) TBD
Kit 1 G-UMPY - Mono Classic/XS 912S, Woodcomp G(@)gdbmk.co.uk
david steade
PostPosted: Tue Apr 12, 2011 12:07 am    Post subject: Wiring size ? Reply with quote
Peter
I got these two documents regarding wire capacity off the web.
David Steade
 Filesize:  366.23 KB
 Viewed:  3011 Time(s)
 Filesize:  555.95 KB
David Steade
