sstearns2(at)yahoo.com Guest
Posted: Fri Apr 08, 2011 10:01 am Post subject: nose drop question... |
Hello all,
I'm trying to fully understand the nosedrop problem. I had assumed the problem was nose drop after touchdown, but it sounds like it's a nose drop in the flare but prior to touchdown. Is that right?
Scott
| | - The Matronics KIS-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
lgdavid(at)roadrunner.com Guest
Posted: Fri Apr 08, 2011 11:02 am Post subject: nose drop question... |
Hi Scott, et al,
I suspect those who experienced this problem are no longer active on the List. Rich might remember.
Larry
On 4/8/2011 10:59 AM, Scott Stearns wrote: [quote] Hello all,
Scott
randy.ott(at)gmail.com Guest
Posted: Fri Apr 08, 2011 1:37 pm Post subject: nose drop question... |
Vortex generators on the elevator seem to fix mine.
Randy
96BT
On Fri, Apr 8, 2011 at 11:57 AM, Larry David <lgdavid(at)roadrunner.com (lgdavid(at)roadrunner.com)> wrote:
[quote] Hi Scott, et al,
Larry
On 4/8/2011 10:59 AM, Scott Stearns wrote: | Quote: | Hello all,
Scott
et="_blank">http://www.matronics.com/Navigator?KIS-List
tp://forums.matronics.com
bakerocb
Posted: Fri Apr 08, 2011 1:52 pm Post subject: nose drop question... |
4/8/2011
Hello Scott, You wrote: "I'm trying to fully understand the nosedrop problem."
There are two nose drop problems in landing the KIS TR-1. They are:
A) Difficulty in holding the nose wheel off the landing surface after a normal rate of descent main landing gear touchdown. This is not, in my opinion, a safety problem, but rather one of annoyance to those pilots who desire to use aerodynamic braking from the instant of main landing gear touchdown until they want to lower the nose wheel or until the nose wheel can no longer be held off the landing surface as a result of slowing speed during landing roll out.
B) A sudden pitch down of the nose during the landing flare while still airborne that catches the pilot by surprise and can cause a very harsh touchdown. If the nose wheel does not contact the landing surface at the same time as the main landing gear in this harsh initial contact it will slam down a fraction of a second later as a result of nose down rotation about the main landing gear contact point.
History bears out that this harsh touchdown can indeed result in aircraft damage and, potentially, injury to occupants depending upon the distance fallen.
I think that it is important to understand the difference between A and B as the discussion proceeds.
'OC' Baker Says: "The best investment we can make is the time and effort to gather and understand knowledge."
galinhdz(at)gmail.com Guest
Posted: Fri Apr 08, 2011 5:27 pm Post subject: nose drop question... |
Same with the TR-4. Much better elevator authority and landings at low
air speeds with my VG's.
On Friday, April 8, 2011, Randy Ott <randy.ott(at)gmail.com> wrote:
| Quote: | Vortex generators on the elevator seem to fix mine.
Randy
96BT
On Fri, Apr 8, 2011 at 11:57 AM, Larry David <lgdavid(at)roadrunner.com> wrote:
Hi Scott, et al,
Larry
Hello all,
Scott
BlueSkyFlier
Posted: Sat Apr 09, 2011 3:16 am Post subject: Re: nose drop question... |
Galin & Randy,
Would you mind sharing pictures of your vortex generators on the elevator?
It would be useful to know in which position the VGs have been found to be effective.
Alfred
_________________ _________________________________________ |
bakerocb
Posted: Sat Apr 09, 2011 5:35 am Post subject: nose drop question... |
4/9/2011
Hello Galin, You wrote: "I placed mine 4" in front of the hinge line on the bottom of the elevator."
It would appear from both your photograph and your words "..front of the hinge line.." that your vortex generators are actually placed on the bottom surface of the horizontal stabilizer and not on the bottom surface of the elevator.
BlueSkyFlier
Posted: Sat Apr 09, 2011 10:32 am Post subject: Re: nose drop question... |
Ok, I did a search for "vortex generator" on the KIS list and it brought up a whole host of past messages on this same subject which made good and informative reading.
Alfred
Robert Reed
Joined: 22 Oct 2009 Posts: 331 Location: Dallas/Ft.Worth
Posted: Sat Apr 09, 2011 11:09 am Post subject: nose drop question... |
Ah come on OC, as my old grandmother used to say, take him for what he means, not what he said. <BG>
On Apr 9, 2011, at 8:33 AM, <bakerocb(at)cox.net (bakerocb(at)cox.net)> wrote:
[quote] 4/9/2011
