Looking to create a scuba to schrader hose
thomasg(at)infosysnetwork
PostPosted: Tue Apr 05, 2011 6:50 pm    Post subject: Looking to create a scuba to schrader hose Reply with quote
I am looking to create a hose to go from a scuba tank to the Schrader valve on my CJ.
Looking at gooseneck couplings, it seems that the high pressure ones don't have a center pin to depress the core valve. I am guessing that the air pressure itself depresses the valve?
Aircraft Spruce has one http://www.aircraftspruce.com/catalog/lgpages/gooseneck.php
For the other end, I am looking for the Scuba Yoke Assembly. I have some old regulators that I may be able to take apart for this, but does anyone have any specifics on adapters that I may need? It looks like the Yoke diameter is definitely larger than the gooseneck diameter.
Tommy
viperdoc(at)mindspring.co
PostPosted: Tue Apr 05, 2011 7:11 pm    Post subject: Looking to create a scuba to schrader hose Reply with quote
Tom,
You need the stage one from a scuba regulator. That will fit the yolk on the scuba tank. I have forgotten the size of the fittings you need for the high pressure line from the stage 1 to the screwed valve.
Doc
On Apr 5, 2011, at 9:47 PM, Thomas Geoghegan <thomasg(at)infosysnetworks.com> wrote:
Tommy
dsavarese0812(at)bellsout
PostPosted: Wed Apr 06, 2011 3:20 am    Post subject: Looking to create a scuba to schrader hose Reply with quote
This is the end for the Schrader valve.
http://www.aircraft-tool.com/shop/detail.aspx?PRODUCT_ID=SK2043C
Actually you should remove the valve core because it is very likely it
is not a high pressure check valve to begin with. Plus you don't need
it since the system is already protected with check valves.
Dennis
Tommy
PostPosted: Wed Apr 06, 2011 3:29 am    Post subject: Looking to create a scuba to schrader hose Reply with quote
I meant to say, "it is not a high pressure valve core".
Dennis
On 4/6/2011 6:15 AM, A. Dennis Savarese wrote:
<dsavarese0812(at)bellsouth.net>
is not a high pressure check valve to begin with. Plus you don't need it
Dennis
> Geoghegan<thomasg(at)infosysnetworks.com>
> valve on my CJ.
> Thanks,
> Tommy
PostPosted: Wed Apr 06, 2011 7:22 am    Post subject: Looking to create a scuba to schrader hose Reply with quote
Doc,
Do I really need the stage 1 of the regulator or just a connection to the scuba yoke? I would think that I would be using the high pressure off the stage 1, for the low pressure is only about 130 psi. So if I'm using the high pressure port, then I should be able to remove the stage 1 and connect the hose directly to the tank.
While I was typing this, I just got an email from Precision Avionics. They have this for $50. Looks like I can attach a hose to the end and then to a Schrader gooseneck. Thoughts?
 Filesize:  70.24 KB
 Viewed:  10933 Time(s)
William Halverson
PostPosted: Wed Apr 06, 2011 7:34 am    Post subject: Looking to create a scuba to schrader hose Reply with quote
All I use on my YAK-55 is the scuba yoke.
When you fill the bottle the pressure relief valve will prevent any damage due to over pressure.
With practice you can fill it up and not waste much scuba air at all.
William Halverson
YAK-55
N355YK
gill.g(at)gpimail.com
PostPosted: Wed Apr 06, 2011 8:19 am    Post subject: Looking to create a scuba to schrader hose Reply with quote
You should not have a valve core in your schrader fitting, the check valve
on the firewall serves the necessary check function. I went to a scuba shop
and picked up a used yoke and had an 1/8th inch national pipe thread drilled
and tapped. In all my cost for yoke, custom high pressure hose (4500 psi)
from a hydraulic shop and Schrader adapter was under $50.
Gill
PostPosted: Wed Apr 06, 2011 9:11 am    Post subject: Looking to create a scuba to schrader hose Reply with quote
Looking at it, you are correct, there is no valve core.
thanks
