brake linings
dlm34077(at)q.com
PostPosted: Tue Mar 29, 2011 4:19 pm    Post subject: brake linings Reply with quote
Anyone found a good source for Rapco RA66-112 (Cleveland equivalent is 066-11200)? Spruce does not carry and Vans wants $60 + for a set of Clevelands.
Kelly McMullen
PostPosted: Tue Mar 29, 2011 5:34 pm    Post subject: brake linings Reply with quote
http://www.trade-a-plane.com/detail/1258510.html
Aircraft Supply in PA...$18.50
It is also used on the Beech Skipper
Clevelands.
Kelly McMullen
A&P/IA, EAA Tech Counselor
KCHD
Tim Olson
PostPosted: Tue Mar 29, 2011 6:22 pm    Post subject: brake linings Reply with quote
Spruce has carried them in the past. I just found them online
I think from Skygeek.com too for $18.99 each.
There are no Rapco's available yet. Rapco is in the process
of making them and getting them out but they said 2-3 more
months. I started talking to them back in 2006 or 2007 about
making them for the RV-10 and they're finally about to get
them in production. They told me last week that when they're
available, Desser Tire will have them first, but that it
will at least be 2-3 months yet.
For now, your only choice is Cleveland. Oh, and I saw that
Desser will likely be selling them for $16.99, so sadly,
it's not going to be a huge savings...only $8 for a complete
brake job.
Tim
Clevelands.
partner14
PostPosted: Tue Mar 29, 2011 6:39 pm    Post subject: brake linings Reply with quote
Just talked to the Rapco guys here at Sun and Fun, and they are going to go ahead and release them to Desser for sale... prior to attaining the FAA blessing.... probably 2 to 3 weeks, and at a much better price.
Don McDonald
Here at Lakeland in my RV41.
Sent: Tue, March 29, 2011 6:31:55 PM
Subject: brake linings
Don A. McDonald
40636
rv10flyer(at)verizon.net
PostPosted: Tue Mar 29, 2011 7:30 pm    Post subject: brake linings Reply with quote
desser carries them
http://www.vansaircrafttires.com/categories/RV%252d10/Brakes/
Sent: Tuesday, March 29, 2011 4:31 PM
Tim Olson
PostPosted: Tue Mar 29, 2011 8:23 pm    Post subject: brake linings Reply with quote
I hope the "much better" that Desser is advertising them for
ends up changing to a real actual "much" better. The
Clevelands I saw for $18.99. Desser wanted $16.99 for
the Rapcos. I think many other types of pads are under
$10 for Rapco's. If they can't do better than cutting
$2 off, I can't consider it "much". I'd love to
see them for $10 each.
Tim
Don McDonald
*To:* rv10-list(at)matronics.com
*Sent:* Tue, March 29, 2011 6:31:55 PM
*Subject:* brake linings
Clevelands.
rj_todd(at)yahoo.co.uk
PostPosted: Wed Mar 30, 2011 12:04 am    Post subject: brake linings Reply with quote
Vans quotes $66 for a set of four plus rivets - that's $16.50 each,
Rodger
--- On Wed, 30/3/11, Tim Olson <Tim(at)myrv10.com> wrote:
Subject: Re: brake linings
Date: Wednesday, 30 March, 2011, 5:39
for
for
cutting
Tim
they are going to
to attaining the
better price.
> Don McDonald
> *From:* DLM <dlm34077(at)q.com>
for a set of
> Clevelands.
Forum -
FAQ,
   - MATRONICS WEB FORUMS -
List Contribution Web Site -
              -Matt
Dralle, List Admin.
Tim Olson
PostPosted: Wed Mar 30, 2011 4:33 am    Post subject: brake linings Reply with quote
Today, that's a good deal. I should warn you RV-10 guys....brakes may not last you long until you get it in your head not to ride them. My first set lasted 150 hours or so, as a guess....I hit 170 and the rivets were hitting the rotors. My next set went longer. But, if you fly 100 hrs/year, you'll want to inspect every spring and fall and you will likely replace them every other year. I'm sure many people will do better than me, too, but either way, always keep a spare set on hand....you will find that it is nice not to scramble to order them when you suddenly need them, because they're not convenient to change with wheel fairings. That's why I have no air fill ports on the fairings....it provides the necessary
Motivation to pop off the fairing occasionally and replace or inspect the brakes.
Tim
Rodger
> From: Tim Olson <Tim(at)myrv10.com>
> To: rv10-list(at)matronics.com
> for
> for
> cutting
> Tim
> they are going to
> to attaining the
> better price.
>> Don McDonald
> for a set of
>> Clevelands.
> Forum -
> FAQ,
> -Matt
> Dralle, List Admin.
dmaib@me.com
PostPosted: Wed Mar 30, 2011 5:44 am    Post subject: Re: brake linings Reply with quote
I've had the opportunity to fly RV-10's with and without rudder pedal extensions. I believe the rudder pedal extensions make staying off the brakes a whole lot easier. The angle of the pedals make it pretty hard to do without the extensions. This seems to be more true for taller pilots with bigger feet. I gave some transition training to a gentleman who purchased a flying RV-10 a couple of weeks ago. He was a big guy and had a real problem keeping his feet off the brakes. I am not sure, but suspect the rudder pedals were in the aft position on his airplane and that probably aggravated the problem. I installed the rudder pedal extensions from http://www.mlblueskunk.com/Rudder_pedal_Extensions.html and they are working great for me. There are other vendors selling similar extensions as well. I planned to change brake linings at my last condition inspection in December, but they were only about half worn at 300+ hours. I am going to take another look at them this week. Now that I am using my airplane for a little bit of Transition Training, I am sure the wear will accelerate.
 Filesize:  709.75 KB
 Viewed:  14059 Time(s)
 Filesize:  708.48 KB
 Filesize:  768.68 KB
David Maib
RV-10 #40559
New Smyrna Beach, FL
dlm34077(at)q.com
PostPosted: Wed Mar 30, 2011 6:33 am    Post subject: brake linings Reply with quote
I agree that a lot of pilots ride the brakes. While checking out another
pilot in my 10, I did not notice he was on the brakes until we touched and
then hopped on the nose wheel. I now fly with my feet on the weldments and
deliberately move feet to centers to apply brakes. I will be suggesting that
others who fly my aircraft avoid using the brakes on landing.
PostPosted: Wed Mar 30, 2011 7:43 am    Post subject: brake linings Reply with quote
My suggestion is those at SnF talk to Ken at the Desser booth, he is the one
driving all the parts for the -10, the other folks there wont know. Ask him
about the pads and other -10 parts in the works. Tell him you want better
pricing on the pads. He has been more than willing to make it work for the
RV's in general and I have found he listens to suggestions.
Pascal
Sent: Tuesday, March 29, 2011 8:39 PM
Tim
> Don McDonald
> Clevelands.
Tim Olson
PostPosted: Wed Mar 30, 2011 8:23 am    Post subject: brake linings Reply with quote
I think those extensions probably aren't a bad idea if for
nothing else than as a training crutch to help prevent
someone from riding the brakes. You're right that especially
for tall people, and especially with the pedals in the aft
position, you can picture your foot that is always bent
back more than 90 degrees, just to make your foot sole
match the angle of the pedal. So having a little extra
bump out on the bottom bar is probably a good thing to help
keep your toes from hitting while your feet first touch.
If you notice on my rudder pedal blocks I made for andrea,
I added a piece of trim wood to put the bottoms out an
extra 1/4" or more too, just for that purpose.
I may actually give these pedal extensions a try. It's a bit
steep in price but they look to be done nicely. But at this
point I'm down to only a few upgrades/mods left that
I could possibly do, so maybe I should try them out. Smile
The biggest downside for me is that they'd interfere with
my gust lock unless I modified that too...and I really
like my gust lock. But, oh well.
Thanks for reminding us of these David....I do think they're
a good idea.
Tim Olson - RV-10 N104CD
that! I am using my airplane for a little bit of Transition Training,
-------- David Maib RV-10 #40559
http://forums.matronics.com/viewtopic.php?p=335495#335495
http://forums.matronics.com//files/img_1640_970.jpg
http://forums.matronics.com//files/img_1637_189.jpg
http://forums.matronics.com//files/img_1546_342.jpg
robin(at)PaintTheWeb.com
PostPosted: Wed Mar 30, 2011 9:06 am    Post subject: brake linings Reply with quote
HEALS ON THE FLOOR! That was what was drilled into me from early on in my flight training. It is nearly impossible to actuate the breaks with your heals touching the floor boards. For me I do that & keep the balls of my feet on the corners of the peddle assemblies until I need to apply the brakes. My first set of brakes lasts 195 hours including about 40 hours flying off of grass strips which can be substantially harder on the pads. Those pads still had 20+% left but since we were changing tires & tubes we changed the shoes as well. I hope to get 300 hours out of my second set flying exclusively on pavement.
I am sure the rudder pedal extensions will help prevent brake riding. I am however reticent to add more weight & costs to my flying -10, especially for something I can do without if I use basic piloting skills.
Robin
From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) [mailto:owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)] On Behalf Of DLM
Sent: Wednesday, March 30, 2011 6:51 AM
--> RV10-List message posted by: "DLM" <dlm34077(at)q.com (dlm34077(at)q.com)>
Tim Olson
PostPosted: Wed Mar 30, 2011 9:33 am    Post subject: brake linings Reply with quote
Cool, a man on the inside! That's what we need.
one driving all the parts for the -10, the other folks there wont know.
Ask him about the pads and other -10 parts in the works. Tell him you
want better pricing on the pads. He has been more than willing to make
it work for the RV's in general and I have found he listens to suggestions.
Pascal
> Tim
>> Don McDonald
>> Clevelands.
