Rubber Channel Molding
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Allegro-List
hgmckay
PostPosted: Wed Mar 30, 2011 9:01 am    Post subject: Rubber Channel Molding Reply with quote
Has anyone had to replace the small rubber molding that goes around the top of the vertical stabilizer where the horizontal stabilizer comes in contact? This same molding also goes around the ā€œUā€ cutout on the wheel pants. If so, where did you get it?
Hugh G. McKay III, P.E.
Senior Consultant
Worldwide Engineering Inc.
4090 North NC Hwy. 16
Denver, NC 28037
Ph. 704-661-8271
Fax 704-483-5466
email hgmckay(at)bellsouth.net
http://www.wwegeo.com
- The Matronics Allegro-List Email Forum -
http://www.matronics.com/Navigator?Allegro-List
Hugh.vcf
 Filename:  Hugh.vcf
 Filesize:  364 Bytes
 Downloaded:  876 Time(s)
Brian Carpenter
PostPosted: Wed Mar 30, 2011 6:53 pm    Post subject: Rubber Channel Molding Reply with quote
Hugh,
Seems that I talked to Doug about that. He said to go to an automotive parts store and get some molding like what is used on car doors.. My is cracked but have not replaced it yet..
Good luck,
Brian
n3081x
928-205-8300
--- On Wed, 3/30/11, Hugh McKay <hgmckay(at)bellsouth.net> wrote:
Subject: Rubber Channel Molding
To: allegro-list(at)matronics.com
Date: Wednesday, March 30, 2011, 9:50 AM
Senior Consultant
Denver, NC 28037
Ph. 704-661-8271
Fax 704-483-5466
BRIAN N3081X
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Allegro-List All times are GMT - 8 Hours
