Transient_voltage_suppression_diode failure
bakerocb
PostPosted: Wed Mar 16, 2011 2:49 pm    Post subject: Transient_voltage_suppression_diode failure Reply with quote
3/16/2011
Hello Fellow Aeroelectric Listers, You may be interested in the attachment
and the below information:
http://en.wikipedia.org/wiki/Transient_voltage_suppression_diode
'OC' Baker Says: "The best investment we can make is the time and effort to
gather and understand knowledge."
ce-08-12r1.pdf
 Filename:  ce-08-12r1.pdf
 Filesize:  32.95 KB
 Downloaded:  371 Time(s)
Eric M. Jones
PostPosted: Fri Mar 18, 2011 11:42 am    Post subject: Re: Transient_voltage_suppression_diode failure Reply with quote
Looks just like that Perihelion Design thing they call a SnapJack.
Eric M. Jones
www.PerihelionDesign.com
113 Brentwood Drive
Southbridge, MA 01550
(508) 764-2072
emjones(at)charter.net
longg(at)pjm.com
PostPosted: Fri Mar 18, 2011 1:01 pm    Post subject: Transient_voltage_suppression_diode failure Reply with quote
Eric, you're on a roll today.
Q - the whackjack thing you sell: does that have a mounting hole or does
it screw onto a 1/4 bolt or what? I'm pausing about where that thing
would install up front. Also, how large a wire do you run from the
whackjack to the B Terminal?
With the Nuclear Plant problem in Japan (sort of like an alternator that
won't turn off), I'm thinking this is a good investment.
Glenn E. Long
Eric M. Jones
PostPosted: Fri Mar 18, 2011 2:47 pm    Post subject: Re: Transient_voltage_suppression_diode failure Reply with quote
Glenn,
It has a 1/4" Stud. But it isn't designed to save everything if your alternator runs away. The wire should be 22g.
Headline: JAP SCIENTISTS CALL MOTHRA AND GODZILLA TO STOMP ATOMIC FIRES
Eric M. Jones
113 Brentwood Drive
(508) 764-2072
