Posted: Sat Mar 05, 2011 3:09 pm Post subject: seat rails and AN509 8R10 screws |
I can't find any place in the parts where they sent me enough of these screws to attach the seat rails. Did anyone else have this shortage or am I missing something?
And I thought that as the part count went down it would get easier to find needed items.
John
partner14
Joined: 12 Jan 2008 Posts: 540 Location: Granbury Texas
Posted: Sat Mar 05, 2011 4:14 pm Post subject: seat rails and AN509 8R10 screws |
You probably just need to do what we've all done.... put an order together with Spruce, or another hardware supplier, of practically every nut, bolt, screw. nut plate, washer, cotter pin, tubing, etc, so that you just MIGHT have what you need, when you need it. Obviously it'll take a little time to iron out the quantities, but it's worth it.
Couple of hundred bucks ought to do it.
Don McDonald
To: RV 10 group <rv10-list(at)matronics.com>
Sent: Sat, March 5, 2011 5:06:30 PM
Subject: seat rails and AN509 8R10 screws
John
| Quote: | [b]
or?RV10-List" rel=nofollow target=_blank>http://www.matronics.com/Navigtronics.com/" rel=nofollow target=_blank>http://forums.matronics.com |
_________________ Don A. McDonald
40636 |
davidsoutpost(at)comcast. Guest
Posted: Sat Mar 05, 2011 4:40 pm Post subject: seat rails and AN509 8R10 screws |
David Clifford
RV-10 Builder
Howell, MI
I just dug mine out last week. They were in a brown paper bag with all the other bags of hardware that came in the finish kit. There were over 100 of them IIRC. I temporarily installed my seat rails and stripped two of the Phillips heads when I removed them. Had to drill them out of the nutplates. I will use Torx drive screws next time they get installed.
[b]From:[/b] John Gonzalez <indigoonlatigo(at)msn.com>
John
[/b][b]
Lew Gallagher
Joined: 04 Jan 2008 Posts: 402 Location: Greenville , SC
Posted: Sat Mar 05, 2011 4:42 pm Post subject: Re: seat rails and AN509 8R10 screws |
Hey John,
It's been too long for me to remember exactly, but it seems there IS something about the seat rail screws -- some countersunk, some not? not all the holes in the rails are used? Others that are at that stage or have the plans handy, chime in here. Or lay the seat rails out where they fit and check it out.
Later, - Lew
_________________ non-pilot
crazy about building
NOW OFICIALLY BUILDER #40549
Fly off completed ! |
rv10flyer(at)verizon.net Guest
Posted: Sat Mar 05, 2011 5:52 pm Post subject: seat rails and AN509 8R10 screws |
For what it's worth, I have no idea what I got and what Vans gave me, but I
am one of those that ordered all sorts of items from Spruce so I always have
extra's on hand for those times I need a hot swap for a stripped hardware
item or more commonly, misplaced items.
Pascal
Tim Olson
Posted: Sat Mar 05, 2011 6:10 pm Post subject: seat rails and AN509 8R10 screws |
Yes, you should just order 100 packs of many standard size screws,
all the common ones, and all of the ones you need for
commonly removed items. I ordered maybe 10 lengths of
each size screw, 4-40, 6's, 8's, 10's....so that's a lot
of screws but in 100 packs its not a big deal. You'll want
them long term for maintenance anyway.
Tim Olson - RV-10 N104CD
but I am one of those that ordered all sorts of items from Spruce so I
always have extra's on hand for those times I need a hot swap for a
stripped hardware item or more commonly, misplaced items.
Pascal
Posted: Sat Mar 05, 2011 10:30 pm Post subject: seat rails and AN509 8R10 screws |
Yes guys I have been doing this orderring of all different bolts and screw...but, and as is the case these are 8R10s, I have 8R7s.
My finishing kit did not contain these screws.
I'll place another order and wait a few days. It not like I am doing anything you all haven't already done.
What I find difficult to do it order through Spruce because they use a different system of numbering. Anyone have a conversion chart?
JOhn
> Date: Sat, 5 Mar 2011 20:07:34 -0600
[quote] From: Tim(at)myrv10.com
To: RV10-list(at)matronics.com
Subject: Re: Re: seat rails and AN509 8R10 screws
--> RV10-List message posted by: Tim Olson <Tim(at)myrv10.com>
> --> RV10-List message posted by: "Pascal" <rv10flyer(at)verizon.net>
> Pascal
dmaib(at)mac.com Guest
Posted: Sat Mar 05, 2011 11:10 pm Post subject: seat rails and AN509 8R10 screws |
You can order them from Van's, as well. I don't know if Spruce is cheaper, but you can order any quantity from 1 on up from Van's.
David Maib
40559
Flying
On Mar 6, 2011, at 1:16 AM, John Gonzalez wrote:
[quote]Yes guys I have been doing this orderring of all different bolts and screw....but, and as is the case these are 8R10s, I have 8R7s.
JOhn
[quote] Date: Sat, 5 Mar 2011 20:07:34 -0600
To: RV10-list(at)matronics.com (RV10-list(at)matronics.com)
--> RV10-List message posted by: Tim Olson <Tim(at)myrv10.com (Tim(at)myrv10.com)>
> --> RV10-List message posted by: "Pascal" <rv10flyer(at)verizon.net (rv10flyer(at)verizon.net)>
> Pascal
bgill1(at)charter.net Guest
Posted: Sun Mar 06, 2011 4:01 am Post subject: seat rails and AN509 8R10 screws |
Hi John:
I order everything from Aircraft Spruce.. Don’t really have a conversion chart but most everything has dual designations there. Type in AN509 and the listing comes up for MS24694. From there you can see the second column contains the older AN509 dash number. The -8R10 looks to be MS24694-S7.
Hope that helps out some.
Byron
N253RV Phase one
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Gonzalez
Sent: Sunday, March 06, 2011 1:16 AM
To: RV 10 group
Subject: RE: Re: seat rails and AN509 8R10 screws
JOhn
> Pascal
Tim Olson
Posted: Sun Mar 06, 2011 5:09 am Post subject: seat rails and AN509 8R10 screws |
But that's what I mean....I ordered like 8R7's, 8R8's, 8R9's, 8R10's, 8R... If you prepare and order some additional sizes above and below, you'll be ready. I found many places where a slightly longer screw was nicer, or where I had some reason to switch. And for some locations I used stainless screws instead of the Cad plated, depending on what it was for.
You'll want to probably replace ALL of the wingtip and fairing screws with stainless, and leave them unpainted if you don't like chipped paint screws.
Do the same with AN bolts, especially 3's and 4's....get some additional sizes. For general hardware, I found it better to just empty the Vans baggies into parts bins all sorted out, and then order a pile of replacement and additional hardware so I had a more complete assortment of hardware. At this point I rarely need to order anything. It promotes good maintenance because you feel happy to replace a screw when it's in worsening condition, rather than reusing it because you didn't have one.
Buy 100 packs of cotter pins too....especially the ones for the axles.
And washers, and nuts both nylock and all-metal. You'll also find that in doing the engine you don't always do things 100% identically to other people, so you'll want extra Adel clamps, and non-nylon nuts in the engine compartment. Washers too of course. The list is long but if you're going to be your own mechanic later you may as well spend the $200-300 on extra hardware....even some sizes not in the plans. If it were a rare size, I ordered 20, but common I just went for 100 packs for the discount. You can usually go up a size if you need to, in a pinch.
Tim
On Mar 6, 2011, at 12:16 AM, John Gonzalez <indigoonlatigo(at)msn.com (indigoonlatigo(at)msn.com)> wrote:
[quote] Yes guys I have been doing this orderring of all different bolts and screw...but, and as is the case these are 8R10s, I have 8R7s.
JOhn
[quote] From: [url=mailto:Tim(at)myrv10.com]Tim(at)myrv10.com (Tim(at)myrv10.com)[/url]
To: [url=mailto:RV10-list(at)matronics.com]RV10-list(at)matronics.com (RV10-list(at)matronics.com)[/url]
Subject: Re: RV10-List: Re: seat rails and AN509 8R10 screws
> Pascal
bill.peyton
Joined: 19 Sep 2010 Posts: 198 Location: St. Louis, MO
Posted: Sun Mar 06, 2011 5:55 am Post subject: Re: seat rails and AN509 8R10 screws |
I checked and mine are in bag 1435 qty 80 an509-8r10. I attached a searchable (<control>F) word file for all but the Firewall Forward kit.
RV-10 Inventory List.doc |
69.5 KB |
2468 Time(s) |
_________________ Bill
WA0SYV
Aviation Partners, LLC |
Posted: Sun Mar 06, 2011 8:12 am Post subject: seat rails and AN509 8R10 screws |
Thanks Bill. I referenced bag 1435 in my kit which is located in my "quickbuild Fuselage Kit." My Firewall Foreward kits have bags in the 500's.
Indeed, this bag 1435 does contain the AN509 8R10 screws but there are only #20. That would leave me five screws per rail.
Weird how Van's inventory with the kits ship, but it is an wonder it works at all.
BTW not only have I been orderring extra of everything, but also now have the plastic Plano boxes to label and sort them.
> Subject: Re: seat rails and AN509 8R10 screws
dlm34077(at)q.com Guest
Posted: Sun Mar 06, 2011 9:22 am Post subject: seat rails and AN509 8R10 screws |
a real aviation supply house (Spruce)is first choice for the extra hardware but when they don't stock it, try McMaster Carr for example, for the cap screws for nose wheel stops and Wheel pant outboard "1/4" type stainless.
aerosport1
Posted: Sun Mar 06, 2011 9:53 am Post subject: seat rails and AN509 8R10 screws |
One thing to check for is that your seat
Rails are not being distorted once you
Screw them down. Both sides on my
10 needed shinned at the aft end.
I believe the plans talk about this. I have
A .02 shim on the one side and without it
The seat can will hardly move.
Geoff
Sent from my iPhone Geoff
On Mar 6, 2011, at 12:16 PM, "DLM" <dlm34077(at)q.com (dlm34077(at)q.com)> wrote:
[quote] a real aviation supply house (Spruce)is first choice for the extra hardware but when they don't stock it, try McMaster Carr for example, for the cap screws for nose wheel stops and Wheel pant outboard "1/4" type stainless.
_________________ Geoff Combs
RV-10 QB N829GW
Flying 500 hrs
40033 |
Posted: Sun Mar 06, 2011 1:18 pm Post subject: seat rails and AN509 8R10 screws |
I been thinking about Tim's response here and I know the truth regarding what he is up to.
Tim's wife says, "Honey, you have more extra bolts, washers, nuts and screws then you could ever use on our plane."
His reply, "Yah, I was thinking about that and I would hate for them to go to waste, I think I should start another project, it will be done once the kids move out and we only need two seats."
Very clever fox!!!!
Date: Sun, 6 Mar 2011 07:06:05 -0600
Tim
[quote] Yes guys I have been doing this orderring of all different bolts and screw....but, and as is the case these are 8R10s, I have 8R7s.
JOhn
> Pascal
Tim Olson
Posted: Sun Mar 06, 2011 4:36 pm Post subject: seat rails and AN509 8R10 screws |
You know, you may be on to something.
I do have the itch...
Tim
On Mar 6, 2011, at 3:14 PM, John Gonzalez <indigoonlatigo(at)msn.com (indigoonlatigo(at)msn.com)> wrote:
[quote] I been thinking about Tim's response here and I know the truth regarding what he is up to.
Very clever fox!!!!
From: [url=mailto:Tim(at)MyRV10.com]Tim(at)MyRV10.com (Tim(at)MyRV10.com)[/url]
To: [url=mailto:rv10-list(at)matronics.com]rv10-list(at)matronics.com (rv10-list(at)matronics.com)[/url]
Tim
On Mar 6, 2011, at 12:16 AM, John Gonzalez <[url=mailto:indigoonlatigo(at)msn.com]indigoonlatigo(at)msn.com (indigoonlatigo(at)msn.com)[/url]> wrote:
JOhn
From: (Tim(at)myrv10.com)[url=mailto:Tim(at)myrv10.com]Tim(at)myrv10.com (Tim(at)myrv10.com)[/url]
To: (RV10-list(at)matronics.com)[url=mailto:RV10-list(at)matronics.com]RV10-list(at)matronics.com (RV10-list(at)matronics.com)[/url]
--> RV10-List message posted by: Tim Olson <[url=mailto:Tim(at)myrv10.com]Tim(at)myrv10.com (Tim(at)myrv10.com)[/url]>
> --> RV10-List message posted by: "Pascal" <[url=mailto:rv10flyer(at)verizon.net]rv10flyer(at)verizon.net (rv10flyer(at)verizon.net)[/url]>
> Pascal
bill.peyton
Posted: Sun Mar 06, 2011 6:08 pm Post subject: Re: seat rails and AN509 8R10 screws |
When I received my kit, I scanned in the entire inventory document using a text converter, and then cleaned it up using MS Word, where it is easily searchable. I then just put the bags in plastic drawers purchase from the aviation section of Lowes. The drawers are numbered with the bag number. When I need a specific part I just punch it in to the work area laptop, and it tells me which bag its in. Vans told me they were in the process of converting all of the antique inventory forms to Word. They sent me the QB Fuse list, which is all they had done at the time. It sure makes it easier to find stuff. I never did anthing more than a bag inventory. I did find that I was short 300 of the CS4-4s, which Vans sent me ASAP, no questions.
bill
WA0SYV
partner14
Posted: Mon Mar 07, 2011 6:37 pm Post subject: seat rails and AN509 8R10 screws |
So Robin, you gonna have time to fly off the hours? When you flying it to Calif? There's goes the room in your hangar for my next visit!!!!
Don McDonald
BTW.... congrats.
Sent: Sun, March 6, 2011 5:04:46 PM
Look what we did with our extra bolts, washers, screws & nuts.
Robin
Do Not archive
[img]cid:1.3133798099(at)web161304.mail.bf1.yahoo.com[/img]
From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) [mailto:owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)] On Behalf Of John Gonzalez
Sent: Sunday, March 06, 2011 1:15 PM
To: RV 10 group
Very clever fox!!!!
Tim
JOhn
> Pascal
71.91 KB |
12149 Time(s) |
40636 |
