Sean Blair
Joined: 09 Jan 2006 Posts: 39 Location: Colorado Springs
Posted: Thu May 11, 2006 9:00 am Post subject: Infinity Aerospace Grip |
Hey everyone,
I am looking at the Infinity Aerospace Grips and they seem to be what I want. It looks like several builders have installed these as well. Could you flying users of this equipment share your impressions and configurations of the buttons/switches?
Also, is there anything you would like to change about the configuration you chose? Is it difficult to correct this after the installation?
Does the specific right or left hand molding bother you? Would you prefer having a "neutral" grip?
Thanks!
Sean B.
#40225
_________________ Sean S. Blair
#40225
N967SB (reserved) |
jesse(at)itecusa.org Guest
Posted: Thu May 11, 2006 9:19 am Post subject: Infinity Aerospace Grip |
We installed one in N256H and love it. In N415EC we are installing right
and left units. We have the following layout:
Left thumb - rudder trim
Coolie hat - aileron and elevator trim
Right thumb - flaps (momentary down - non-momentary up)
Trigger - PTT of course
Side thumb - Auto Pilot Control Wheel Steering
Pinky - flight timer on first, probably overhead LED panel lights on N415EC
We have the boost pump switch between the throttle and prop knobs, so
without moving your hands you have almost all of the important controls if
something happens. One option for the pinky is a starter solenoid button
so you could restart without moving your hands, especially with the boost
pump next to the throttle.
Hope this helps.
Jesse Saint
Hey everyone,
Thanks!
Sean B.
#40225
Jesse Saint
I-TEC, Inc.
www.itecusa.org
jjessen
Posted: Thu May 11, 2006 9:43 am Post subject: Infinity Aerospace Grip |
I'd also like to hear from those who've chosen to use some type of wooden
gripe, if anyone has. I'm interested in something simple, hardwood, but
with enough of a "head" to hold a hat switch, and maybe 1 or 2 other
buttons.
John J.
328
Tim(at)MyRV10.com Guest
Posted: Thu May 11, 2006 9:51 am Post subject: Infinity Aerospace Grip |
Sean,
I started skeptically looking at the infinity. All the plastic
grips looked like toys to me, but now all that's changed.
In addition, I used to think I'd want a neutral grip, not left
or right. I also used to think I didn't need that many buttons.
Boy have I learned.
I am liking the right-hand/left-hand arrangement, as it's comfortable
and I find that I don't swap hands that much because you are more
or less required (not REQUIRED, but...) to use your right hand if
you're in the right seat and left if you're in the left, since
the throttle is in the middle. Being right handed, I think that
if you were doing lots of radio work from the right seat, you
may have other preferences, but I don't fly from the right in my
own plane, so I can't comment much on that.
I do use every switch, and wish I had one or two more. I am
using them as follows:
Hat switch - Aileron and Elevator trim
One top button - swap chelton screen modes
Other top switch (DPDT) - Com flip com1 (UP) / Com flip com2 (DN)
Thumb button - CWS/AP Disconnect
Trigger - PTT
Pinky button - EFIS MUTE
In addition, I wish I had another button to swap my 2nd
chelton screen mode.
I'm not a fan of putting flaps or engine start on the stick.
There are various reasons why, inadvertent activation being
the biggest, but if you talk to a bunch of people you'll
at least get thinking points.
I also have a locking-lever toggle on the panel that is used
to switch OFF the ground returns on some of the functions
on the co-pilot switch. This allows me to disable the
copilot's TRIM, so they can't mess with my trim (important
if you have kids over there).
I like the setup very much. I think other grips would be
nice too, but I do like what I have. The wires route
down the stick tube, and aren't visible at all in the cabin.
My biggest wish is that I would have either added one more
button to the stick for that 2nd screen swap, or perhaps
instead of had it be a button, I would have used a 2nd
DPDT toggle so the up and down could do it to either
screen.
Whatever multi-function stick you get, I think you'll
like having some of these things on the stick. EFIS
mute I use all the time.
seanblair(at)adelphia.net wrote:
Hey everyone,
installation?
Thanks!
Sean B. #40225
rnewman(at)lutron.com Guest
Posted: Thu May 11, 2006 10:37 am Post subject: Infinity Aerospace Grip |
Tim, What is EFIS mute??
Also, I second many of your opinions regarding the usefulness of the
buttons.
On our Glastar we have elev trim, PTT and autopilot disable, and com
swap. Its very manageable and intuitive.
Also, I fully agree that the need to switch hands is pretty much zero.
I've tried to fly with my right hand and that's about as awkward as
trying to write cursive with the wrong hand!
-Bob Newman
fuse slow build, going slowly
Sean,
Boy have I learned.
Trigger - PTT
screen.
Hey everyone,
what
| Quote: | I want. It looks like several builders have installed these as
well.
| Quote: | Could you flying users of this equipment share your impressions and
installation?
Thanks!
Sean B. #40225
Posted: Thu May 11, 2006 10:39 am Post subject: Infinity Aerospace Grip |
John,
I have no gripe about wood.
buttons.
John J.
328
Posted: Thu May 11, 2006 11:05 am Post subject: Infinity Aerospace Grip |
See inline...
Bob Newman wrote:
The EFIS will give voice warnings: "terrain", "traffic", "check
engine", "stall", and others. When setting up the system and
fine tuning it especially, you'll want to quickly be able to
mute this stuff. Esp. on the first flight when you have your
stall speed warning and some things maybe set a bit high.
It's very handy.
| Quote: | Also, I second many of your opinions regarding the usefulness of the
buttons.
Yeah, the com swap really is cool. I can be viewing an airports
runway info on the chelton, scroll up to the CTAF freq. and hit
"TO COM1", then with my other hand that's on the stick, just flip
it and it'll be active without me moving over to the radio
and doing more work there. Great stuff.
| Quote: | Also, I fully agree that the need to switch hands is pretty much zero.
Yep, you get used to whatever you do.
| Quote: | -Bob Newman
>>> Tim(at)MyRV10.com 5/11/2006 1:50:31 PM >>>
Sean,
Boy have I learned.
Trigger - PTT
screen.
> Hey everyone,
what
well.
> installation?
> Thanks!
> Sean B. #40225
Tdawson(at)avidyne.com Guest
Posted: Thu May 11, 2006 11:20 am Post subject: Infinity Aerospace Grip |
We've got some wood grips. I think they are in the Spruce catalog, but I found them in a closet at work (long story).
We haven't flown yet, so I can't tell you how they are. Our right-side just has PTT. Pilot has
Pushbutton on top - AP
Toggle on top - Flap
Coolie hat on top - Trim
PTT near the index finger
and a pinky button we haven't decided on what it will be used for yet.
TDT
From: owner-rv10-list-server(at)matronics.com on behalf of Tim Olson
Sent: Thu 5/11/2006 2:37 PM
Subject: Re: Re: Infinity Aerospace Grip
John,
buttons.
John J.
328
jjessen
Posted: Thu May 11, 2006 11:35 am Post subject: Infinity Aerospace Grip |
grape gripe pipe pip whatever. a contextual spell checker would be nice.
coop85(at)bellsouth.net Guest
Posted: Thu May 11, 2006 1:18 pm Post subject: Infinity Aerospace Grip |
I opted for the wood grips that Van's sells. One version has both a PTT and
a coolie hat switch. I used a similar stick in my RV-6 and really liked it.
Since I'm not starting with roll trim, I used the side position of the
coolie hat for the autopilot control wheel steering.
One consideration I'd like to offer. I know a number of folks have put the
flap control on grip but I chose not to in order to prevent an inadvertent
flap extension at cruise speed. I think it would really get your attention
to get the flaps rolling at 170 knots and could be pretty easy to do. Just
my .02 worth, and it's not a problem as long as you never hit the wrong
button.
Marcus
Posted: Thu May 11, 2006 4:48 pm Post subject: Infinity Aerospace Grip |
Another thing with the left-right-handed grips is that you are not gripping
the whole thing the whole time you are flying. You rest your hand on your
lap and just hang on with two or three fingers to the bottom of the grip.
Flying this way it works with both hands. When you are gripping the whole
grip is when you need to focus and need to have your inside hand on the
throttle, for the most part. Also, the autopilot ends up doing a lot of the
flying anyway.
Do not archive.
Jesse Saint
I-TEC, Inc.
www.itecusa.org
352-465-4545
dmasys(at)cox.net Guest
Posted: Thu May 11, 2006 6:32 pm Post subject: Infinity Aerospace Grip |
I have the Infinity grip on my RV-7A and like it a lot, though I had to revise the Coolie hat wiring. Originally had the fore and aft Coolie hat control pitch trim, and moving it to the left swapped frequencies on the #1 Comm, while moving it right swapped frequencies on the #2 Comm. Bad idea -- found I was inadvertently changing frequencies whenever I changed the pitch trim.
I now have it set up with:
Top left = fuel boost pump
Coolie hat fore/aft = pitch trim. Don't have electric aileron trim so left/right on Coolie hat doesn't do anything currently.
Top right = flaps. Here the folks at Infinity recommended that down be momentary, and up be a locking position. I have that, but often find when I shut the plane down that the up flap motor is still running. On the -10 I am going to put an Infinity in, but the flap switch will be momentary on in both directions.
Trigger = PTT, like everybody
Thumb button = transponder ident
Pinkie button = A/P disconnect.
It's a very comfortable grip -- in the -7A I have the resting position rotated 45 degrees, so my elbow sits on the elbow rest with my forearm angled about 45 degrees.
(see http://array.ucsd.edu/rv7a/2003-02-16_stickgrip.jpg )
I normally fly the plane with two fingers on the grip (thumb and index finger of left hand). Only grap a handful of grip for takeoff and landing.
-Dan Masys
#40448 installing autopilot servos and wiring
Posted: Thu May 11, 2006 6:52 pm Post subject: Infinity Aerospace Grip |
Remember, that if you have the flap positioning system, when it get to the
top the motor shuts off and doesn't draw almost any current, just enough to
verify that it is in the up position, unless I am mistaken. Yes, it often
happens that the flap switch is left up, but that only is a problem if there
are two switches, and one is left up while the other is trying to put the
flaps down. That can be solved by the "disable copilot switches" switch if
there are two stick grips. Otherwise, leaving the flap switch in the
up-locked position, it is a reminder that the flaps are up, especially if,
as in N256H, you don't have a flap position indicator.
Do not archive.
Jesse Saint
I-TEC, Inc.
www.itecusa.org
352-465-4545
dlm46007(at)cox.net Guest
Posted: Thu May 11, 2006 7:23 pm Post subject: Infinity Aerospace Grip |
For the problem of a running flap motor I have put a running light next to
the flap switch (DPDT momentary down and switched up). light will indicate
that switch needs to be returned to neutral (center) position
10flyer(at)verizon.net Guest
Posted: Thu May 11, 2006 7:49 pm Post subject: Infinity Aerospace Grip |
Jesse, can you tell me how you installed electric rudder trim. I'm assuming
it's electric if there is a switch on the stick for it. I have been messing
with a tab on my rudder and have finally got a fairly neutral force for
cruise, but the ball is out one way on climb out and out the other in higher
speed descents. Not a big deal, at some point you have to fly these things
like real airplanes, but I was considering building a new rudder and adding
a built in tab with a servo in the tail to drive it. Just curious what you
came up with. Mark.(N104ML)
Posted: Fri May 12, 2006 4:16 am Post subject: Infinity Aerospace Grip |
We used AeroTrim on both N256H and now on N415EC. They really work well,
and can be installed after the plane is flying. The hardest part is getting
the wire there, but that isn't that bad at all. You just cut a hole in the
skin at the right place, either pop-rivet or nut-plate and screw the trim
servo in, then drill out a few rivets from the trailing edge and rivet the
hinge on. I don't have any pictures on me, sorry. Norm's number is
305-864-3336. We paid about $175, I think, but we bought more than one at a
time. His unit is STC'd for a bunch of planes, as I understand, so make
sure you let him know that you are experimental, and that you only want the
trim and the hinge, not the cheepo little toggle switch or the indicator.
If somebody wanted to go all-out, they could mount the trim under the skin
and then glass over it to make it a little more durable and a little more
flush-looking, but that would make it very hard to remove and service or
replace. We put in 6 #6 nutplates on N415EC (for both aileron and rudder
trims) and will be able to remove them without trouble.
We have over 200hours on N256H and wouldn't fly it without the trims. They
make it so easy to keep it flying clean, no matter how you decide to burn
your fuel, and keep the ball in the center. It's worth the money.
Jesse Saint
I-TEC, Inc.
www.itecusa.org
352-465-4545
Rick S.
Posted: Fri May 12, 2006 5:34 am Post subject: Infinity Aerospace Grip |
I have the CH products gripes. The sales rep is an RV-6 driver. It has all the same features as most, coolie hat, trigger, pinky and two thumb buttons. One nice feature is you can set the grip to allow it to swivel so it lines up with your hand as you bank and pitch. I'm not saying it's spins around freely and all loose, but the machined stick insert has a machined grove that the set screw rides in and the tension can be adjusted or locked fully down so there is no movement. I haven't tried to play with it yet. I read about the feature on a RV-7 site.
http://www.chproducts.com/retail/aircraft.html
Rick S.
40185
Fuse/fini
_________________ Rick S.
RV-10
40185 |
Ray.R.Doerr(at)sprint.com Guest
Posted: Fri May 12, 2006 6:38 am Post subject: Infinity Aerospace Grip |
I love these grips. I had them on my RV-9A on both sides as
well as my RV-10 (not flying yet). I have the left and right hand
version on each side. I mounted them at a 20 degree angle to the
centerline which is what I found to be the neutral position of my
forearm while my elbow rest on my lap. I even made my own circuit
boards that I put a DB15 connector on the wires from this grip and then
I have a db25 connector on the board that interfaces to everything else
in the plane. I have the hat switch run the ailron and elevator trims
via a onboard mosfet drivers. I have a flap toggle switch which is a
momentary on-off-on which the center is off. The other three location
have simple single pole single throw switches that I use for Audio Panel
Com Swap, Radio Act/Stby Swap, Transponder Ident, Auto Pilot disconnect.
This board I made can control three outputs for this gear as well as the
Ailron, Elavator and Flap motors. This is all solid state and no
relays. I then have another board on the co-pilot side that connects to
the pilot side with a 2 wire CAN bus. This is where any button on the
right stick can send commands to the left control to run the motors.
I've talked to the owner of Infinity Aerospace and he wants to
see what I have done and possibly sell them.
Thank You
Ray Doerr
40250 (First flight in 2 weeks.)
Posted: Fri May 12, 2006 6:46 am Post subject: Infinity Aerospace Grip |
Thanks, I'll look into it! Mark
Rick S.
Posted: Fri May 12, 2006 8:01 am Post subject: Infinity Aerospace Grip |
While were on the grip thing, How did you route your leads from the stick? Did you drill the curved portion or route them on the outside of the stick. Did anyone cut their sticks down to their most comfy position? I assume they will be too long as is, I need to mount a seat to check my length.
Rick S.
40185
RV-10
40185 |
