Need help with wiring LR3C-14 regulator & LED Lo Volt Wn
plevyakh
PostPosted: Tue Mar 01, 2011 6:03 pm    Post subject: Need help with wiring LR3C-14 regulator & LED Lo Volt Wn Reply with quote
Bob and fellow builders,
I need your help checking my use of an NK YB15 series pushbutton LED light with the B&C LR3C-14 Alternator controller.
I've attached what I think is how the Lo Volt Warning light should be wired.
I'd like to use this style switch since one of my instruments is using this same LED warning light. I'd like to keep the same style across my panel.
This LED light is NKK YB series part number YB15WSKW01-5C-JC-RO.
See: http://www.mouser.com/ProductDetail/NKK-Switches/YB15WSKW01-5C-JC-RO/?qs=Vo7e0yZOYdFthTQBhy2rSg%3d%3d
Can you please take a look at the schematic attached and confirm the wiring is correct and that it should work fine with LR3C in place of the Midget Flanged bulb?
Howard (working thru my page per system schematics)
LED LO Volt Wng Light Schematic w LR3C-14 Regulator.pdf
NKK YB15 Series Switch used as Lo Volt Wng light with LR3C Alternator Controller (Schematic - draft)
 Filename:  LED LO Volt Wng Light Schematic w LR3C-14 Regulator.pdf
 Filesize:  799.58 KB
 Downloaded:  494 Time(s)
Howard Plevyak
GlaStar / Cincinnati, Ohio
rparigoris
PostPosted: Tue Mar 01, 2011 10:32 pm    Post subject: Re: Need help with wiring LR3C-14 regulator & LED Lo Vol Reply with quote
Hi Howard
I too have a LR3c on my Rotax 914 Europa that I chose to use a LED for low voltage warning.
For starters, follow Bobs advise using this layout to prevent LED from glowing when there is high enough voltage:
http://www.europaowners.org/forums/gallery2.php?g2_itemId=79802
Another problem is will you be able to get information you desire from your LED during daylight operations with sunlight shining down on your LED? You may be disappointed. The stupid simple lamp as supplied by B+C works pretty good in sunlight. I fooled with an awful lot of LEDs. Many don't work well in sunlight. I purchased some pretty nice sunlight visible LEDs panel mount black bezel LEDs from allied and was at best disappointed. I ended up after several other disappointments mutilating the bezel mount LED and installing LEDs purchased from Best Hong Kong which gave acceptable performance.
You can have a look at page 2:
http://www.europaowners.org/forums/gallery2.php?g2_itemId=27305&g2_page=2
and page 3:
http://www.europaowners.org/forums/gallery2.php?g2_itemId=27305&g2_page=3
For all the LEDs I have fooled with, Pep boys are kinda nice, plenty bright and especial long with small flange. You best purchase a better quality resistor and solder it better than they do however. Also have a look at their Quad LEDs:
http://www.europaowners.org/forums/gallery2.php?g2_itemId=78683
and wide angle LEDs:
http://www.europaowners.org/forums/gallery2.php?g2_itemId=78681
Have fun
Ron Parigoris
plevyakh
PostPosted: Sun Mar 06, 2011 8:01 am    Post subject: Re: Need help with wiring LR3C-14 regulator & LED Lo Vol Reply with quote
rparigoris wrote:
Hi Howard
Ron Parigoris
Ron,
Thanks for the information. I took your recommendation and switched to a simple LED in my schematic. I'll be posting my entire electrical system schematic today for forum input and review.
Thanks again!
Howard
Howard Plevyak
