Door Hinges
Kellym
PostPosted: Mon Feb 28, 2011 5:08 am    Post subject: Door Hinges Reply with quote
Getting near to installing the hinges, and find that Vans didn't bother
to mark them at all. I haven't found on any build logs anything that
identifies which is left and right. Does the high side go to the front
or rear?
Kelly
Kelly McMullen
KCHD
Strasnuts
PostPosted: Mon Feb 28, 2011 5:26 am    Post subject: Door Hinges Reply with quote
Not next to my plane yet but I'm pretty sure the high sides face away from each for the contour of the cabin top and door top. It's not that they all face fwd or aft. They mirror each other.
On Feb 28, 2011, at 6:04, Kelly McMullen <kellym(at)aviating.com> wrote:
Getting near to installing the hinges, and find that Vans didn't bother to mark them at all. I haven't found on any build logs anything that identifies which is left and right. Does the high side go to the front or rear?
Kelly
RV-10 SB N801VR Flying
780 Hours
SuperSTOL 60 hours
Kellym
PostPosted: Mon Feb 28, 2011 6:00 am    Post subject: Door Hinges Reply with quote
Thanks Sean.
> Kelly
Kelly McMullen
KCHD
partner14
PostPosted: Mon Feb 28, 2011 6:06 am    Post subject: Door Hinges Reply with quote
Kelly, here is a couple of shots that should help..... btw, would you still like to have a set of the hinge covers. Sorry I hadn't sent them off already.
Don McDonald
Sent: Mon, February 28, 2011 7:04:42 AM
Subject: Door Hinges
--> RV10-List message posted by: Kelly McMullen <kellym(at)aviating.com (kellym(at)aviating.com)>
Kelly
 Filesize:  22.14 KB
 Viewed:  3775 Time(s)
 Filesize:  21.83 KB
Don A. McDonald
40636
Mauledriver(at)nc.rr.com
PostPosted: Mon Feb 28, 2011 7:37 am    Post subject: Door Hinges Reply with quote
FYI, the hinges definitely rate multiple trial fittings and clear
marking. I've found it impossible to visually determine which hinge is
which. When I guess, it's ALWAYS wrong. Only my markings allow me to
get them back on right. And when you paint and prime, make sure you
maintain your marks.
Bill "screw up once, then measure thrice" Watson
front or rear?
Kelly
