Posted: Tue Feb 22, 2011 4:13 pm Post subject: Governor control cable bracket |
I’m trying to figure out what to do for a governor bracket. I’m using a PCU5000 governor and James plenum. I purchased the bracket from Van’s but it is clocked wrong (ether pointed at the cylinder or pointed straight down).
How did others do this?
Carl
Kelly McMullen
Posted: Tue Feb 22, 2011 4:56 pm Post subject: Governor control cable bracket |
I think that is the exact combination Deems has on his tricked out Ten.
On Tue, Feb 22, 2011 at 5:10 PM, Carl Froehlich
<carl.froehlich(at)verizon.net> wrote:
| Quote: | I’m trying to figure out what to do for a governor bracket. I’m using a
down).
Carl
A&P/IA, EAA Tech Counselor
KCHD |
Deems Davis
Posted: Tue Feb 22, 2011 5:36 pm Post subject: Governor control cable bracket |
Here's a link to a set of pictures that should be self explanatory: http://deemsrv10.com/album/Sec%20FF2%20Baffling%20and%20Plenum/slides/DSC04852.html
Here's a link to some write ups that accompany the pics: http://deemsrv10.com/FF2logindex.html
Deems
On 2/22/2011 5:46 PM, Kelly McMullen wrote: [quote] | Quote: | --> RV10-List message posted by: Kelly McMullen <apilot2(at)gmail.com> (apilot2(at)gmail.com)
down).
Carl
Deems Davis[b]
Posted: Tue Feb 22, 2011 6:03 pm Post subject: Governor control cable bracket |
Ahhhh the good old days. Deems, do you miss having an airplane in the garage?
To all those still building at home. One day you may be able to fit a car in your garage again.
Robin
From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) [mailto:owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)] On Behalf Of Deems Davis
Sent: Tuesday, February 22, 2011 5:15 PM
Subject: Re: Governor control cable bracket
Deems
On 2/22/2011 5:46 PM, Kelly McMullen wrote: | Quote: | --> RV10-List message posted by: Kelly McMullen <apilot2(at)gmail.com> (apilot2(at)gmail.com) I think that is the exact combination Deems has on his tricked out Ten.
On Tue, Feb 22, 2011 at 5:10 PM, Carl Froehlich<carl.froehlich(at)verizon.net> (carl.froehlich(at)verizon.net) wrote: | Quote: | | I’m trying to figure out what to do for a governor bracket. I’m using aPCU5000 governor and James plenum. I purchased the bracket from Van’s butit is clocked wrong (ether pointed at the cylinder or pointed straightdown). | 0123456789 | Quote: | | I think that is the exact combination Deems has on his tricked out Ten. | 0 | Quote: | | I think that is the exact combination Deems has on his tricked out Ten. | 1 | Quote: | | I think that is the exact combination Deems has on his tricked out Ten. | 2 | Quote: | | I think that is the exact combination Deems has on his tricked out Ten. | 3 | Quote: | | I think that is the exact combination Deems has on his tricked out Ten. | 4 I think that is the exact combination Deems has on his tricked out Ten. | 5 | Quote: | | I think that is the exact combination Deems has on his tricked out Ten. | 6 | Quote: | | I think that is the exact combination Deems has on his tricked out Ten. | 7 | Quote: | | I think that is the exact combination Deems has on his tricked out Ten. | 8 | Quote: | | I think that is the exact combination Deems has on his tricked out Ten. | 901
2345==============[/b][/quote] ,[/b][/quote] ?RV10-List">http://www.matronics.com/Navigator?RV10-List[/b]
[/quote]67 = t; http://www.matronics.com/contribution[/b][/quote] ==============[/b]
[/quote]8
Checked by AVG - www.avg.com
Version: 10.0.1204 / [quote][b]
rleffler
Posted: Tue Feb 22, 2011 6:34 pm Post subject: Governor control cable bracket |
With all the freezing rain and snow here the last few weeks, both my wife and I are appreciative of having the cars in the garage. The down size is that I have a twelve mile drive to an unheated hangar. The build has slowed down a bit, but I’m anxious to when it starts getting warmer. I’ll be almost living at the hangar to get things done this summer. It won’t be done for Oshkosh, but will be done before fall.
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Robin Marks
Sent: Tuesday, February 22, 2011 8:59 PM
Subject: RE: Governor control cable bracket
Robin
[quote] [b]
_________________ Bob Leffler
N410BL - Phase I
n8zg(at)att.net Guest
Posted: Tue Feb 22, 2011 6:58 pm Post subject: Governor control cable bracket |
My airplane has been out of the garage for nearly three years.
I’m still hard-pressed to get a bicycle in far enough to air-up the tires…
neal
Sent: Tuesday, February 22, 2011 7:59 PM
Robin
Deems
On 2/22/2011 5:46 PM, Kelly McMullen wrote: | Quote: | --> RV10-List message posted by: Kelly McMullen <apilot2(at)gmail.com> (apilot2(at)gmail.com) I think that is the exact combination Deems has on his tricked out Ten. On Tue, Feb 22, 2011 at 5:10 PM, Carl Froehlich<carl.froehlich(at)verizon.net> (carl.froehlich(at)verizon.net) wrote: | Quote: | | I’m trying to figure out what to do for a governor bracket. I’m using aPCU5000 governor and James plenum. I purchased the bracket from Van’s butit is clocked wrong (ether pointed at the cylinder or pointed straight | 0123456789 | Quote: | | I think that is the exact combination Deems has on his tricked out Ten. | 0 | Quote: | | I think that is the exact combination Deems has on his tricked out Ten. | 1 | Quote: | | I think that is the exact combination Deems has on his tricked out Ten. | 2 | Quote: | | I think that is the exact combination Deems has on his tricked out Ten. | 3 | Quote: | | I think that is the exact combination Deems has on his tricked out Ten. | 4 | Quote: | | I think that is the exact combination Deems has on his tricked out Ten. | 5I think that is the exact combination Deems has on his tricked out Ten. | 6 | Quote: | | I think that is the exact combination Deems has on his tricked out Ten. | 7 | Quote: | | I think that is the exact combination Deems has on his tricked out Ten. | 8 | Quote: | | I think that is the exact combination Deems has on his tricked out Ten. | 9012
3456
?RV10-List">http://www.matronics.com/Navigator?RV10-List7
==============8
Version: 10.0.1204 / 90 - List Contribution Web generous nbsp; --> http://www.matronics.com/c=[/b] [/quote]1
Deems Davis
Posted: Tue Feb 22, 2011 7:04 pm Post subject: Governor control cable bracket |
Funny thing, the cars are in the garage, but its messier than it ever was with the airplane. The hangar on the other hand is spotless
Deems
On 2/22/2011 6:58 PM, Robin Marks wrote: | Quote: |
Robin
Deems
On 2/22/2011 5:46 PM, Kelly McMullen wrote: | Quote: | --> RV10-List message posted by: Kelly McMullen <apilot2(at)gmail.com> (apilot2(at)gmail.com) I think that is the exact combination Deems has on his tricked out Ten. On Tue, Feb 22, 2011 at 5:10 PM, Carl Froehlich<carl.froehlich(at)verizon.net> (carl.froehlich(at)verizon.net) wrote: | Quote: | | I’m trying to figure out what to do for a governor bracket. I’m using aPCU5000 governor and James plenum. I purchased the bracket from Van’s butit is clocked wrong (ether pointed at the cylinder or pointed straightdown). | 0 1 2 3 4 5 6 7 8 9 | Quote: | | I think that is the exact combination Deems has on his tricked out Ten. | 0 | Quote: | | I think that is the exact combination Deems has on his tricked out Ten. | 1 | Quote: | | I think that is the exact combination Deems has on his tricked out Ten. | 2 | Quote: | | I think that is the exact combination Deems has on his tricked out Ten. | 3 | Quote: | | I think that is the exact combination Deems has on his tricked out Ten. | 4 I think that is the exact combination Deems has on his tricked out Ten. | 5 | Quote: | | I think that is the exact combination Deems has on his tricked out Ten. | 6 | Quote: | | I think that is the exact combination Deems has on his tricked out Ten. | 7 | Quote: | | I think that is the exact combination Deems has on his tricked out Ten. | 8 | Quote: | | I think that is the exact combination Deems has on his tricked out Ten. | 9 0 1
2 3 4 5 ============== , ?RV10-List">http://www.matronics.com/Navigator?RV10-List 6 7 = t; http://www.matronics.com/contribution ============== 8
On Tue, Feb 22, 2011 at 5:10 PM, Carl Froehlich | 0 [quote][b]
jcumins(at)jcis.net Guest
Posted: Tue Feb 22, 2011 8:14 pm Post subject: Governor control cable bracket |
Boy do I every pay the right of passage having the garage full of RV-10 parts. I get plenty of lip service when the wife has to scrape the ice off her windows at 6:30 in the morning. I do volunteer to go scrape them but I am spoiled she says not thanks I can do it.
HEHEHE
John G. Cumins
President
2499 B1 Martin Rd
Fairfield Ca 94534
707-425-7100
707-425-7576 Fax
Your Total Technology Solution Provider
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Deems Davis
Sent: Tuesday, February 22, 2011 6:59 PM
Deems
Robin
Deems
On 2/22/2011 5:46 PM, Kelly McMullen wrote: | Quote: | --> RV10-List message posted by: Kelly McMullen <apilot2(at)gmail.com> (apilot2(at)gmail.com) I think that is the exact combination Deems has on his tricked out Ten. On Tue, Feb 22, 2011 at 5:10 PM, Carl Froehlich<carl.froehlich(at)verizon.net> (carl.froehlich(at)verizon.net) wrote: | Quote: | | I’m trying to figure out what to do for a governor bracket. I’m using aPCU5000 governor and James plenum. I purchased the bracket from Van’s butit is clocked wrong (ether pointed at the cylinder or pointed straightdown). | 0123456789 | Quote: | | I think that is the exact combination Deems has on his tricked out Ten. | 0 | Quote: | | I think that is the exact combination Deems has on his tricked out Ten. | 1 | Quote: | | I think that is the exact combination Deems has on his tricked out Ten. | 2 | Quote: | | I think that is the exact combination Deems has on his tricked out Ten. | 3 | Quote: | | I think that is the exact combination Deems has on his tricked out Ten. | 4I think that is the exact combination Deems has on his tricked out Ten. | 5 | Quote: | | I think that is the exact combination Deems has on his tricked out Ten. | 6 | Quote: | | I think that is the exact combination Deems has on his tricked out Ten. | 7 | Quote: | | I think that is the exact combination Deems has on his tricked out Ten. | 8 | Quote: | | I think that is the exact combination Deems has on his tricked out Ten. | 901
2345
= t; http://www.matronics.com/contribution ============== 7
Version: 10.0.1204 / 89 | Quote: | | On Tue, Feb 22, 2011 at 5:10 PM, Carl Froehlich | 0
| Quote: | | On Tue, Feb 22, 2011 at 5:10 PM, Carl Froehlich | 1 | Quote: | | On Tue, Feb 22, 2011 at 5:10 PM, Carl Froehlich | 2 | Quote: | | On Tue, Feb 22, 2011 at 5:10 PM, Carl Froehlich | 3 | Quote: | | On Tue, Feb 22, 2011 at 5:10 PM, Carl Froehlich | 4< - MATRONICS WEB FORUMS via the Web --> http://forums.matronics.com - List Contribution Web generous nbsp; --> http://www.matronics.com/c=[/b]On Tue, Feb 22, 2011 at 5:10 PM, Carl Froehlich[/quote]5
1.54 KB |
5741 Time(s) |
speckter(at)comcast.net Guest
Posted: Wed Feb 23, 2011 5:44 am Post subject: Governor control cable bracket |
From your mouth to my ears!!!
Gary Specketer
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Neal George
Sent: Tuesday, February 22, 2011 9:56 PM
neal
Robin
Deems
On 2/22/2011 5:46 PM, Kelly McMullen wrote: | Quote: | --> RV10-List message posted by: Kelly McMullen <apilot2(at)gmail.com> I think that is the exact combination Deems has on his tricked out Ten. On Tue, Feb 22, 2011 at 5:10 PM, Carl Froehlich<carl.froehlich(at)verizon.net> wrote: | Quote: | | I’m trying to figure out what to do for a governor bracket. I’m using aPCU5000 governor and James plenum. I purchased the bracket from Van’s butit is clocked wrong (ether pointed at the cylinder or pointed straight | 0123456789 | Quote: | | I think that is the exact combination Deems has on his tricked out Ten. | 0 | Quote: | | I think that is the exact combination Deems has on his tricked out Ten. | 1 | Quote: | | I think that is the exact combination Deems has on his tricked out Ten. | 2 | Quote: | | I think that is the exact combination Deems has on his tricked out Ten. | 3 | Quote: | | I think that is the exact combination Deems has on his tricked out Ten. | 4 | Quote: | | I think that is the exact combination Deems has on his tricked out Ten. | 5I think that is the exact combination Deems has on his tricked out Ten. | 6 | Quote: | | I think that is the exact combination Deems has on his tricked out Ten. | 7 | Quote: | | I think that is the exact combination Deems has on his tricked out Ten. | 8 | Quote: | | I think that is the exact combination Deems has on his tricked out Ten. | 9012
3456
?RV10-List">http://www.matronics.com/Navigator?RV10-List 7
============== 8
<nbsp; - MATRONICS WEB FORUMS via the Web --> http://forums.matronics.com - List Contribution Web generous nbsp; --> http://www.matronics.com/c= 1
2 [quote][b]
Posted: Wed Feb 23, 2011 3:12 pm Post subject: Governor control cable bracket |
Thanks Deems – perfect.
Carl
Sent: Tuesday, February 22, 2011 8:15 PM
Deems
2345 - List Contribution Web generous nbsp; --> http://www.matronics.com/c=[/b] [/quote]6
