		bcbcbc
				 Posted: Sat Feb 19, 2011 11:51 am    Post subject: Yak 52 Air Leaks |
				Hello all, my Yak has a bleed down air leak that takes about 2 days, thus making it hard to detect.  I've replaced the pop off valve piston and the air filler check valve.  The main air shutoff valve has been checked good.  Thus the leak is between the air filler check valve and the main air shutoff valve.  That seems to only leave air lines and B nuts and perhaps flared tube end cracks.  Has anyone else had a slow leak, what did you do, and what turned out to be the problem, so I can intelligently hone in on what the problem might be, instead of tearing everything apart.  I can still fly alright since the compressor overcomes the slow leak, but I'd like to see that main air gage park itself at 40 or 50.  The emergency side is tight as a drum.  Thanks all.
  |  | - The Matronics Yak-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		radiopicture
				 Posted: Sat Feb 19, 2011 12:48 pm    Post subject: Yak 52 Air Leaks |
				Those problems can be pesky, but since it doesn't appear to be leaking in, try slathering all fittings, etc. with soapy water.
 On Feb 19, 2011, at 2:51 PM, bcbcbc wrote:
  Hello all, my Yak has a bleed down air leak that takes about 2 days, thus making it hard to detect.  I've replaced the opo off valve piston and the air filler check valve.  The main air shutoff valve has been checked good.  Thus the leak is between the air filler check valve and the main air shutoff valve.  That seems to only leave air lines and B nuts and perhaps flared tube end cracks.  Has anyone else had a slow leak, what did you do, and what turned out to be the problem, so I can intelligently hone in on what the problem might be, instead of tearing everything apart.  I can still fly alright since the compressor overcomes the slow leak, but I'd like to see that main air gage park itself at 40 or 50.  The emergency side is tight as a drum.  Thanks all.
  http://forums.matronics.com/viewtopic.php?p=331551#331551
		talew(at)bellsouth.net Guest
				 Posted: Sat Feb 19, 2011 1:16 pm    Post subject: Yak 52 Air Leaks |
				i have found that kid's bubble mix works well when applied with a small paint
 brush .
 terry lewis
		bcbcbc
				 Posted: Sat Feb 19, 2011 1:35 pm    Post subject: Re: Yak 52 Air Leaks |
				Excellent advice !!!  I figured that would be the next step, and rather simple to do at that.  Thanks for the prompt replies.
		KingCJ6(at)aol.com Guest
				 Posted: Sat Feb 19, 2011 3:05 pm    Post subject: Yak 52 Air Leaks |
				An ultrasonic leak detector is the best way to go. One can aim it or just  have it in the proximity of a small leak and it will sound like a raging  river.  Good for areas you can't access and observe soapy water.   About $100 on E-Bay.
  Dave
   In a message dated 2/19/2011 1:37:51 P.M. Pacific Standard Time,  ghostemail(at)verizon.net writes:
   	  | Quote: | 	 		  -->    Yak-List message posted by: "bcbcbc"    <ghostemail(at)verizon.net>
 Read this topic online    here:
 http://forums.matronics.com/viewtopic.php?p=331558#331558===============================================
 _-=   e  ties  Day  ================================================               - MATRONICS WEB FORUMS  ================================================             - List Contribution Web Site  sp;                             ===================================================
		bcbcbc
				 Posted: Sat Feb 19, 2011 3:20 pm    Post subject: Re: Yak 52 Air Leaks |
				Another great idea.  Thanks very much !!!
		Vic
  Joined: 12 Aug 2008 Posts: 116 Location: Southern Bavaria
				 Posted: Sat Feb 19, 2011 5:35 pm    Post subject: Re: Yak 52 Air Leaks |
				Hello,
 don“t forget to check the lines to the manometer, they are rubber hoses in the 18 T, don“t know about 52s. These hoses may be awkward to replace, so we had a leak there due to old age of the rubber. And yes, we had a develloping fracture in a pipe as well. Each time we could locate the problem by just listening carefully in a quiet hangar. A pressure system drop to zero in two days is quite a few gallons per hour. So I“suggest you take a torch and listen carefully in the still of the night. Not knowing your age I would have advised to take a younger person with you for the job, but then a veteran of the techno generation would be quite useless at that.
   Good luck with that one
 cheers
 Vic
		radiopicture
				 Posted: Sat Feb 19, 2011 5:44 pm    Post subject: Yak 52 Air Leaks |
				I can still hear Led Zepelin when it's quiet.
 On Feb 19, 2011, at 8:35 PM, Vic wrote:
  Hello,
  cheers
  Vic
  http://forums.matronics.com/viewtopic.php?p=331573#331573
		Vic
				 Posted: Sat Feb 19, 2011 7:14 pm    Post subject: Re: Yak 52 Air Leaks |
				Hey,
 Led Zeppelin tinnitus is quite allright ( though it does not help with the diagnosis for pneumatics ) !
 cheers
 Vic
		hkgibby(at)yahoo.com Guest
				 Posted: Sat Feb 19, 2011 9:41 pm    Post subject: Yak 52 Air Leaks |
				Don't forget the gear and flap handles;  any and all can be the culprit;  Leaking rear gear handle is common.  Also, all four of your actuators (3 gear, 1 flap) can have leak-past internally.  Doug overhauled all of mine and it helped.  Finally, your two brake valves (reducing and differential) can go bad and be a source of leakage.  The Chinese made up overhaul kits for all these air system valves and tear them down every 100 hours I believe.  Doubt many of us do that...
  Hank Gibson
 904-738-3240 Mobile
 904-213-1760 Home
 hkgibby(at)yahoo.com (hkgibby(at)yahoo.com)
 hkgibson(at)fnf.com (hkgibson(at)fnf.com)
 --- On Sat, 2/19/11, bcbcbc <ghostemail(at)verizon.net> wrote:
 Subject: Yak 52 Air Leaks
 To: yak-list(at)matronics.com
 Date: Saturday, February 19, 2011, 2:51 PM
  --> Yak-List message posted by: "bcbcbc" <ghostemail(at)verizon.net (ghostemail(at)verizon.net)>
		radiopicture
				 Posted: Sat Feb 19, 2011 9:46 pm    Post subject: Yak 52 Air Leaks |
				shuttle valves, too
 On Feb 20, 2011, at 12:37 AM, Hank Gibson wrote:
 [quote]Don't forget the gear and flap handles;  any and all can be the culprit;  Leaking rear gear handle is common.  Also, all four of your actuators (3 gear, 1 flap) can have leak-past internally.  Doug overhauled all of mine and it helped.  Finally, your two brake valves (reducing and differential) can go bad and be a source of leakage.  The Chinese made up overhaul kits for all these air system valves and tear them down every 100 hours I believe.  Doubt many of us do that...
  Hank Gibson
 904-738-3240 Mobile
 904-213-1760 Home
 --- On Sat, 2/19/11, bcbcbc <ghostemail(at)verizon.net (ghostemail(at)verizon.net)> wrote:
 From: bcbcbc <ghostemail(at)verizon.net (ghostemail(at)verizon.net)>
 [/url] | 	  [url=http://www.matronics.com/Navigator?Yak-List]
		Vic
				 Posted: Sun Feb 20, 2011 7:46 am    Post subject: Re: Yak 52 Air Leaks |
				Hello,
 the question here was, where does the air go when the main shut-off valve is closed ?
 Vic
		wlannon(at)persona.ca Guest
				 Posted: Sun Feb 20, 2011 9:24 am    Post subject: Yak 52 Air Leaks |
				Usually past the corroded valve cone (and/or seat) in the main air valve.
  	  | Quote: | 	 		  From there into the operating system where it will find a leak path to
 atmosphere.
 Doug has new stainless steel cones to fix that problem.
 Of course there are other things to check but not very many.  Leaking main
 air tank or fittings, pipeline cracks,  bad flares, cracked sleeves. cracked
 flare nuts.  Since there is only one pipeline this is easy.
 Walt
 To: <yak-list(at)matronics.com>
 Sent: Sunday, February 20, 2011 7:46 AM
 Subject: Re: Yak 52 Air Leaks
				 Posted: Sun Feb 20, 2011 7:19 pm    Post subject: Yak 52 Air Leaks |
				Although everything you say Hank is absolutely true, we need to
 remember, this is a Yak 52 leak and not a CJ6 leak.  With the main air
 valve turned off, none of the actuators, gear selectors or any other
 component in the system AFTER the main air valve can discharge the main
 air tank on the Yak 52.
 Dennis
 On 2/19/2011 11:37 PM, Hank Gibson wrote:
  	  | Quote: | 	 		   Don't forget the gear and flap handles; any and all can be the culprit;
  Hank Gibson
  904-738-3240 Mobile
  904-213-1760 Home
  hkgibby(at)yahoo.com <mailto:hkgibby(at)yahoo.com>
  hkgibson(at)fnf.com <mailto:hkgibson(at)fnf.com>
      <http://us.mc367.mail.yahoo.com/mc/compose?to=ghostemail(at)verizon.net>>
      <http://www.matronics.com/Navigator?Yak-List>
				Also after the main air valve.  Can not discharge the main air tank with
 the main air valve turned off.
 Dennis
 On 2/19/2011 11:44 PM, Eric Wobschall wrote:
  	  | Quote: | 	 		   shuttle valves, too
 > Hank Gibson
 > 904-738-3240 Mobile
 > 904-213-1760 Home
 > <mailto:ghostemail(at)verizon.net>>/* wrote:
 >     From: bcbcbc <ghostemail(at)verizon.net <mailto:ghostemail(at)verizon.net>>
 >     To: yak-list(at)matronics.com <mailto:yak-list(at)matronics.com>
				 Posted: Sun Feb 20, 2011 7:20 pm    Post subject: Yak 52 Air Leaks |
				Precisely!
 Dennis
				 Posted: Sun Feb 20, 2011 7:36 pm    Post subject: Yak 52 Air Leaks |
				I have found with a leaking main air valve, one can simply disconnect
 the output side of the valve and spray with soapy water which if
 leaking, will definitely bubble.  Also with a leaking main air valve,
 the tell-tale sign is there is always brake pressure air.  ie: if one
 were to squeeze off all the residual air using the brake handle and let
 it sit for a few hours, then come back and more air can be squeezed off
 with the brake handle, then the main air valve is leaking.
 One thing that is frequently overlooked in the 52 is the physical
 connections on the the air pressure instruments (front and rear
 cockpits).  On the 52, the main and emergency instruments are connected
 before the main air valve.  (Not so on the CJ6; main air instrument is
 connected after the main air valve).  I have found the 17mm nuts on the
 back side of the instrument loose on a few Yak 52's.  A real pain in the
 rear to get to AND tighten without twisting the instrument in the
 instrument mounting bracket.
 Dennis
 On 2/20/2011 11:19 AM, Walter Lannon wrote:
  atmosphere.
  main air tank or fittings, pipeline cracks, bad flares, cracked sleeves.
  cracked flare nuts. Since there is only one pipeline this is easy.
  Walt
 > Hello,
 > valve is closed ?
 > Vic
 > http://forums.matronics.com/viewtopic.php?p=331612#331612
