sstearns2(at)yahoo.com Guest
Posted: Thu Feb 17, 2011 9:54 am Post subject: [QUAR] Re: DUST COVER and insturment panels |
The best thing I did on my airplane was to take Mark's advise from a long time ago and make my panel so it can rotate down and be easily removable.
I have bellcrank bearings on the ends of the panel and all the tubes and wires either have enough excess or exit the panel on the hingeline. I can take out two screws and a nut and the whole panel folds down and rests on the throttle quadrent. Also, all the wires go to cannon plugs on a plate behind the panel. I can remove or install the whole panel in about 20 minutes.
There are pictures on Bob's site. It's really a must do modification looking back at what I've gone through in my flight testing.
Scott
--- On Thu, 2/17/11, Conners, Jerry L <jconners(at)dot.state.nv.us> wrote:
From: Conners, Jerry L <jconners(at)dot.state.nv.us>
Subject: RE: [QUAR] Re: DUST COVER
To: kis-list(at)matronics.com
Date: Thursday, February 17, 2011, 9:09 AM
And something easily removable…having work access to ‘behind the panel’ from the ‘top’ has been important during the last 10 years flying N94K.
Jer
From: owner-kis-list-server(at)matronics.com [mailto:owner-kis-list-server(at)matronics.com] On Behalf Of ALFRED ROSA
Sent: Thursday, February 17, 2011 8:18 AM
Subject: [QUAR] Re: DUST COVER
Importance: Low
THANKS ALL FOR THE TIPS. There's many ways to skin this cat. I think I will cut one out of sheet metal and bend it to shape. then do layups using the metal as a mould. Then surface the whole thing with 1/4" soft foam and cover with beige vinyl that I'm using for the interior.
Al
On Wed, Feb 16, 2011 at 10:30 AM, ted <teds532(at)wk.net (teds532(at)wk.net)> wrote:
I MADE MY DUST COVER WITH 1/4 INCH HARDWARE CLOTH LARGER THEN NEEDED.CUT TO SIZE LATER,COVERED WITH DUCT TAPE THEN WITH PEELPLY,TWO LAYERS OF FIBERGLASS,ONE LAYER OF CARBON FIBER THEN PUT IT ON TOP OF THE CONTROL PANEL AND USED CLEECO CLIPS AND WOOD BRACES TO HOLD IT IN PLACE UNTILL DRY.ADDED 1/4 INCH FOAM .ADDED EXTRA FOAM ON EDGE AT CONTROL PANEL.
| Quote: | | et="_blank">http://www.matronics.com/Navigator?KIS-Listtp://forums.matronics.com_blank">http://www.matronics.com/contribution </ ========================http://www.matronics.com/Navigator?KIS-List</ ========================http://forums.matronics.com</====== | 0
This communication, including any attachments, may contain confidential information and is intended only for the individual or entity to whom it is addressed. Any review, dissemination or copying of this communication by anyone other than the intended recipient is strictly prohibited. If you are not the intended recipient, please contact the sender by reply e-mail and delete all copies of the original message.
fredorosa(at)gmail.com Guest
Posted: Thu Feb 17, 2011 10:42 am Post subject: [QUAR] Re: DUST COVER and insturment panels |
My panel is fairly easy to remove but I have to first remove the yokes since they pass through the panel. I have a rubber vibration isolator at each of 5 mounting points holding the panel to the fuselage so I have to remove 5 nuts and 2 yokes to pull away the instrument panel. About a half hour job.
Al
On Thu, Feb 17, 2011 at 12:52 PM, Scott Stearns <sstearns2(at)yahoo.com (sstearns2(at)yahoo.com)> wrote:
[quote]The best thing I did on my airplane was to take Mark's advise from a long time ago and make my panel so it can rotate down and be easily removable.
Scott
--- On Thu, 2/17/11, Conners, Jerry L <jconners(at)dot.state.nv.us (jconners(at)dot.state.nv.us)> wrote:
From: Conners, Jerry L <jconners(at)dot.state.nv.us (jconners(at)dot.state.nv.us)>
Jer
From: owner-kis-list-server(at)matronics.com (owner-kis-list-server(at)matronics.com) [mailto:owner-kis-list-server(at)matronics.com (owner-kis-list-server(at)matronics.com)] On Behalf Of ALFRED ROSA
Importance: Low
Al
2[b]
