mono support when derigged
graeme bird
PostPosted: Wed Feb 16, 2011 2:43 pm    Post subject: mono support when derigged Reply with quote
What do folk use to support a mono fuselage when de-rigged, I have something for the build so I can raise the wheel but what about when I need to move it when the cowls are on etc, is there a standard solution?
Graeme Bird
kit4 (Wagstaff) TBD
Kit 1 G-UMPY - Mono Classic/XS 912S, Woodcomp G(@)gdbmk.co.uk
rparigoris
PostPosted: Wed Feb 16, 2011 3:02 pm    Post subject: Re: mono support when derigged Reply with quote
Hi Graeme
A few ideas:
http://www.europaowners.org/forums/gallery2.php?g2_itemId=77261
Ron Parigoris
carl(at)flyers.freeserve.
PostPosted: Thu Feb 17, 2011 2:05 pm    Post subject: mono support when derigged Reply with quote
Sooner or later (once your Europa is flying) you will need to raise/ lift
the fuselage.
One solution to purchase a hydraulic engine hoist - new on Ebay for £125 or
s/h for less.
Use the engine mounting frame as an attachment point.
Obviously there are cheaper options but we find ours invaluable as the only
practical way to inspect and overhaul the undercarriage.
Carl & Dot
G-LABS
