fklein(at)orcasonline.com Guest
Posted: Thu Mar 10, 2011 12:38 pm Post subject: latching relays |
Hi Bob,
I'm following your Figure Z-19 schematic as a guide to the electrics
to service an MPEFIed Sube EA81 derivative put out by Ron Carr at RAM
Performance...it is powering a Europa XS, well along in its
construction.
With the FWF complete (well, almost complete), a lot of the wiring
done for ancillary systems (fuel pumps, lighting, antennas, etc.) I'm
taking a hard look at the power side of things and have just ordered
35 feet of Super-4 fatwire, and am planning on dual Odyssey batteries.
And I have a couple of the generic contactors which Acft. Spruce sells
as Master Relays (p/n 111-226), purchased w/ the intention of using
one at each battery.
A pal...a savvy guy for MARINE electrical systems...has suggested that
I use "latching relays" which, he sez, will add to flight safety. I've
not seen any references to them in your discussion of battery
contactors in your book, though you do include some cautionary words
about proper installation and potential contactor failure.
What do you have to say about "latching relays" functioning as battery
contactors?
Thanks in advance for any wisdom you can offer...I confess to be one
of those airplane builders w/ scant knowledge of the electrical side
of things,
Fred
markcs
Posted: Fri Mar 11, 2011 5:03 am Post subject: Re: latching relays |
Fred,
I know you asked Bob for his opinion on self latching relays, but thought I would through my two penneth in.
Self latching relays operate in a number of different ways including the use of permanent magnets and cam mechanisms to achieve the latching. I suppose that there are two main perceived advantages of these devices for an aircraft:
1. Once latched they do not require power to hold them open (but with your Sube you have a fairly meaty alternator so that should not be an issue for you, especially if you install an essential bus that does not require a made contactor to provide power to your ignition system).
2. Once latched they are closed unless they are positively unlatched and so any failure in the wiring etc will not cause them to unlatch, but see comment above ref the use of an essential bus.
Contactors are very simple devices and have proved extremely reliable in practice. One of the principle benefits of a simple battery contactor is its function as your last port of call isolation device for your main electrical systems. If you have a fault either with a stuck starter on the the ground or perhaps an electrical fault in the air that causes smoke in the cockpit your ultimate get out of jail card is to switch off the battery contactor, and in flight with an electrically dependent engine operate the essential bus depending on your electrical architecture. If the wiring fails to a latching relay at the same time as your fault you cannot release it but if the wiring fails to a battery contactor it will release under its own steam.
If I am sailing a boat, the issue is somewhat different. With a major fault and unable to release the latching relay I can normally gain access to the battery and release the positive terminal or if that isn't possible most boats I have sailed have battery isolation switches for all battery banks which would isolate the fault - both scenarios are not possible in an aircraft. So your fault isolation logic would seem to me to need to be different
Just food for thought.
Mark
Joined: 28 Mar 2008 Posts: 1967 Location: Riley TWP Michigan
Posted: Fri Mar 11, 2011 5:04 am Post subject: latching relays should fail safe |
A designer needs to ask, "if this part fails, how will I deal with it?" If a latching relay fails to open when commanded to, how will the electrical power be shut off? In case of a fire or imminent forced landing, the power needs to be shut off immediately.
What is safer, a master contactor that fails open or one that fails closed? The engine will keep running with a failed contactor. And the essential bus will keep powering critical equipment. Your marine friend might not realize that an airplane can keep flying with the master contactor off. Simpler is better.
Joe
_________________ Joe Gores |
Posted: Fri Mar 11, 2011 6:43 am Post subject: latching relays |
contactors?
A couple of List members have accurately captured the thought
processes unique to aircraft systems design. The
well considered failure modes effects analysis speaks
to Plan-B . . . mitigating the effects of any
particular failure. It also seeks to identify whether or
not the failure is passive (fail safe) or active (oh (at)#$(at)#!
how do I turn this thing off!).
I've considered the latching contactor often since
it was introduced to us on the List a few weeks back.
I've not yet discovered the right words and reasoning
one might apply to say, a design review at Hawker-Beechcraft
suggesting incorporation of the device onto one of their
airplanes.
Posted: Fri Mar 11, 2011 9:45 am Post subject: latching relays |
Mark, Joe, Bob,
Your wisdom is very much appreciated...thank you...I have much to learn.
Though I've been active on the matronics Europa-list, I've just joined
here and look forward to a time when I might have some wisdom to share
as well...til then, I fear I'll just be askin questions.
Fred
Posted: Fri Mar 11, 2011 3:34 pm Post subject: latching relays |
At 12:39 PM 3/11/2011, you wrote:
Mark, Joe, Bob,
Good . . . 'cause for sure, we can't build your
airplane for you. Here is where you'll find lots
of recipes for success and some help on sorting through
the options. What ever you decide to do will perform
as advertised. Questions are the place to start . . .
jan_de_jong(at)casema.nl Guest
Posted: Sun Mar 13, 2011 2:03 am Post subject: latching relays |
May I offer a thought in support of latching relays.
How likely is it that the fault that causes smoke in the cockpit
coincides with the failure of the relay to open?
Wouldn't they be generally independent failures?
I do agree that if you have plenty of amps it is hard to find a
compelling reason to use them.
On the other hand - Tyco must see a market for automotive power saving.
For the minimalist system with PM alternator I think the notion of using
latching relays can be played with.
Jan de Jong
Posted: Sun Mar 13, 2011 6:25 am Post subject: Master contactor reduced voltage holding |
Another option for using a conventional master contactor is to energize it at full voltage, then hold it at reduced voltage. I believe that Bob was working on a microprocessor based device that would do that. One could also make their own reduced voltage holding circuit using a resistor or diodes to drop the voltage along with a 3-position master switch: off, low voltage, and normal voltage.
Or how about this IC along with a Power MOSFET?
http://ww1.microchip.com/downloads/en/DeviceDoc/21448c.pdf
I was going to use this IC to control the elevator trim servo. I think it would also work with the master contactor. It applies full voltage for a timed interval, then puts out a PWM voltage, for a price of $1.38.
Joe
Posted: Sun Mar 13, 2011 7:56 am Post subject: latching relays |
Very low risk.
I suspect that 'power saving' is way down
on the list of design goals. Increased longevity
due to low values of internally generated heat
might be a big driver. The mechanically latched
device is not going to aggravate the effects of
a transient event. It wouldn't drop out and re-close
during a severe brown-out . . . and the folks who
brought these to market may not have considered
either . . .
using latching relays can be played with.
Absolutely. I should remind readers that my
background calls for sifting the sands of
risk for the purposes of keeping folks-who-know-
more-about-airplanes-than-we-do happy. I'm
not implying that regulatory mandates do not
mesh well with elegant solutions. But they DO
tend to discourage new solutions from emerging
and evolving.
Let's do our own sand-sifting.
JLuckey(at)pacbell.net Guest
Posted: Mon Mar 14, 2011 1:59 pm Post subject: latching relays |
Circuits like these do have their places but I don't think controlling the
coil of a master solenoid is one of them.
This sort of smells like a solution looking for a problem. Keep in mind
that when you place more components in the critical path, the reliability of
the system goes down - no matter how reliable those components are.
In the case of master solenoids, (as Bob & others point out) they have
proven to be pretty darn reliable. Therefore so I would be reluctant to
"over-engineer" a solution to a problem that doesn't exist.
Posted: Wed Mar 16, 2011 6:07 am Post subject: a non-critical component |
| Quote: | Circuits like these do have their places but I don't think controlling the coil of a master solenoid is one of them.
This sort of smells like a solution looking for a problem. Keep in mind that when you place more components in the critical path, the reliability of the system goes down - no matter how reliable those components are.
In the case of master solenoids, (as Bob & others point out) they have proven to be pretty darn reliable. Therefore so I would be reluctant to "over-engineer" a solution to a problem that doesn't exist. |
I agree with what you are saying except for the "critical path". There should always be a backup plan like an alternate feed path. A backup plan will turn a critical component into a non-critical one. I am not recommending reduced current to the master contactor for most installations. But it will be of benefit to systems that have limited generating power, or to prolong battery life when the alternator fails. A contactor coil operating at reduced voltage will generate less heat and thus be even more unlikely to fail.
Joe
Posted: Wed Mar 16, 2011 7:45 am Post subject: latching relays |
WARNING - STANDBY FOR LEVEL 4 NIT-PICKING. IF YOUR'RE NOT REALLY INTO THIS,
DO NOT WASTE YOUR TIME
I'm gonna provide MY definitions for some of the terms we are throwing
around (just 'cause it's a slow morning around here)
Let's talk about Critical Path (CP 'cause I'm a lazy typist) and Redundant
Circuitry (RC).
Critical Path:
The chain of components required to make a circuit operate as designed.
Example:
Circuit breaker -> switch -> contactor coil and the wiring that connects
them. All those things are in the CP because if any one fails, the circuit
stops working. [Let's add an LED in parallel w/ the coil (to give the
operator a visual indication) - I would say that the LED is not in the CP]
Every circuit has a CP. (regardless of other circuits that may be added for
redundancy)
If every circuit has a CP and adding components to the CP reduces
reliability, we can still increase reliability by adding a Redundant
Circuit. The RC still has its own CP, but the reliability of the SYSTEM
goes up.
I agree that reduced coil current may add to coil longevity but these
devices have proven to be so reliable that I don't think it's worth the
effort.
-Jeff
Posted: Wed Mar 16, 2011 7:00 pm Post subject: latching relays |
| Quote: | If every circuit has a CP and adding components to the CP reduces
goes up.
Generally speaking, the adjective "critical" is reserved
for conditions that have a potential for (1) single
points of failure in (2) systems needed for comfortable
termination of flight where (3) no effort has been
made craft a failure tolerant system. When failure
tolerance has been achieved, no single failure is
"critical". In little airplanes maintained by the
competent observer/owner/operator, probability
of two potentially critical failures in any single
flight cycle (typically 4 hours max) is vanishingly
small.
Once a degree of failure tolerance is achieved, the
system integrator can begin to massage cost/performance
and parts reduction issues.
The successful program starts with design goals.
Goals that add/upgrade performance features (A-N
versus VOR versus TACAN versus GPS). To reduce cost
(less expensive parts with perhaps shorter service
lives are attractive). No doubt there are other
goals.
When I was heavily involved in new products design
and certification at Electro-Mech, one could look
forward to a pretty steady stream of hopeful sales
folks with a new electro-whizzy to show off. Some
were really amazing advances of the state of the
art . . . and would be considered for a new design.
But the $time$ required to modify and old design
made it unlikely that anything new gets a field
retrofit. In 40+ years, I've only worked three
programs that produced a fleet wide change-out
of hardware and two of those were under safety of
flight duress.
Even when I could tell the bright-eyed salesman
that he had a really nifty product, I had to
remind him that we'd beat him up on price, delivery,
cert documentation, and maybe . . . just maybe
we'd bless him with an order for 1000 parts spread
out over 10 years. Of course, that order would
get perpetually modified/canceled as our line rates
moved up and down with the stock market.
Aviation is one of the most demanding customers
yet the numbers of airplanes built every year
makes them a ho-hum target for the electro-
whizzy guys. Now, if you're selling rivets
or aluminum . . .
Okay, you've got this nifty latching contactor. I think
it's fairly obvious how it might be used in our
airplanes. The questions to be asked and answered
are (1) does this product 'fix' some nuisance of
maintenance, costs or sense of less-than-elegant
functionality?
Since (repeat after me) we DESIGN, CRAFT AND MAINTAIN
FAILURE TOLERANT SYSTEMS, reliability and criticality
are not part of the considerations. Only cost of
ownership and reasonably seamless integration
into the-best-we-know-how-to-do-today are the go/no-go
drivers.
