gordona23(at)earthlink.ne Guest
Posted: Sat Feb 05, 2011 6:38 am Post subject: Trim servo wiring |
The 750 kit ships with two lengths of 5 conductor cable. One longer
than the other. Which one
connects to the elevator servo ? I can't find this anywhere in the
docs. Thanks.
| | - The Matronics Zenith750-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Zenith750-List |
Jimmy Young
Joined: 24 Nov 2007 Posts: 182 Location: Missouri City, TX
Posted: Tue Feb 08, 2011 8:24 am Post subject: Re: Trim servo wiring |
From what I recall, I hooked up the short one to the trim servo to run thru the HS to the fuse. I have the longer one running from the fuse tail to the cabin, using the bottom longeron as a chase. I put sections of 3/8" wire loom at the L angle/longeron junctions to protect the wire. I plan to install a Molex 5 pin connector at the fuse/HS connection to allow for easy disassembly of the tail section when I finally paint. Hope this helps.
_________________ Jimmy Young
Missouri City, TX
Kolb FS II/HKS 700 |
