robin(at)PaintTheWeb.com Guest
Posted: Tue Feb 22, 2011 1:51 pm Post subject: Replacement Prop Governor Suggestion |
Dear list,
We are very close to flying the 8A and have run our 400 TTSOH engine with new Hartzell BA Prop. Everything runs great with the exception of the Prop Governor direction. The unit came off a Lake Amphibian LA-4-200 with a different prop. Unfortunately it seems to work backwards, the engine smoothes out and rpm increases when you pull the lever back. We believe we have the wrong Gov and it is time for a replacement.
Here are the specifics:
Prop: New Hartzell, HC-C2YR-1BFP/F7497
Engine: IO-360-AIB 200 Hp
Hartzell Prop. Gov: The alum. tag is hard to read. Model F-6-5 **
Prior Aircraft: Lake LA-4-200 Ser. No. 465
My question; is there a preferred Prop Governor on the market for this prop & engine combination? I read on the Hartzell site the recommended Hartzell governor is the S-1-10. Any comments or recommendations?
Robin
RV-4 Sold
RV-6A Sold
RV-10 210 Hours
RV-8A Soon
** Model F-6-5 I'm sure about the "F" and the "6", pretty sure about the "5", it could have another digit after the 5, can't tell. Ser. no. -7310T, the dash could be an "A" or "?-"
| | - The Matronics RV7-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?RV7-List |
