hammerhead
Posted: Sat Jan 22, 2011 6:01 am Post subject: Prop not turning |
Hello all. I am a fairly new owner of a Yak-52 and I don't have much experience with the internals of it yet. This is my first winter season. My plan was to fly regularly during the winter so I haven't done anything to conserve the engine during the cold, below 0 C, winter we get here in Scandinavia. Anyway, since the cold weather arrived I just can't get the starter to turn the prop. With the air on I push the starter, but all I hear is a humming, hizzing noise. I have heard this noise before once when I forgot to turn the main air valve on. Nothing happens except for that sound. Does anybody have a suggestion as to what I could try or look for to get the starter to work? I will try leaving the heater on for more than a few hours the next time, but in the meantime it would be interesting to find out the steps that happens (or should happen) internally when the start button is pushed? I have looked at the schematics over the air system, but it is a static view that doesn't seem to help me right now.
Regards, Henrik
radiopicture
Posted: Sat Jan 22, 2011 6:21 am Post subject: Prop not turning |
Henrik:
First, I'm assuming the engine is pre-heated to above 5 degrees C (preferably more like 12), and you've pulled the prop through, etc.
The buzzing is the shower of sparks. If you're not getting a "pop" noise before the hissing, then the air valve isn't opening for some reason. If you're not clearing out the snot valve after each flight, the mixture of glycerine, oil blow-by and condensate can freeze things in the air system. If the plane can be warmed in a hangar, I think I'd try that first.
-Eric
On Jan 22, 2011, at 9:01 AM, hammerhead wrote:
Hello all. I am a fairly new owner of a Yak-52 and I don't have much experience with the internals of it yet. This is my first winter season. My plan was to fly regularly during the winter so I haven't done anything to conserve the engine during the cold, below 0 C, winter we get here in Scandinavia. Anyway, since the cold weather arrived I just can't get the starter to turn the prop. With the air on I push the starter, but all I hear is a humming, hizzing noise. I have heard this noise before once when I forgot to turn the main air valve on. Nothing happens except for that sound. Does anybody have a suggestion as to what I could try or look for to get the starter to work? I will try leaving the heater on for more than a few hours the next time, but in the meantime it would be interesting to find out the steps that happens (or should happen) internally when the start button is pushed? I have looked at the schematics over the air system, but it is a static view that doesn't s!
Regards, Henrik
http://forums.matronics.com/viewtopic.php?p=327870#327870
talew(at)bellsouth.net Guest
Posted: Sat Jan 22, 2011 7:04 am Post subject: Prop not turning |
Hi Henrik,
The very first thing You should check is the condition
of the batteries . The start valve needs a lot if current to open .
The spark vibrator is on the same circuit . This means you must
have good batteries for both of these to work properly at the same time .
Terry
pa3arw(at)euronet.nl Guest
Posted: Sat Jan 22, 2011 7:25 am Post subject: Prop not turning |
Henrik,
This is not a big problem. Assuming the following is ok:
Outside airtemp 5 degrees C or higher, otherwise I advise to pre warm the engine one way or the other.
Battery voltage is OK, i.e. 24v. If you push the button and you don’t see the control lights go out one may assume that that is OK.
Ait bottle filled at 45 bars min and air valve open.
If the things above are all OK I suggest the following:
Close the air valve.
Make sure electrical power is shut off and brakes are on.
Check both mag switches are OFF.
Now do the following:
Make sure nobody comes in the area of the propellor.
On the left side of the ruddercontrol, inside the cockpit against the fire wall, you will notice a valve.
This valve controls the air to the air distributor which makes the prop turn.
On the right side of the valve you will notice a small spoon like nipple.
Use a stick or something, or if you lucky and small enought you can touch it with you hands, to move this little spoon up and down.
This will manually activate the air to the airdistributor, that is why you have to make sure there is nobody in the prop area, beause the prop will turn,just a little, but it will turn.
If it has done that, start the engine with the normal procedure.
Sometimes, when it is cold, it may happen that this valve gets a bit stuck.
Please do me favour: makes sure both mag switches and the power are switched of....otherwise...wll you know what may happen....
Let me know how it went.
Hans
RA3326K
Netherlands
------ Einde van doorgestuurd bericht
yakplt(at)yahoo.com Guest
Posted: Sat Jan 22, 2011 7:42 am Post subject: Prop not turning |
If you hear buzzing then you have a battery that is at least alive. Next time you try to start, look at your voltmeter/ammeter gage. When you push in the button it reads volts. Push the button in and read the voltage. It should be close to 24 volts. While holding the button in, hit the starter. If the voltage drops down to 19 volts or so, your batteries need charge, or replacment. If you replace them, always replace both at the same time, assuming you have already replaced the stock battery.
Next. I assume you have pulled the prop through a WHOLE bunch on a cold engine and that you have gotten every bit of oil out of it while doing so. If this has been done and the engine still does not rotate, then you are either not getting air or water is frozen in a line.
The electrical starter valve on a YAK 52 is ... as I remember it (I own a YAK-50 and not a 52) down by your left foot. Get your head down in there and find it. It will be a round cylinder about 6-8 inches long almost gold in color and it will have an air line hooked to the top and the bottom of it. Also an electrical cannon plug in the top or bottom third of it. FIND THIS. Now see if it has a small little metal tab/lever sticking out of it. This is the MANUAL LEVEL to actuate this valve.
Open your main air valve, make sure your main air pressure is 40-50 bars, and then clear the prop. Leave the mags OFF. Now push on this lever. If the prop suddenly starts turning, you have found your problem.
If the valve works manually but not electrically, you can try cleaning it by taking off the top air line and spraying WD-40 down in there to clean it out, but this is typically only a temp. fix. Better to replace it. Be aware that a CJ-6 uses the exact same valve. Not ALMOST the same, it uses the EXACT same valve. See Doug Sapp.
If THIS does not work... I.E. the engine still does not turn, now you really have a headache on your hands. Let's not go there. The first thing is to really get that airplane in a heated hangar and see if it will then work. If it STILL fails, then you need to start finding out why air is not getting to your starter distributor on the engine. This kind of detail is not necessary unless you really get to that point.
The most likely thing is that the starter valve is not opening. By using the manual lever on the side of it to manually open it, you will be able to prove that quickly.
Mark Bitterlich
--- On Sat, 1/22/11, hammerhead <henrik.andoff(at)had.se> wrote:
| Quote: | From: hammerhead <henrik.andoff(at)had.se>
Subject: Prop not turning
To: yak-list(at)matronics.com
Date: Saturday, January 22, 2011, 9:01 AM
"hammerhead" <henrik.andoff(at)had.se>
Regards, Henrik
Forum -
FAQ,
- MATRONICS WEB FORUMS -
List Contribution Web Site -
-Matt
Dralle, List Admin.
Posted: Sat Jan 22, 2011 9:02 am Post subject: Prop not turning |
Mark,
I have given him the same procedure....quite frankly I had exactly the same
problem yesterday when I wanted to fly my Yak52 even at +6 degrees C.
Hans
RA3326K
Op 22-01-11 16:33, Yak Pilot <yakplt(at)yahoo.com> schreef:
that quickly.
Mark Bitterlich
> Regards, Henrik
> Forum -
> FAQ,
> -Matt
> Dralle, List Admin.
Posted: Sat Jan 22, 2011 9:14 am Post subject: Prop not turning |
Henrik,
The problem is the air start valve in front of your left foot on the
back side of the firewall is sticking. You may try energizing the air
start valve manually with the small tab on the right side of the valve.
When you lift it, the air start valve is opened manually instead of
electrically as is done when you press the start button. The only way
to fix this problem is to remove the air start valve from the back side
of the firewall and either replace it or possibly clean out the junk
that has accumulated inside the plunger section.
Dennis
A. Dennis Savarese
334-285-6263
334-546-8182 (cell)
Skype: Yakguy1
www.yak-52.com
On 1/22/2011 8:01 AM, hammerhead wrote:
s!
Posted: Sat Jan 22, 2011 9:17 am Post subject: Prop not turning |
Eric,
You're correct about the buzzing. But the air start valve is hanging
up. Easy to figure out by moving the little tab on the side of the air
start valve to open the valve manually. Most likely this is the culprit
and happens frequently in cold weather due to the gunk inside the valve
the builds up over the years.
Dennis
A. Dennis Savarese
334-285-6263
334-546-8182 (cell)
Skype: Yakguy1
www.yak-52.com
On 1/22/2011 8:18 AM, Eric Wobschall wrote:
Henrik:
-Eric
t!
Posted: Sat Jan 22, 2011 10:21 am Post subject: Prop not turning |
Hans, I wrote mine before I read yours.
The actual starter valve probably has just a small amount of moisture in it that froze.
Mark
--- On Sat, 1/22/11, Hans Oortman <pa3arw(at)euronet.nl> wrote:
| Quote: | From: Hans Oortman <pa3arw(at)euronet.nl>
Subject: Re: Prop not turning
Date: Saturday, January 22, 2011, 12:00 PM
Mark,
exactly the same
degrees C.
Hans
RA3326K
the starter. If the
need charge, or
problem.
> that quickly.
> Mark Bitterlich
I don't
This is
regularly during
the engine
arrived I just
air on I
hizzing
forgot to
for that
could try
leaving
time, but
out the
when the
schematics over
doesn't s!
>> Regards, Henrik
>> Forum -
>> FAQ,
>> -Matt
>> Dralle, List Admin.
Forum -
FAQ,
-Matt
Dralle, List Admin.
radiopicture
Posted: Sat Jan 22, 2011 1:10 pm Post subject: Prop not turning |
Or it's frozen, right, Dennis?
On Jan 22, 2011, at 12:12 PM, A. Dennis Savarese wrote:
Henrik,
The problem is the air start valve in front of your left foot on the back side of the firewall is sticking. You may try energizing the air start valve manually with the small tab on the right side of the valve. When you lift it, the air start valve is opened manually instead of electrically as is done when you press the start button. The only way to fix this problem is to remove the air start valve from the back side of the firewall and either replace it or possibly clean out the junk that has accumulated inside the plunger section.
Dennis
A. Dennis Savarese
334-285-6263
334-546-8182 (cell)
Skype: Yakguy1
www.yak-52.com
s!
> Regards, Henrik
radiopicture
Posted: Sat Jan 22, 2011 1:11 pm Post subject: Prop not turning |
Ah... makes sense.
On Jan 22, 2011, at 12:14 PM, A. Dennis Savarese wrote:
Eric,
You're correct about the buzzing. But the air start valve is hanging up. Easy to figure out by moving the little tab on the side of the air start valve to open the valve manually. Most likely this is the culprit and happens frequently in cold weather due to the gunk inside the valve the builds up over the years.
Dennis
A. Dennis Savarese
334-285-6263
334-546-8182 (cell)
Skype: Yakguy1
www.yak-52.com
> Henrik:
> -Eric
t!
> s!
>> Regards, Henrik
hammerhead
hammerhead
Posted: Sun Jan 23, 2011 3:22 am Post subject: Re: Prop not turning |
By the way, Eric is mentioning a "snot valve". Where is this located, and how should it be operated?
| radiopicture wrote: | Henrik:
-Eric
radiopicture
Posted: Sun Jan 23, 2011 5:14 am Post subject: Prop not turning |
That is a knob on a small cylindrical apparatus on the firewall, low and on the right side. Opening that valve after each flight reduces the build-up of water, oil, etc. in the air system. I'm guessing if that isn't being blown off, that residue could be what's freezing in your starter valve. However, there have been many other suggestions in here by guys who would know since I made that remark. Just another thing to check.
Posted: Sun Jan 23, 2011 10:17 am Post subject: Prop not turning |
On the left side of the firewall above the bottom engine mount when standing
in front of the left wing root. Reach in the left side of the cowl. On the
52, it is just above the base of the engine mount. It has a scalloped knob
on the left side of the snot valve. Rotating it counter clockwise opens it
draining the condensation from the previous flight so that it is not
injected into your air system when you start up the next time.
Doc
hammerhead
Posted: Tue Feb 01, 2011 5:06 am Post subject: Prop not turning |
The air start valve is located directly in front of the left rudder
pedal on the back side of the firewall. It's the vertical unit with the
small tab on the side and an electrical connector on the top. I've
attached a photo of it.
Dennis
GeorgeCoy
Posted: Tue Feb 01, 2011 6:42 am Post subject: Prop not turning |
Some of the air start valves do not have the manual activation tab.
George Coy
Posted: Tue Feb 01, 2011 6:55 am Post subject: Prop not turning |
You're right George. I forgot about that.
Dennis
George Coy
jan.mevis(at)informavia.b Guest
Posted: Tue Feb 01, 2011 7:06 am Post subject: Prop not turning |
The original air start valve on my 50 did not have a manual tab. Would be
useless on a 50 anyway.
Jan
[quote] --
