Basic Fluting Question
william(at)gbta.net
PostPosted: Thu Jan 13, 2011 2:05 pm    Post subject: Basic Fluting Question Reply with quote
Hey everyone. I'm having an issue with fluting some ribs. Some of my ribs have a "spring" or twist to them caused by stamping them out (I assume). I cannot seem to get the "spring" out of the ribs by fluting them--no matter what I try. If I apply light pressure to the rib while on a table they lie flat but the instant I let go they spring right back so they are twisted. Am I doing something wrong??? My fluting does get the rivet holes lined up good when the ribs lie flat on the table. I've had a few in the past like this that I just installed and the clecoes very easily pull the rib into place. Is this acceptable? If not, how do I correct. I've attached a few pictures to better describe my issue.
Thanks in advance,
Bill (Feels like I'm going backwards) Britton
 Filesize:  296.62 KB
 Viewed:  3822 Time(s)
 Filesize:  288.14 KB
jcumins(at)jcis.net
PostPosted: Thu Jan 13, 2011 2:37 pm    Post subject: Basic Fluting Question Reply with quote
Bill
We are in about the same spot in construction. What I did was use a straight edge down the ribs and fluted to make the rib straight and not curved like they are coming from Vans. The twist issue I do not think you can fix, but the curve can be fluted away.
Good luck.
John
40864 Wings Wanting good weather so I can primer more parts.
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Billy & Tami Britton
Sent: Thursday, January 13, 2011 1:06 PM
Subject: Basic Fluting Question
Thanks in advance,
Tim Olson
PostPosted: Thu Jan 13, 2011 2:42 pm    Post subject: Basic Fluting Question Reply with quote
If they stand up that much, I'd flute them and make them flatter.
I'm sure it could be fine if you installed them, but really,
the idea is to get that stress out of them and make them flat.
There is a technique to it, and it's easier to do or show
than speak, but once you get the hang of it, you'll have it
down. It's been a LOOONG time, but I think that the one you
have the picture of in this email probably is over-fluted,
and that's why it's bowed up. If you flute less, the length
of the bottom edge would be longer, and it would tend to
make it flatter. Picture it as a bar that you want to bend,
and if you flute one side, it bends that way. Well, you
fluted the side facing down, and when you got to a certain
point, the thing bent in a curve facing that direction.
So I'd relax the flutes and see what happens.
You'll get the hang of it.
Tim
Tim Olson - RV-10 N104CD
Thanks in advance,
rv6(at)att.net
PostPosted: Thu Jan 13, 2011 6:40 pm    Post subject: Basic Fluting Question Reply with quote
With some work, they will lay fairly flat. I prefer pliers like in the
attached file that makes a thinner flute. Pliers with wide flutes didn't
work well for me. Lay the rib on a flat surface with the rib flanges
pointing up. I pick the side of the rib that doesn't want to lie down and I
very lightly flute that section starting in the middle working back and
forth to each end of rib. Press down slightly on the web as you do this. It
should start laying down. I also work the ribs by hand by bending and
twisting a little. Once the rib lays as flat as you feel it's going to, the
flanges are checked to make sure they are close to 90 degrees to the web so
the skin fits flush to the flange.
Just watch how the rib reacts to fluting and flute lightly. Some flutes
will need additional fluting. Some flutes may be fluted too much and seamer
pliers (see attached file) can be used to squeeze out some of the fluting.
Once you get the hang of it, it gets easier.
Jerry Calvert
RV6
N296JC
Thanks in advance,
 Filesize:  13.37 KB
 Viewed:  3813 Time(s)
 Filesize:  14.85 KB
Mauledriver(at)nc.rr.com
PostPosted: Fri Jan 14, 2011 8:48 am    Post subject: Basic Fluting Question Reply with quote
First, I just want to say that when I first managed to flute the ribs on
the elevator counterweight ribs, I felt like a sheet metal Jedi
Master. Getting them to lie flat was very cool.
However, later I found that my 2 elevator ribs were not exactly aligned
with each other. That is, when I lined up my elevator trailing edges,
the counterweight extensions weren't quite aligned. And vice-a-versa.
It was one of the few places that CNC drilled holes didn't bring things
into perfect alignment. Must have been that master fluting job.
Actually, I don't know what happened. It's not enough to worry about in
my opinion but I found it frustrating. Can't imagine that the fluting
of the wing ribs would possibly be as critical. Hang in there though.
I used 2 different fluting pliers and found that both had utility though
I'm sure the job can be done with 1.
No advice, just reflection...
Bill Watson
Tim
> Thanks in advance,
rv10flyer
PostPosted: Fri Jan 14, 2011 8:57 pm    Post subject: Re: Basic Fluting Question Reply with quote
I found lining up a flexible 24" steel rule with the hole edges to work the best. The edge distance always varies due to the holes being punched then the rib forming. By lying them on a table you may get a straight sheetmetal edge but not a straight set of holes. The pre-punched skin holes are in a straight line so you want to have the holes in the ribs in a straight line not the edge of the metal flange. I just did a little at a time and if I overdid it just went back and took some out. After a few ribs you know just how much force to use and where.
Wayne G.
