rleffler
Posted: Wed Jan 12, 2011 7:37 pm Post subject: Mounting Main Wheel Question |
In starting to mount my main wheels this evening, it became quickly apparent
that there was an issue with the cotter pin and the tire valve. There is
almost no clearance between the valve cover and the axel nut.
A side note, I really like the extensions that Tim had made for the
community. Although I've had them for a while, I am extremely appreciative
of what Tim did for the community and probably can't express my thanks often
enough.
Back on topic, I was curious as to how others dealt with this. I could
crimp the end a little tighter so that the pin sits a little lower. Another
option would be to bend the top over to be more flat on top of the nut. I'm
not sure how AC43.13 handle the lack of clearance issue.
Comments?
bob
 Download |
| Filename: |
winmail.dat |
34.45 KB |
| Downloaded: |
535 Time(s) |
_________________ Bob Leffler
N410BL - Phase I
Posted: Wed Jan 12, 2011 7:56 pm Post subject: Mounting Main Wheel Question |
Hence the Matco solution. Basically Vans will tell you to remove the valve
cover and it will be fine, that is what they did with the demo plane.
I ended up paying $60 and sent my wheels back to Matco , they sent me the
correct setup that allows the clearance you need. If it was untouched MAtco
was replacing the wheels for $20.
Kelly McMullen
Posted: Wed Jan 12, 2011 8:26 pm Post subject: Mounting Main Wheel Question |
I think you are talking about the nose wheel and Bob is talking about the mains. Not sure it is the same issue.
On Wed, Jan 12, 2011 at 8:54 PM, Pascal <rv10builder(at)verizon.net (rv10builder(at)verizon.net)> wrote:
[quote]--> RV10-List message posted by: "Pascal" <rv10builder(at)verizon.net (rv10builder(at)verizon.net)>
Hence the Matco solution. Basically Vans will tell you to remove the valve cover and it will be fine, that is what they did with the demo plane.
I ended up paying $60 and sent my wheels back to Matco , they sent me the correct setup that allows the clearance you need. If it was untouched MAtco was replacing the wheels for $20.
A&P/IA, EAA Tech Counselor
KCHD |
Tim Olson
Posted: Wed Jan 12, 2011 8:47 pm Post subject: Mounting Main Wheel Question |
I think he's talking a different problem...the mains. I haven't had a big issue with the mains. I got some big cotter pins that don't stick out a lot of excess and when I bend the ears over it clears fine. Sure, it's close sometimes, but it always clears. You want to buy 100 of the right size cotter pins, because you throw them away every tire dismount. I think if I remember right, my original ones were slightly longer and I snipped the tips. The ones I use now are just about perfect. They are a pain to install, cuz you have to arch them a little as you install them, and then straighten them out to get them through the far hole. My worry has been that if the ears rotate, they could scrape the seal cover ring but that's not happened so far.
So unless you have a different clearance than me, Bob, I think it should be workable. Thanks for the comment on the extensions....haven't heard of any breaking and there are over 160 sets out there so we must be at least doing better than stock.
Posted: Wed Jan 12, 2011 9:01 pm Post subject: Mounting Main Wheel Question |
good point! It is a different issue
forget Matco solution, but “Basically Vans will tell you to remove the valve cover and it will be fine, that is what they did with the demo plane.” stays.
I did go out and looked and there is minimal clearance, but should not be an issue, especially if the valve cover is removed.
Sent: Wednesday, January 12, 2011 8:21 PM
Subject: Re: Mounting Main Wheel Question
rleffler
Posted: Thu Jan 13, 2011 3:05 am Post subject: Mounting Main Wheel Question |
Tim hit the nail on the head.
Tim do you recall the part number of the pin that worked better for you?
Thanks!
N410BL - Phase I
dlm34077(at)q.com Guest
Posted: Thu Jan 13, 2011 6:10 am Post subject: Mounting Main Wheel Question |
The 10 needs the Matco axle. Those stainless sleeves eventualy turn and score the fork. You might as well get the full matco solution when you change the axle. I saw a 10 in Phoenix which some A&P had returned to service where the nose wheel wobbled 15 degrees each side of vertical.
rleffler
gengrumpy(at)aol.com Guest
Posted: Thu Jan 13, 2011 6:36 am Post subject: Mounting Main Wheel Question |
I changed tubes to the 90 degree stems, much easier to fill and no
conflict with the nut or axle.
grumpy
On Jan 12, 2011, at 9:31 PM, Bob Leffler wrote:
apparent
There is
appreciative
thanks often
enough.
could
Another
nut. I'm
Comments?
bob
Tim Olson
Posted: Thu Jan 13, 2011 6:54 am Post subject: Mounting Main Wheel Question |
I can't find reliable info in my old pile of stuff. I'll
have to try to find out when I am at the hangar and actually
doing the job again. I'm confused more now because I know
I've bought over 600 of the -362's...maybe when we did
the extensions?
MS24665-362 1/8" x 2-1/2
But when I read the plans, I see that Van's specs these:
MS24665-360 1/8" x 2
..which are actually shorter. So maybe they fixed the p/n
already? or maybe it was just me.
Either way, just install what you have and know the p/n, and
measure it, and then see if it needs shorter and if so,
order a few to try, and if they work better, order a pile.
Wish I had better for-sure info....so don't trust the above
too much.
Tim Olson - RV-10 N104CD
Thanks!
