No Title
tinnemaha(at)hotmail.com
PostPosted: Wed Jan 11, 2006 6:49 am    Post subject: No Title Reply with quote
Bob & list,
Thank You all for the many helpful suggestions. I feel sorta silly not to
have thought of some of them myself, so thanks for your patience &
willingness to point out what may seem obvious to you.
As for installing the radials, one to the front will be easy & off to one
side will be short (maybe 2.5 inches) but there is no room to the other side
or back, at least if I want to stay in the same 'plane' as the base of the
antenna, which I believe is important. Is there a way to incorporate the
'silver spray' portion of the polyfiber finishing system into the antenna?
The 'silver spray' is basically a thin sheet of aluminum used to protect the
fabric from UV rays.
Thanks again for all the help. This list is a GREAT resource.
