Frankd
Posted: Sat Jan 08, 2011 8:29 pm Post subject: Kolb/Jabiru carb overflow |
Hi guys,
looking for suggestions here about the 94/40 Bing Carb on the Jabiru 2200 engine.
I have started my engine but am getting fuel overflow at idle. I switched out the float needle valve as recommended with the black tipped one and cleaned out everything I could around the needle valve area.
It still overflows at idle.
Any ideas on how to fix this and what the issue may be?
My thoughts are:- a/ the floats are getting stuck somehow in the bowl.
b/ The needle valve seat still has some microscopic fibers or something I can't see.
c/ There is a blockage of vents causing an air pocket and the floats are not fully lifting (one would think the overflow vent would stop this)
Any ideas and suggestions for a fix are welcome
Frankd
M3X
rickofudall
Posted: Sat Jan 08, 2011 9:21 pm Post subject: Kolb/Jabiru carb overflow |
Frank, have you checked to make sure the float arm is parallel to the base of the carburetor body when the needle valve is seated? If it is past parallel, i.e. the ends of the arms are closer to the body than the pivot the fuel level will be too high and let fuel overflow. Have you checked the fuel pressure?
Are you running a boost pump? Is it the correct model that limits fuel pressure to less than 4 psi? Assuming you have a boost pump, remove the float bowl and see if you can shut off the fuel flow by pushing lightly on the needle, then try the same by pushing on the float arms you could have something keeping the float arms from swinging freely.
I looked at the picture of the pink tipped needle that you posted and it appears by the marks on it that it is seated properly, but all it takes is one imperfection to make it leak. Get a magnifying glass and look the brass seat over carefully. If in doubt replace it.
Rick Girard
On Sat, Jan 8, 2011 at 10:29 PM, Frankd <frankd(at)foundrynet.com (frankd(at)foundrynet.com)> wrote:
| Quote: | --> Kolb-List message posted by: "Frankd" <frankd(at)foundrynet.com (frankd(at)foundrynet.com)>
Hi guys,
I have started my engine but am getting fuel overflow at idle. I switched out the float needle valve as recommended with the black |
| Quote: | tipped one and cleaned out everything I could around the needle valve area.
Frankd
M3X
http://forums.matronics.com/viewtopic.php?p=326078#326078
le, List Admin.
Zulu Delta
Kolb Mk IIIC
582 Gray head
4.00 C gearbox
3 blade WD
Thanks, Homer GBYM
It is not bigotry to be certain we are right; but it is bigotry to be unable to imagine how we might possibly have gone wrong.
- G.K. Chesterton
Thom Riddle
Posted: Sun Jan 09, 2011 5:33 am Post subject: Re: Kolb/Jabiru carb overflow |
Rick's recommendations are good ones and hitting on the most probable causes. However, the Jabiru installation manual states that the acceptable maximum fuel pressure is only 3 psi.
From Jabiru Installation manual:
4.4 Pressure to Carburettor (above ambient)
• Maximum 20 kPa (3 psi)
• Minimum 5 kPa (0.75 psi)
and
11.3 Mechanical Fuel Pump
The mechanical fuel pump is mounted on the engine crankcase and is camshaft driven. It is
designed to supply fuel at the pressure described in the following paragraph. If fitted, the
electrical boost pump must also fulfill the fuel input criteria for the carburettor, given below.
11.4 Carburettor
A Bing constant depression type 94/40 is used. This carburettor has a minimum delivery
pressure of 5 kPa (0.75 Psi) and a maximum pressure of 20 kPa (3 psi). To confirm that the
fuel system is capable of delivering this pressure a fuel flow test must be performed.
To check pressure, insert a ‘T’ piece between the mechanical pump and the carby.
Test boost pump with engine off, then mechanical fuel pump with engine on, then
combine with electrical boost pump as well, before first flight.
A method for performing a fuel flow test is available from Jabiru if required. A drip deflector
to deflect overflowing fuel from the exhaust system is supplied as standard equipment on the
engine.
_________________ Thom Riddle
Buffalo, NY (9G0)
- Anonymous |
Roger Lee
Posted: Sun Jan 09, 2011 6:43 am Post subject: Re: Kolb/Jabiru carb overflow |
Fuel venting causes:
1. float arms not adjusted properly. Fuel level to high in the bowl. (number
one cause and an easy fix)
2. rough running engine or poor engine mounts causing the engine to shake
so the floats can't properly control the level.
3. boost pump in series and running all the time and has too much fuel
pressure to the carb. (not always a problem, but needs to be ruled out)
4. carb not mounted straight. Tilted to one side or the other too much.
5. debris around the carb needle and not effectively controlling fuel flow.
Go after number 1 first and make sure your carb is not tilted.
_________________ Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Cell 520-349-7056 |
Dana
Posted: Sun Jan 09, 2011 6:45 am Post subject: Kolb/Jabiru carb overflow |
At 12:18 AM 1/9/2011, Richard Girard wrote:
| Quote: | | ...but all it takes is one imperfection to make it leak. Get a magnifying glass and look the brass seat over carefully. If in doubt replace it. |
How often should one replace the float needle/seat? Or put another way, how often do they fail?
Not the same engine or carb, (mine is a Cuyuna with Mikuni carb), but I had what appears to be the same thing, engine flooding while running, after it had been running fine all year. Happened once before, a few years back, and although the needle/seat didn't look bad then, I replaced it and the problem didn't happen again (until now). This time it almost put me down in a farm field. I haven't taken the carb apart yet,but I've ordered a Viton tipped needle (the old one was steel).
-Dana
Society is like a stew. If you don't keep it stirred up, you get a lot of scum on top.
Frankd
Posted: Sun Jan 09, 2011 8:56 am Post subject: Re: Kolb/Jabiru carb overflow |
Hi guys,
thanks for the suggestions.
I do have an electric pump mounted at the bottom level of the tanks and it is a Facet (P/N4015) 4.5Max PSI , but I did not have it on while I get this condition. I now see that Aircraft spruce have a lower PSI pump (!).
I have checked that the carb is not tilting side to side and one thing that came to mind is that it does tilt front to back due to the angle of the whole airframe so I can adjust the floats to close sooner. The overflow holes are towards the rear of the bowl.
Engine Vibration appears normal, actually quite smooth so this is not a concern.
I will double check the fuel pressure from the mechanical pump if adjusting the floats to close sooner does not work. I will also test both pumps operating in sequence to see if this causes a problem.
Replacing the brass insert is on the list if none of the above works.
Lots to do, thanks again for the pointers.
FrankD
Soon to be fixed M3X
Posted: Sun Jan 09, 2011 9:33 am Post subject: Kolb/Jabiru carb overflow |
FrankD
Frank D/Folks:
Correct float bowl level is critical to proper carb operation, as is the
fuel float bowl static port and the static port in the intake lip of the
carb.
Float level to high, engine runs rich. Float level to low, engine runs
lean. Set the level per your engine manufacturer's specs.
Correct length and location of the float bowl chamber static port tubing is
also very important. The engine manufacturer or Bing should be able to
provide that information.
That little port and tube are not vents, but static ports. The front and
float bowl chamber static ports should read the same static pressure in
order to operate correctly.
The configuration of the Bing carbs on the 912 series engines, the way they
are delivered new is the correct set up, per the Rotax folks. However, I
discovered that configuration of accessories and location can affect airflow
and the proper static pressure. To preclude this I run my float bowl
chamber static port tube to the inside of my carb air filter covers. This
has proven to work well on my airplane.
What works for N101AB, may not work for you.
Titus, Alabama - Already up to 30F from a low of 24 last night. Forecast is
snow and cold for the next week. Ugh!!!
_________________ John Hauck
Titus, Alabama |
zeprep251(at)aol.com Guest
Posted: Sun Jan 09, 2011 2:13 pm Post subject: Kolb/Jabiru carb overflow |
Frank,
I had this issue as well.it would happen occasionally,and I dropped the bowl removed the needle and flushed the seat using the aux pump.It would be OK for a while ,then flood again,even after the new needle.When it happened, I could shut off the fuel run the engine till it leaned out which let the float drop and the needle pull off the seat, then open the fuel valve and it flushed the trash off the needle and seat and it would run fine for a few days.Some microscopic fuzz can do it.
Starting at the tanks,new paper element filter,new lines all the way through the gascolater,aux pump to the engine driven pump and to the carb, which IS tilted 20 degrees to even up the exhaust temps.No more problems even idle all the time.
G.Aman MK-3C Jabiru 2200a 600hrs
ces308
Joined: 03 Nov 2008 Posts: 317 Location: houghton lake ,mi
Posted: Sun Jan 09, 2011 3:00 pm Post subject: Re: Kolb/Jabiru carb overflow |
Hi Jabbers..
As you all know I had the problem with the float needle too and after replacing the needle had the same problem...after 3 successful forced landings in 3 weeks,we finally fixed it today...I'm not so sure it was even the float needle to start with...today I got a fuel pressure reading and it was putting out 7 lbs of pressure ! Disconnected the mechanical pump and ran it on the electric pump that was putting out 2-3.2 lbs and it ran perfect ! I removed the mechanical pump,placed an extra .030 gasket between the pump and the engine and the fuel pressure went from 7 lbs to 3.2 and stayed right there and ran great...
Why it started pumping so much more gas I have no idea...
chris ambrose
M3X/jabiru A-2200
N327CS
Thom Riddle
Posted: Mon Jan 10, 2011 5:57 am Post subject: Re: Kolb/Jabiru carb overflow |
Chris,
Very glad to hear you found the actual problem. It IS a mystery as to why it changed over time.
A couple questions:
1- Had you done any fuel pump maintenance before this happened? What is the total gasket thickness now?
2- Are your electric and mechanical fuel pumps in series or parallel?
3- Do you normally run the electric during all phases of flight?
FWIW, my electric pump is plumbed in parallel with the mechanical and I use the electric to fill the float bowl before starting and during approach and take-off. I know the Facet is a 100% duty cycle pump which could be run full time but it is an old habit of mine not to use it except as stated.
Also, I've never removed my fuel pump so don't know how much gasket is there and I don't have a fuel pressure gage installed so don't know what it is producing. I think I'll ckeck it out during next condition inspection.
Buffalo, NY (9G0)
- Anonymous |
ces308
Posted: Mon Jan 10, 2011 12:12 pm Post subject: Re: Kolb/Jabiru carb overflow |
Ok...Chapter 14....I thought I had the problem solved ,then I flew it today...stayed over the airport for about 10 minutes and it seemed to run fine...headed out over the lake,throttled down to loose some altitude and it started all over again...I headed back to the airport and it sounded like it was going to quit again...I kept the throttle wide open and luckily it started to clear out and kept running....land ... Called Pete at Jabiru ,told him about spacing the pump out .030 and it seemed to be ok....his thought now was the spring in the pump needed replacing...I removed the spring...took about 7/16 off the spring put it back on the plane with a fuel pressure Gage and at idle I had 1.7 and it went to almost 3lbs wide open....when I GET THE NEW SPRING ,i WILL PUT IT IN AND TAKE ANOTHER pressure reading....
stay tuned...
chris ambrose
M3X/jabiru
N327CS
ces308
Posted: Mon Jan 10, 2011 2:15 pm Post subject: Re: Kolb/Jabiru carb overflow |
OK..
Our theory on the spring is this....as the spring gets rusty from condensation it gets more brittle and harder thusly,making more pressure as it pushes the fuel into the carb...cutting it off,making it shorter also made the spring weaker and reducing the pressure...you think ???When I get the new spring ,I am going to rust proof it just for the heck of it then re-install it and take another pressure reading....
chris ambrose
by0ung(at)brigham.net Guest
Posted: Mon Jan 10, 2011 2:16 pm Post subject: Kolb/Jabiru carb overflow |
Ok...Chapter 14....I thought I had the problem solved ,then I flew it today...stayed over the airport for about 10 minutes and it seemed to run fine...headed out over the lake,throttled down to loose some altitude and it started all over again...I headed back to the airport and it sounded like it was going to quit again...I kept the throttle wide open and luckily it started to clear out and kept running....land ... Called Pete at Jabiru ,told him about spacing the pump out .030 and it seemed to be ok....his thought now was the spring in the pump needed replacing...I removed the spring...took about 7/16 off the spring put it back on the plane with a fuel pressure Gage and at idle I had 1.7 and it went to almost 3lbs wide open....when I GET THE NEW SPRING ,I WILL PUT IT IN AND TAKE ANOTHER pressure reading....
stay tuned...
chris ambrose
seems that springs loose tension after time.... I am puzzled on how you would get an increase of pressure.... is there any chance at a reduced power setting there is a vibration that is putting enough bubbles in the float bowl that the float wont sense the correct level?
boyd young
mkiii
rmurrill(at)cox.net Guest
Posted: Mon Jan 10, 2011 2:55 pm Post subject: Kolb/Jabiru carb overflow |
Contrary view...Wow there are thousands of those engines in service, lots with very high hours, and yours is the first to suffer "rusty fuel pump spring hardness"? I am unaware of the metallurgy that leads to increased elastic modulus from rusted steel surface damage. Maybe something hangs up on the spring movement or a diaphragm movement......I think I would look again for maybe a vacuum or vent leak in the induction systems that develops with temperature differential.
Best of luck..
Bob
---- ces308 <ces308(at)ldaco.com> wrote:
OK..
chris ambrose
http://forums.matronics.com/viewtopic.php?p=326355#326355
racerjerry
Joined: 15 Dec 2009 Posts: 202 Location: Deer Park, NY
Posted: Wed Jan 12, 2011 2:52 am Post subject: Re: Kolb/Jabiru carb overflow |
All the thoughts expressed here are right on target, but don’t forget the common simple/basic cause of carb flooding which is HEAVY FLOAT. With metal floats - a leak/pinhole or with composite floats - soggy/porous.
_________________ Jerry King |
ces308
Posted: Wed Jan 12, 2011 5:18 pm Post subject: Re: Kolb/Jabiru carb overflow |
Hi Jabbernuts !
Did anyone here know there are 2 different springs?? The silver one is the one we are supposed to have ..it puts out 2-3 lbs....the gold spring puts out 7 lbs....and some of the engines "got out" with the gold springs.....Imagine that.....Mine was to rusted to see what color ( seee picture) even after we cleaned it up...
chris ambrose
M3X/Jabiru
N327cs
ces308
Posted: Wed Jan 12, 2011 5:21 pm Post subject: Re: Kolb/Jabiru carb overflow |
sorry...forgot the pictures...
chris ambrose
46.88 KB |
51356 Time(s) |
50.71 KB |
51356 Time(s) |
58.31 KB |
51356 Time(s) |
Posted: Wed Jan 12, 2011 5:39 pm Post subject: Kolb/Jabiru carb overflow |
Chris- looks like condensation from somewhere.
Bill Sullivan
Windsor Locks, Ct.
FS 447
--- On Wed, 1/12/11, ces308 <ces308(at)ldaco.com> wrote:
Posted: Wed Jan 12, 2011 6:09 pm Post subject: Kolb/Jabiru carb overflow |
Wow..."got out"....we used to call that an "escapement " in the DoD universe. Sounds like you are very close to getting back to a highly reliable powerplant!
Hi Jabbernuts !
chris ambrose
M3X/Jabiru
N327cs
http://forums.matronics.com/viewtopic.php?p=326776#326776
ces308
Posted: Wed Jan 12, 2011 8:42 pm Post subject: Re: Kolb/Jabiru carb overflow |
"Wow..."got out"....we used to call that an "escapement " in the DoD universe. Sounds like you are very close to getting back to a highly reliable powerplant! "
This really has been a very reliable engine and other than this,I could be happier with this engine ! It should be all better next week....then look out for the new videos !!! lol
chris ambrose
M3X/jabiru A-2200
N327CS
87.62 KB |
51333 Time(s) |
