coop85(at)verizon.net Guest
Posted: Sat Jan 08, 2011 2:04 pm Post subject: Engine heater |
As winter has been well established this year already, I'm once again in the
mood for an engine heater. I had planned on ordering the one from Van's
when I thought to do a Google search. Here's something that came up and I'm
struggling for a reason not to go for it:
http://www.amazon.com/Kats-24150-Watt-Universal-Heater/dp/B000I8TQD6/ref=pd_
sim_auto_2
It appears to be thermostatically controlled and attaches to the oil sump
like the $178 version but at only $22. Any points to consider would be
appreciated.
Marcus
40286
n223rv(at)wolflakeairport Guest
Posted: Sat Jan 08, 2011 2:56 pm Post subject: Engine heater |
I don't think you will find a 4"x5" spot on your sump. I had a hard time fitting on the 2 Reiff pads and they were like 1.5"x3 or so each.. The Reiff also has the cylinder bands, which is really nice...
On Jan 8, 2011, at 5:02 PM, "Marcus Cooper" <coop85(at)verizon.net> wrote:
sim_auto_2
appreciated.
Marcus
40286
Tim Olson
Posted: Sat Jan 08, 2011 3:56 pm Post subject: Engine heater |
I'm using the Reiff Preheater:
http://www.reiffpreheat.com/
It's been very nice to have over the years. This winter I hope to
add the oil cooler heater also. I have cylinder band heaters
for each cylinder, and a sump heater right now. Generally, even
if it's below zero outside, my cylinders will be in the high
60's, and the warmer it is outside the warmer the engine will
be. Most of the time when I fly in the winter, the temps are
between the 70's and 90F. I actually hit 100F (which is where
I normally warm up to before takeoff) faster in the fall/winter/
spring, than I do in the summer, because of the preheat.
With the cowl plugs from Fightline, the whole engine generally
stays pretty warm. The oil cooler out on the firewall doesn't
probably get as warm, so that's why I want to add a heater
for that. See this:
http://www.reiffpreheat.com/Oil%20cooler%20heater.htm
I know you can heat just a sump, or heat with a lightbulb
under the cowl, but those I view as more of an occasional
workaround. If you really want to get it warmed up and ensure
that the engine gets pumping lube right away, you want to heat
the whole engine and get all the oil flowing well.
I've used Tanis brand heaters on my previous plane. Those worked
well too. I do like the cylinder band heaters from Reiff though.
Tim Olson - RV-10 N104CD
On 1/8/2011 4:02 PM, Marcus Cooper wrote:
sim_auto_2
appreciated.
Marcus
40286
kearney
Posted: Sat Jan 08, 2011 7:16 pm Post subject: Engine heater |
Marcus
I live where it gets quite nippy in winter - I have flow in in -30c weather.
About 10 years ago I installed on of these on my Piper Cherokee.
http://www.aircraftspruce.com/catalog/eppages/symtecpreheat.php
I give this a 5 star rating as it does a great job. I like the oil sump
heater as it heats the old and then the engine. When my EGT / CHT temps are
up, it means the who engine, including the core is heated. Heating the
cylinders first seems counter intuitive but may be wrong.
Any way, cheaper is not necessarily better. The nice thin about these
heaters is that they are elements in solid al epoxied to the sump. Not
silicone pads that might age.
Anyways, this just my opinion...
Cheers
Les
larkrv10(at)yahoo.ca Guest
Posted: Sat Jan 08, 2011 7:28 pm Post subject: Engine heater |
Marcus, looks very similar to the Reiff oil pan heater on our 360 Lycoming. Only difference is ours is only 100W. I say go for it.
Rick
#40956
Soutghampton, Ont
Sent: Sat, January 8, 2011 5:02:49 PM
Subject: Engine heater
--> RV10-List message posted by: "Marcus Cooper" <coop85(at)verizon.net (coop85(at)verizon.net)>
sim_auto_2
appreciated.
Ma - MATRONICS nbsp; -->
AirMike
Posted: Sun Jan 09, 2011 9:56 pm Post subject: Engine heater |
I put the Reiff - Vans pads on my IO540 this fall. Gets the oil to 60 degrees overnight which is fine for start-up (after a 10 degree night). The Vans pads are 2x50W. I notice that the one that you are looking at is 150W - Overkill? I also note that the budget pad has no ground plug. I figure that with a $40K engine what the heck is $170 for a tried and true certified product. I also figure that with the Reiff product that there is a some liability trail if the product is defective.
_________________ See you OSH '18
Q/B - sold. |
m.gabrielson(at)sbcglobal Guest
Posted: Mon Jan 10, 2011 5:09 am Post subject: Engine heater |
On our Dakota which had the O-540, we installed the Reiff Turbo XP. I think that was their highest wattage offering at the time (2004?). It had 100W on each cylinder and 200W on the oil sump. Pretty rapid warm up and if left on it held the oil at nearly 90dF according to the engine monitor w/ oil temp probe. That was hangared but without cowl plugs in. Probably overkill but the engine went beyond TBO in a flying club setting in the middle-midwest.
Matt Gabrielson
Sent: Sun, January 9, 2011 11:56:04 PM
Subject: Re: Engine heater
--> RV10-List message posted by: "AirMike" <Mikeabel(at)Pacbell.net (Mikeabel(at)Pacbell.net)>
See you OSH '11
Q/B - flying 1 yr+
Tim Olson
Posted: Tue Jan 18, 2011 9:01 pm Post subject: Engine heater |
A couple days ago I ran across a "letter to the editor" in Sport
Aviation (Dec. 2010, from the guy at Reiff Preheat systems.
I attached it in .jpg form for you. He makes a couple good
points about engine heating and about leaving them on all the
time. I know from people I've talked to over the years, I've
heard it various ways that you either can or can't leave
them on all the time. The letter referenced this FAQ of
Reiff's:
http://www.reiffpreheat.com/FAQ.htm#QA3
I've always just left mine plugged in, that FAQ also references
an Aviation consumer article that I have, where they tested
heaters and the dewpoint and temperature of the engines and
basically found that if you have a good heater that heats
nice and warm on the whole upper (cylinders) and lower (sump),
that you're not very likely to have the conditions that will
cause high moisture and rust in your engine if you leave it
on all the time.
The Aviation Consumer article is worth reading if you have
a subscription. If not, and you want it, let me know and
I can fax it or something.
If you have a sump heater only, you won't do as good a job
heating your engine as a whole, and you may indeed have
oil warmed that brings moisture up to condense up higher
where it's cold. So it would be much more of a problem
with the cheap partial heaters. I guess what I get out
of it is, if you really need heat, either buy a whole
system (I have the reiff with cylinder bands, which was
simple to install) and feel free to operate it is you wish,
or get a system that you only use when you plan to fly.
One of my issues is, I never know when I want to fly, at this
time of year. The days sneak up on you. If I continuous
heat, it'll be ready anytime. If not, it won't necessarily
heat fast enough (unless maybe you buy the fast system),
to be worth turning on. Add to that the complexity of
getting a remotely operated switch to turn on the heater.
In my case, I leave it on all the time and it's something
like 250 watts....so a big light bulb. The bill isn't
bad for that to run all winter. In fact, a remote switch
would cost me well over $100-150 (plus internet access with
a static IP) for a good one, and I don't spend that much
to heat the plane for a few years. Also, it takes me
15-30 minutes to get to the hangar if I wanted to go there
and turn it on, and then go wait while it heats...a waste
of time. So leaving it on works perfectly for me.
One last point is, if you put it on a timer, or cycle
it on when you think you may fly, just in case, but then
don't fly, you're probably more likely to cause moisture
buildup from the heat cycling, than if you just brought
it up to temp and left it warm. So if you heat it,
fly it, I guess is the idea, if you're not continuous.
Get the oil temp to 180F so you evaporate the moisture
before you put it away.
Anyway, all good things to think about in relation to
heaters. I've had great luck continuous heating with
both a Tanis and Reiff system. The only negative about
the Tanis for me today would be it uses the CHT bayonet
port, which I use for my probes. If you use the Tanis,
you'll probably need ring type CHT probes which aren't
quite as accurate.
Happy winter flying! Was out a few days ago...and with
my daughter we were climbing over 2200fpm with the 2 of
us. Winter performance is great!
On 1/8/2011 9:12 PM, Les Kearney wrote:
Marcus
Cheers
Les
134.08 KB |
7620 Time(s) |
rv10builder(at)verizon.ne Guest
Posted: Wed Jan 19, 2011 7:20 am Post subject: Engine heater |
One item you didn't cover was the concern of power being applied while
unsupervised could very well cause a short and burn your hangar down. I know
it's rather rare but
http://www.vansairforce.com/community/showthread.php?t=67311
This was here locally, my understanding is that there was a short and a fire
began. It was not a preheater in this case.
Pascal
Posted: Wed Jan 19, 2011 7:39 am Post subject: Engine heater |
My point was just a reminder about power in general (trickle charger, air
compressor, etc) not specific to a preheater that is applying heat.
More of a reminder about be careful to power off items that are not needed
when away.
Posted: Wed Jan 19, 2011 12:14 pm Post subject: Engine heater |
The 'cause' as stated in the thread was sub-standard wiring. Electrical
fires are usually due to overloaded outlets, frayed wires, and .......
replacing that 15 or 20 amp breaker with 50 amp ones. The breaker swap
is the most squawked item when the electrical system is checked 15 or 20
years after the hangars were approved. Any 'shorts' should trip the
breaker ..... if it's the correct one.
Linn
I know it's rather rare but
a fire began. It was not a preheater in this case.
Pascal
rv10flyer
Posted: Wed Jan 19, 2011 5:07 pm Post subject: Re: Engine heater |
I'll be preheating before I fly with electric furnace/blower and ductwork to cowl inlets. Oil cooler must be preheated too. I plan on flying often enough to keep the engine well lubricated. I don't want the extra expense and weight to carry around for the other 8 months of the year.
_________________ Wayne G. |
