Is over-voltage protection recommended for small alternator?
PostPosted: Wed Jan 05, 2011 8:02 pm    Post subject: Is over-voltage protection recommended for small alternator? Reply with quote
Some builders think that they do not need over-voltage protection because their EFIS will warn of high voltage and they can shut off the master or add additional load to reduce the voltage, especially if the alternator is a small PM alternator. In effect, they plan to regulate the voltage manually.
I believe it is better to have automatic over-voltage protection because it will take the pilot too long to react. By then expensive avionics could be damaged. A small PM alternator can put out too high of a voltage if lightly loaded and the regulator fails. I recommend some type of over-voltage protection. What do others think?
Joe
Joe Gores
