tim2542(at)sbcglobal.net Guest
Posted: Mon Jan 03, 2011 10:23 pm Post subject: CPC's |
I saw a interesting video tonight from EAA on using circular plastic
connectors.
http://www.eaavideo.org/video.aspx?v=713328494001
Can anyone tell me the part numbers for the connectors he's using? I'd
like to use these for the stick grips and a few other places. I would
like to use the same crimp pins he's using instead of the molex type,
which is about all I could find on a search tonight.
Thanks, Tim Andres
dsvs(at)ca.rr.com Guest
Posted: Mon Jan 03, 2011 11:09 pm Post subject: CPC's |
That is a Danials crimper and the pins and sockets are machined . Steinair
has both.
glastar(at)gmx.net Guest
Posted: Mon Jan 03, 2011 11:31 pm Post subject: CPC's |
This are from Tycoelectronics:
<http://www.tycoelectronics.com/catalog/minf/en/645>
and here 493 products:
<http://www.tycoelectronics.com/catalog/feat/en/c/10574?BML=10576,17560,23645,17584,17760>
bulkier then the db9 I use but if you need more then 9 pins they might
be your choice.
Werner
| Quote: | Can anyone tell me the part numbers for the connectors he's using? I'd
Posted: Mon Jan 03, 2011 11:43 pm Post subject: CPC's |
Pins and sockets are on allied electronics catalog page 202 use DM20 p and
s. Series 2 connectors are on page 199
BobsV35B(at)aol.com Guest
Posted: Tue Jan 04, 2011 7:09 am Post subject: CPC's |
Good Morning Werner,
My understanding is that the D-subminiature DB is a twenty-five pin connector whereas a DE-9 is a nine pin connector. Where have I gone wrong?<G>
Happy Skies,
Old Bob
In a message dated 1/4/2011 1:31:49 A.M. Central Standard Time, glastar(at)gmx.net writes:
| Quote: | --> AeroElectric-List message posted by: Werner Schneider <glastar(at)gmx.net>
be your choice.
Werner
like to use these for the stick grips and a few other places. I ========================= Use utilities Day ================================================ - MATRONICS WEB FORUMS ================================================ - List Contribution Web Site sp; ===================================================
Posted: Tue Jan 04, 2011 7:38 am Post subject: CPC's |
Hello "old" Bob,
you are certainly right Sir and I'm wrong
D shell and 2nd letter is size so it would be DE:
<http://en.wikipedia.org/wiki/D-subminiature> (I've learned something new
But I'm excused coming from the computer side (read 5th Paragraph)
....to see DE9 connectors sold as "DB9" connectors. DB-9 is nearly
always intended to be a 9 pin connector with an E size shell.
Werner
On 04.01.2011 16:05, BobsV35B(at)aol.com wrote:
| Quote: | Good Morning Werner,
wrong?<G>
Happy Skies,
Old Bob
be your choice.
Werner
using? I'd
mrspudandcompany(at)veriz Guest
Posted: Tue Jan 04, 2011 7:45 am Post subject: CPC's |
I gone wrong?<G>
Happy Skies,
Old Bob
The D subminiature series is inclusive of
the 9 and 25 pin connectors.
Roger
winmail.dat |
3.89 KB |
336 Time(s) |
Posted: Tue Jan 04, 2011 8:23 am Post subject: CPC's |
On 1/3/2011 11:06 PM, Don wrote:
has both.
Thanks; I have the pins & crimper, that's why I wanted to use the
specific connector he's using. The problem is there are hundreds of
choices from either Tyco or Amp, and all the ones I could find used the
molex type crimped pin vs. the D-sup machined pins I'm familiar with.
I'll keep looking or call Allied for help.
Thanks, Tim Andres
Ok great Don! thats what I could not find.
Tim
Posted: Tue Jan 04, 2011 8:34 am Post subject: CPC's |
Sounds fair to me!
Happy Skies,
Old Bob
In a message dated 1/4/2011 9:39:27 A.M. Central Standard Time, glastar(at)gmx.net writes:
Hello "old" Bob,
.....to see DE9 connectors sold as "DB9" connectors. DB-9 is nearly
Werner
wrong?<G>
Happy Skies,
Old Bob
be your choice.
Werner
using? I'd
Posted: Tue Jan 04, 2011 8:35 am Post subject: CPC's |
Good Morning Roger,
That is true and the DA is 15, DB is 25, DC is 37, DD is 50 and DE is 9. Did I say or imply otherwise?
Happy Skies,
Old Bob
In a message dated 1/4/2011 9:46:08 A.M. Central Standard Time, mrspudandcompany(at)verizon.net writes:
| Quote: | The D subminiature series is inclusive of
Roger
Posted: Tue Jan 04, 2011 8:48 am Post subject: CPC's |
Happy Skies, |
The second letter after the D in some folks catalogs
refer to a shell size. The original D series was A thru
D for 15 thru 50 pins. I think the 9 pin was added later
and they gave it an out-of-sequence letter "E"
See
http://aeroelectric.com/Mfgr_Data/Connectors/ITT_Cannon/dsub_accessories.pdf
Bob . . . [quote][b]
Posted: Tue Jan 04, 2011 9:42 am Post subject: CPC's |
I have the pins & crimper, that's why I wanted to use the specific
connector he's using. The problem is there are hundreds of choices
from either Tyco or Amp, and all the ones I could find used the molex
Goto http://digikey.com
Do search on amp cpc -> circular housings (330 items) -> then Contact size 20
There you will find a listing of a limited number of
sizes for the CPC connectors that accept the 20 AWG
machined pins (a la D-sub). This series is described
in AMP document
http://search.digikey.com/scripts/DkSearch/dksus.dll?Cat=1441934&k=cpc%20series%202
in top paragraphs of column 2 on both pages.
As you can see. This particular connector is not
available in many sizes. It's also more expensive
than D-subs and is bulkier than a trimmed down
dsub described on the website.
http://aeroelectric.com/articles/macservo/macservo.html
If you need more than 9 wires, use two connectors
and flip the sex for the connectors so that they
cannot be mis-mated.
