richard.goode(at)russiana Guest
Posted: Mon Dec 27, 2010 9:02 pm Post subject: 52 spinning |
This is an issue that greatly concerns me,as it should anyone who spins the 52.
The 52 will always recover,but particularly from a flat spin,recovery is not always conventional;can be very prolonged;stick forces VERY high.
Martin Stahlik,then number 7 in the World,and a superb aerobatic pilot,but with no 52 experience,spun down to the ground in a 52.
This is why proper instruction by an experienced 52 instructor is critical.
Richard
Richard Goode Aerobatics
Rhodds Farm
Lyonshall
Hereford
HR5 3LW
United Kingdom
Tel: +44 (0) 1544 340120
Fax: +44 (0) 1544 340129
www.russianaeros.com
I’m currently in Sri Lanka but this Mail is working,and my local phone is +94 779 132 160.
mikspin
Posted: Mon Dec 27, 2010 10:35 pm Post subject: Re: 52 spinning |
Richard,
I have read the various Yak 52 spin literature in the past and have always wondered if the high stick forces quoted were in a Yak 52 with the original centering springs (or "bungees" as a lot of people call them) installed. I have flown Yaks with and without these installed and of course noticed quite a difference in control feel and forces during maneuvering at the extremes of the envelope.
TIA
Mike Hastings
Posted: Tue Dec 28, 2010 2:56 am Post subject: 52 spinning |
No,the springs have far less effect than the airflow over the control
surfaces that you need to overcome in the flat spin recovery.
Stick forces can be well over 100 pounds,and rudder forces well over 200
pounds!!
Richard
Rhodds Farm
Lyonshall
Hereford
HR5 3LW
United Kingdom
I'm currently in Sri Lanka but this Mail is working,and my local phone is
+94 779 132 160.
mikspin
Posted: Tue Dec 28, 2010 7:06 am Post subject: Re: 52 spinning |
Yes, I've read the article many times that states that as such, and I'm aware of the difference between the aerodynamics forces acting on the controls and the force of the springs.
Regardless, I am asking if the article you were involved with referred to an aircraft with the springs installed.
Thank you
Mike
Posted: Tue Dec 28, 2010 8:28 am Post subject: 52 spinning |
No-since I assume that all civilian owners will remove them-but my concern
is that all pilots who spin 52s should have been instructed on the issues
involved.
Richard
Rhodds Farm
Lyonshall
Hereford
HR5 3LW
United Kingdom
+94 779 132 160.
bwade154(at)yahoo.com Guest
Posted: Tue Dec 28, 2010 11:16 am Post subject: 52 spinning |
Richard its been mentioned that you flew two Yak 52 that didn't recover with conventional (Yak 52) control inputs, how did you regain control or did you bail?
Bill Wade
From: Richard.Goode <richard.goode(at)russianaeros.com>
To: yak-list(at)matronics.com
Sent: Tue, December 28, 2010 11:12:02 AM
Subject: Re: Yak-List: Re: 52 spinning
--> Yak-List message posted by: "Richard.Goode" <richard.goode(at)russianaeros.com (richard.goode(at)russianaeros.com)>
involved.
Richard
Rhodds Farm
Lyonshall
Hereford
HR5 3LW
United Kingdom
+94 779 132 160.
nigel(at)yakdisplay.com Guest
Posted: Tue Dec 28, 2010 12:06 pm Post subject: 52 spinning |
Bill,
The conventional recovery technique involves ailerons central. The aspect of the 52 that can catch you out is that recovery from a flat spin MAY need FULL IN SPIN aileron. The two yaks Richard mentions will be two that did not recover UNLESS the in spin aileron was used. Recovery is prolonged even with the aileron.. Typically 5 turns or so AFTER full anti spin controls have been applied.... often meaning people relax this approach and try something else - which simply isn't going to work. And when it does recover, it snapshot requiring fairly fast centralising of all controls. Hence the recommendation from any 52 aeros pilot to go and do some with an instructor for the experience.
Nigel
On 28 Dec 2010, at 19:13, bill wade <bwade154(at)yahoo.com (bwade154(at)yahoo.com)> wrote:
[quote]Richard its been mentioned that you flew two Yak 52 that didn't recover with conventional (Yak 52) control inputs, how did you regain control or did you bail?
Bill Wade
From: Richard.Goode <richard.goode(at)russianaeros.com (richard.goode(at)russianaeros.com)>
To: [url=mailto:yak-list(at)matronics.com]yak-list(at)matronics.com (yak-list(at)matronics.com)[/url]
Subject: Re: Re: 52 spinning
--> Yak-List message posted by: "Richard.Goode" <[url=mailto:richard.goode(at)russianaeros.com]richard.goode(at)russianaeros.com (richard.goode(at)russianaeros.com)[/url]>
involved.
Richard
Rhodds Farm
Lyonshall
Hereford
HR5 3LW
United Kingdom
+94 779 132 160.
Posted: Tue Dec 28, 2010 5:50 pm Post subject: 52 spinning |
To make the position clear,I was not flying either 52.
But after the Martin Stahlik accident in a 52 that we had sold,I was shocked that such an experienced and skilled pilot could be unable to recover from a spin,particularly since he had a lot of altitude,and had begun the spin at over 6,000 feet.In consequence I did a lot of research on the whole topic,mainly with Yakovlev and pilots from Russia's DOSAAF who had,collectively,thousands of hours of 52 spinning.From this it became clear that conventional recovery MAY not work in the 52,although it WILL recover if the pilot understands the possible slowness of recovery;the very high control forces and the POSSIBLE need for inspin aeleron.Of course this is only normally the case with a developed flat spin,but no one should spin a 52 on the assumption that the spin will not develop or go flat!!
Rhodds Farm
Lyonshall
Hereford
HR5 3LW
United Kingdom
andrewrichards7(at)gmail. Guest
Posted: Wed Dec 29, 2010 1:41 am Post subject: 52 spinning |
Hi Richard
I just bought a 55M out of the US, it will be on a boat this week. Are
there these types of spin issues with the 55M?
I have no time on 55's, only Pitts and Extra's.
Andrew
On 12/29/10, Richard.Goode <richard.goode(at)russianaeros.com> wrote:
| Quote: | To make the position clear,I was not flying either 52.
Rhodds Farm
Lyonshall
Hereford
HR5 3LW
United Kingdom
+94 779 132 160.
Posted: Wed Dec 29, 2010 2:04 am Post subject: 52 spinning |
To the best of my knowledge,none of these 52 cautions are issues with the
55,which has excellent spin recovery characteristics.
Rhodds Farm
Lyonshall
Hereford
HR5 3LW
United Kingdom
+94 779 132 160.
Posted: Wed Dec 29, 2010 3:54 am Post subject: 52 spinning |
Thanks Richard.
Andrew
Rhodds Farm
Lyonshall
Hereford
HR5 3LW
United Kingdom
+94 779 132 160.
bu131(at)swbell.net Guest
Posted: Wed Dec 29, 2010 7:57 am Post subject: 52 spinning |
inverted spin training in yak55m includes the jesus maneuver as per nik timofeyev if all fails center the stick keep some power on , opposite rudder and pray same characteristics as 52
From: andrew richards <andrewrichards7(at)gmail.com>
Sent: Wed, December 29, 2010 3:37:58 AM
Subject: Re: 52 spinning
--> Yak-List message posted by: andrew richards <andrewrichards7(at)gmail.com (andrewrichards7(at)gmail.com)>
Hi Richard
Andrew
On 12/29/10, Richard.Goode <richard.goode(at)russianaeros.com (richard.goode(at)russianaeros.com)> wrote:
Rhodds Farm
Lyonshall
Hereford
HR5 3LW
United Kingdom
+94 779 132 16= (And Get Some AWESOME FREE Gifts!)www.homebuilthelp.com[/url]
_bsp; ========================
Posted: Wed Dec 29, 2010 8:21 pm Post subject: 52 spinning |
Thanks for clarifying that Richard, has anyone bailed from a Yak that didn't recover or do most just ride it in. Next question Richard does the 52TD have the same flat spin characteristics as the 52?
Bill Wade
To: YAK USA LIST <yak-list(at)matronics.com>
Sent: Tue, December 28, 2010 8:55:04 PM
Subject: 52 spinning
Rhodds Farm
Lyonshall
Hereford
HR5 3LW
United Kingdom
Tel: +44 (0) 1544 340120 begin_of_the_skype_highlighting +44 (0) 1544 340120 end_of_the_skype_highlighting
I’m currently in Sri Lanka but this Mail is working,and my local phone is +94 779 132 160 begin_of_the_skype_highlighting +94 779 132 160 end_of_the_skype_highlighting.
[quote]www.homebuilthelp.com</============ [b]
Posted: Wed Dec 29, 2010 9:13 pm Post subject: 52 spinning |
Do you have a smoke oil tank mounted aft of the rear seat? If so don't fly acro with it full and > 60 kg back seated and making the mistake of getting slow at high alpha with the addition of cross control. You may find yourself testing the in spin aileron recovery thing.
Doc
Posted: Wed Dec 29, 2010 9:37 pm Post subject: 52 spinning |
I know of 4 cases where they have spun in.Usually two-up since the rearward C og G greatly agravates the problem.And two where they have jumped.
But,to present a balanced picture,1800 or so 52s made and all of the ones in the East were doing aeros. and spinning continuously,so thousands of spins in total.
I would suggest that the TD is a bit better,without the nose wheel,which adds to the inertia;most of them have much of the heavy electronic kit removed from behind the rear seat,and most will have a bit of fuel remaining in front of the spar [the long-range tanks] which will take C of G a bit forward.But otherwise very similar!
BUT,any significant amount of fuel left in the tanks will exacerbate the problem,since,as you spin the fuel will go out board and increase the rotational inertia.
Rhodds Farm
Lyonshall
Hereford
HR5 3LW
United Kingdom
Posted: Wed Dec 29, 2010 9:43 pm Post subject: 52 spinning |
It is also worth adding that the MAXIMUM that the Russians will allow in the rear cockpit of a 52 is 100 kilos [220 pounds] and that includes parachute;clothing;any cushions etc.I suspect that in the land of the Big Mac,there are a number of pilots/passengers in the rear cockpit who are well over this!!!
Rhodds Farm
Lyonshall
Hereford
HR5 3LW
United Kingdom
Posted: Thu Dec 30, 2010 4:04 am Post subject: 52 spinning |
As a footnote though Richard, the 100 kilos or 220 pounds in the rear cockpit was with the Russian ADF and flight recorder still in the airplane.
Dennis
Posted: Thu Dec 30, 2010 5:52 am Post subject: 52 spinning |
Absolutely correct.
Rhodds Farm
Lyonshall
Hereford
HR5 3LW
United Kingdom
From: owner-yak-list-server(at)matronics.com [mailto:owner-yak-list-server(at)matronics.com] On Behalf Of A. Dennis Savarese
Sent: 30 December 2010 12:01
Dennis
----- Original Message -----
From: Richard.Goode (richard.goode(at)russianaeros.com)
To: YAK USA LIST (yak-list(at)matronics.com)
Sent: Wednesday, December 29, 2010 11:49 PM
Rhodds Farm
Lyonshall
Hereford
HR5 3LW
United Kingdom
| Quote: | | href="http://www.aeroelectric.com">www.aeroelectric.comhref="http://www.buildersbooks.com">www.buildersbooks.comhref="http://www.homebuilthelp.com">www.homebuilthelp.comhref="http://www.matronics.com/contribution">http://www.matronics.com/chref="http://www.matronics.com/Navigator?Yak-List">http://www.matronics.com/Navigator?Yak-Listhref="http://forums.matronics.com">http://forums.matronics.com | | 0123456789 | Quote: | | href="http://www.aeroelectric.com">www.aeroelectric.com | 0 | Quote: | | href="http://www.aeroelectric.com">www.aeroelectric.com | 1 | Quote: | | href="http://www.aeroelectric.com">www.aeroelectric.com | 2 | Quote: | | href="http://www.aeroelectric.com">www.aeroelectric.com | 3 | Quote: | | href="http://www.aeroelectric.com">www.aeroelectric.com | 4 | Quote: | | href="http://www.aeroelectric.com">www.aeroelectric.com | 5 | Quote: | | href="http://www.aeroelectric.com">www.aeroelectric.com | 6 | Quote: | | href="http://www.aeroelectric.com">www.aeroelectric.com | 7 | Quote: | | href="http://www.aeroelectric.com">www.aeroelectric.com | 8 | Quote: | | href="http://www.aeroelectric.com">www.aeroelectric.com | 9 | Quote: | | href="http://www.buildersbooks.com">www.buildersbooks.com | 0 | Quote: | | href="http://www.buildersbooks.com">www.buildersbooks.com | 1 | Quote: | | href="http://www.buildersbooks.com">www.buildersbooks.com | 2 | Quote: | | href="http://www.buildersbooks.com">www.buildersbooks.com | 3 | Quote: | | href="http://www.buildersbooks.com">www.buildersbooks.com | 4
believed to be clean.
mikspin
Posted: Thu Dec 30, 2010 7:45 am Post subject: Re: 52 spinning |
Thanks Richard. I echo your sentiments about getting the proper training from the right people. The question was an academic one.
Continuing that, (Dennis chime in if you know), Would anyone happen to know the CG of the aircraft tested?
Posted: Thu Dec 30, 2010 8:53 am Post subject: 52 spinning |
If you're referring to the "Spins Unspun" article, the test aircraft, according to the article, had a CG of 18% MAC, which is clearly a forward CG. As I remember, without digging into additional documentation, the design CG range for the Yak 52 is 19-25% MAC.
Dennis
