trainnut01(at)aol.com Guest
Posted: Mon Jan 24, 2011 10:37 am Post subject: Saddle |
Has anyone had problems with the fiberglass saddle from Zenith? (6B21-5) Mine lacks over an inch being wide enough to fit at the front. The back is fine. I've spent several hours during this last week-end re-checking every thing else at the rear of the fuselage and can't find anything else wrong. Mine is 7 1/2 inches wide but when placed in position it looks like it needs to be closer to 8 3/4. If someone can tell me whats wrong I sure would be appreciative.
Carroll Jernigan
psm(at)att.net Guest
Posted: Mon Jan 24, 2011 10:58 am Post subject: Saddle |
Hi Carroll,
Fiberglass parts are notorious for this kind of problem. They don't hold their size and shape under varying conditions. They are ok when held in place with rivets.
You can bend fiberglass parts like taffy if you heat them up the right amount. I use a hot air gun for this purpose. You need to keep the heater moving around so you don't burn the fiberglass. It is not as difficult as it sounds. Just heat it up (wearing gloves) and apply force. When it is ready it will bend to the new shape. Then all you need to do is hold it in that shape while it cools.
Good luck,
Paul
XL upgrading fuselage
On 1/24/2011 10:29 AM, Carroll Jernigan wrote: [quote] Has anyone had problems with the fiberglass saddle from Zenith? (6B21-5) Mine lacks over an inch being wide enough to fit at the front. The back is fine. I've spent several hours during this last week-end re-checking every thing else at the rear of the fuselage and can't find anything else wrong. Mine is 7 1/2 inches wide but when placed in position it looks like it needs to be closer to 8 3/4. If someone can tell me whats wrong I sure would be appreciative.
Carroll Jernigan
carlossa52(at)gmail.com Guest
Posted: Mon Jan 24, 2011 12:08 pm Post subject: Saddle |
You could probably make a replacement with aluminum...
Carlos
On 24 January 2011 13:29, Carroll Jernigan <trainnut01(at)aol.com (trainnut01(at)aol.com)> wrote:
Carroll Jernigan
heatonhe36(at)msn.com Guest
Posted: Mon Jan 24, 2011 12:11 pm Post subject: Saddle |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Carroll,
I have the same problem with the saddle I got from Zenith. It has a 3/4" gap on both sides at the front. When I asked Zenith about the problem They said that was the way they came from the supplier and I should be able to fix it. I shouldn't have to fix it. It should be supplied from the manufacturer, cut to the proper size, or at least oversize so we can trim it to fit.
Since I am building from plans anyway, I will just make a mold from the saddle I've got and make a new part the proper size. Sometimes you've just got to do what you've got to do.
Herb Heaton
601XL, Turbo Subaru
Mods almost done
paulrod36(at)msn.com Guest
Posted: Mon Jan 24, 2011 12:56 pm Post subject: Saddle |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> I had problems with mine too; finally I said the hell with it, and made one of fiberglass. Used the rear portion of the saddle ( the part that fit), added an aluminum fairing over the front part, and laid it on the plane. Then, after application of wax as a release agent, I laid wet fiberglass strips on, and added fairings around the front of the stabilizer, thereby covering the gaps. Sort of like the RV uses. After enough to hold it together, I removed it, laid on enough for strength, and sanded the whole thing down to what I wanted. It didn't take long to do.
Paul R
