jchang10
Posted: Mon Dec 27, 2010 12:13 pm Post subject: Upper Cowl Pin Retainer Awkward Fit |
I just want to verify that I didn't make a mistake, since it's unusual that Van's would make a mistake like this.
On page 47-7, (picture attached) the upper cowl pin retainer I have doesn't fit between the hinges. Thus, I need to trim a slight bit from each hinge, for the retainer to fit in between. Also, my pins will not fit in the pin cutout area, so i will be trimming that as well.
Thus, just curious if anyone else encountered the same issue? I double checked all measurements. Just seems odd for such an intricately designed part to actually not fit.
Jae
40533
16.07 KB |
8541 Time(s) |
16.07 KB |
8541 Time(s) |
Bob Turner
Posted: Mon Dec 27, 2010 6:24 pm Post subject: Re: Upper Cowl Pin Retainer Awkward Fit |
Mine didn't fit either.
I think it's the fiberglass cowl that varies. My lower cowl was a real mess, way off specs.
_________________ Bob Turner
RV-10 QB |
rv10builder(at)verizon.ne Guest
Posted: Mon Dec 27, 2010 6:46 pm Post subject: Upper Cowl Pin Retainer Awkward Fit |
my upper cowl was way off, so much so Vans thought I had a defective one
(which it was) but was told by the vendor to use a heat gun and reshape it
into position. Took months to finally get it to fit.
Sent: Monday, December 27, 2010 6:24 PM
Subject: Re: Upper Cowl Pin Retainer Awkward Fit
rleffler
Posted: Mon Dec 27, 2010 7:23 pm Post subject: Upper Cowl Pin Retainer Awkward Fit |
Just what I needed to hear as I just finished the doors and am getting ready
to start on the cowls........ More fiberglass fun!
_________________ Bob Leffler
N410BL - Phase I
http://mykitlog.com/rleffler |
jchang10
Posted: Mon Dec 27, 2010 7:38 pm Post subject: Re: Upper Cowl Pin Retainer Awkward Fit |
In this case, i don't think the cowl is the variable.
The plans have you drill a reference starter hole on the F-1001N left and right hinges, which match up to holes in the forward top skin right in the center.
If i measure everything out, the retainer doesn't fit between the angles which represent the hinges in this photo here: http://lh6.ggpht.com/_E3nI7J8M6Iw/TRlZt1ixKSI/AAAAAAAACLk/UFfV-fc9DhU/s640/IMG_0059.JPG The lines do line up with the holes, just a parallax issue.
It just seems odd, since the retainer could have been made narrower to fit, or the measurement on the reference hole could have been made to fit as well.
Just wanted to double check before i started cutting my cowl hinges, which i worked so hard to get to this point!
Jae
40533
| Bob Turner wrote: | Mine didn't fit either.
I think it's the fiberglass cowl that varies. My lower cowl was a real mess, way off specs. |
jchang10
Posted: Mon Dec 27, 2010 7:48 pm Post subject: Re: Upper Cowl Pin Retainer Awkward Fit |
Bob, just a warning, i thought the cowl was much harder than the doors, personally.
The doors are easier to see exactly where it should fit in relation to being flush in the door frame. you can just step back a couple paces.
The cowl, on the other hand, must be positioned in 3D free space relative to the spinner and firewall, and clear the engine and prop governor. also, if you want to get pickier, the split line between upper and lower halves should be relatively level. All the while, you are walking from the left side to the right side, to the top of the cowl and crawling around on your back on the bottom while avoiding the gear leg and prop. I ended up using levels and even a laser level line to get some fixed reference points to work by.
Jae
| rleffler wrote: | Just what I needed to hear as I just finished the doors and am getting ready
Posted: Mon Dec 27, 2010 8:15 pm Post subject: Upper Cowl Pin Retainer Awkward Fit |
don't worry, Vans told me they never saw this before should be no issue
for you..
As a highly referencable builder states in his site for the cowl "The cowl
has been taking a bit of time. It's actually a very simple operation".
You'll do fine!
Pascal
Sent: Monday, December 27, 2010 7:17 PM
Subject: RE: Re: Upper Cowl Pin Retainer Awkward Fit
ready
Posted: Mon Dec 27, 2010 10:45 pm Post subject: Upper Cowl Pin Retainer Awkward Fit |
Also Know that the engine is also pointing toward the right so the left side of the cowl is longer than the right side.
I made some modification to my top cowl pin retainer mechanism so that it slides down very far out of the way on those lone rivets and when I rotating the screws the mechanism raises up and locks the pins in the cut out.
| Quote: | Subject: RV10-List: Re: Upper Cowl Pin Retainer Awkward Fit
Date: Mon, 27 Dec 2010 19:48:47 -0800
--> RV10-List message posted by: "jchang10" <jc-matronics_rv10(at)jline.com>
Jae
http://forums.matronics.com/viewtopic.php?p=324752#324752
102.64 KB |
8510 Time(s) |
106.96 KB |
8510 Time(s) |
108.59 KB |
8510 Time(s) |
95.26 KB |
8510 Time(s) |
AirMike
Posted: Wed Dec 29, 2010 4:47 am Post subject: Upper Cowl Pin Retainer Awkward Fit |
Might want to consider 1/4 turn cam lock fasteners. Makes it a lot faster to remove the upper cowl
_________________ See you OSH '18
Q/B - sold. |
