rv10free2fly(at)yahoo.com Guest
Posted: Mon Dec 20, 2010 8:55 pm Post subject: Trimming Fibreglass Cabin Top |
Your thoughts regrading the best tool/method for trimming the fibreglass cabin top would be appreciated please?
Merry Christmas and a safe and prosperous New Year to you all.
Kind regards
Patrick Pulis
Adelaide, South Australia
Kellym
Posted: Mon Dec 20, 2010 9:03 pm Post subject: Trimming Fibreglass Cabin Top |
I did most of my rough cuts with Harbor Freight MultiFunction tool, with
the soft metal cutting half moon blade, went through about 4 of them.
Did some touch up with cutoff wheel, but it throws a lot of dust and
debris. Finished with sander and 60 grit paper. Bob Leffler shows the
tool on his builders log. Main issue was to not use too much pressure
and not stay in one place or blade and fiberglass would get too hot,
smoking and dulling the blade. Multiple passes with lighter pressure
worked best.
On 12/20/2010 9:51 PM, Patrick Pulis wrote:
Kind regards
Patrick Pulis
KCHD |
Posted: Mon Dec 20, 2010 9:42 pm Post subject: Trimming Fibreglass Cabin Top |
I used different tools depending on the thickness. I put pieces of hack saw blade in an air saw, but they dull quickly so the pieces got changed out often. Used it on the windows. A Sawzall with coarse teeth also worked well but was hard to control. The best tool was a 4" angle grinder (mine came from Harbor Freight .... they're disposable) with the concrete grinder wheel. It creates a lot of dust so you need to wear a mask and use a fan to blow it away from you. I have a big door on my shop and just blew the dust outside. When using the grinder, keep it moving, taking 'swipes' at where you want to remove the FG. This was useful around the door openings and smoothing out some of the 'bumps'. Good luck!
Linn
On 12/20/2010 11:51 PM, Patrick Pulis wrote: [quote]
Kind regards
Patrick Pulis
rv10builder(at)verizon.ne Guest
Posted: Mon Dec 20, 2010 9:46 pm Post subject: Trimming Fibreglass Cabin Top |
Harbor freight air grinder and the Vans provided cutoff wheels. If you have a decent air compressor you'll get through it pretty quick, otherwise you are given numerous breaks while the air compressor tries to keep up with the air supply the grinder requires.
Once that is done 40, than 60, than 80 grit sandpaper trimming it to fit nicely.
Pascal
Sent: Monday, December 20, 2010 8:51 PM
Subject: Trimming Fibreglass Cabin Top
Kind regards
Patrick Pulis
title="http://www.aeroelectric.com/
CTRL + Click to follow link" href="http://www.aeroelectric.com">www.aeroelectric.com
title="http://www.buildersbooks.com/
CTRL + Click to follow link" href="http://www.buildersbooks.com">www.buildersbooks.com
title="http://www.homebuilthelp.com/
CTRL + Click to follow link" href="http://www.homebuilthelp.com">www.homebuilthelp.com
href="http://www.matronics.com/contribution">http://www.matronics.com/chref="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List
kearney
Posted: Mon Dec 20, 2010 10:14 pm Post subject: Trimming Fibreglass Cabin Top |
Patrick
I used a Dremel multi tool with the semi circular blades. I did go through a few blades as the teeth wore down quickly. I also used a Dremel tool with small cut off wheels. I went through a bunch but it worked surprisingly well.
What I was surprised at was how munch of the doors were removed to get the cabin to fit in the door openings.
Cheers
Les
On 2010-12-20, at 9:51 PM, Patrick Pulis <rv10free2fly(at)yahoo.com.au (rv10free2fly(at)yahoo.com.au)> wrote:
Kind regards
Patrick Pulis
Lew Gallagher
Joined: 04 Jan 2008 Posts: 402 Location: Greenville , SC
Posted: Tue Dec 21, 2010 4:48 am Post subject: Trimming Fibreglass Cabin Top |
Hey Patrick,
All of what the others have said about trimming fiberglass. Plus, I found that sheet metal shears work great for the thin fiberglass parts. I.e. door shells, trimming around windows, etc. No dust, no fuss, then just finese sanding.
Later, - Lew
_________________ non-pilot
crazy about building
NOW OFICIALLY BUILDER #40549
Fly off completed ! |
biovail2001(at)yahoo.com Guest
Posted: Tue Dec 21, 2010 5:49 am Post subject: Trimming Fibreglass Cabin Top |
I would make one suggestion to the air grinder method and that is to do all of your cutting for fiberglass and plexiglass with an inexpensive electric die grinder. This way you will not have to worry about the air grinder bogging down due to the compressor running low on air and then having to cycle through again. I picked up a Harbor Freight model for about $20 and it worked like a charm.
Steve Koziol
RV 9A N424JK
108 hrs
--- On Tue, 12/21/10, Pascal <rv10builder(at)verizon.net> wrote:
Subject: Re: Trimming Fibreglass Cabin Top
Date: Tuesday, December 21, 2010, 12:43 AM
Pascal
Kind regards
Patrick Pulis
ollow target=_blank>www.aeroelectric.com
/" rel=nofollow target=_blank>www.buildersbooks.com
ofollow target=_blank>www.homebuilthelp.com
=nofollow target=_blank>http://www.matronics.com/Navigator?RV10-List
Posted: Tue Dec 21, 2010 6:20 am Post subject: Trimming Fibreglass Cabin Top |
Most all the replies suggested tools from Harbor freight. Poor Patrick Pulis lives in Adelaide, South Australia ....... maybe he'll let us know if they have HF down under!!!! It reminded me just how much we rely on and use all the cheap, imported Chinese stuff .......
Linn
[quote] I would make one suggestion to the air grinder method and that is to do all of your cutting for fiberglass and plexiglass with an inexpensive electric die grinder. This way you will not have to worry about the air grinder bogging down due to the compressor running low on air and then having to cycle through again. I picked up a Harbor Freight model for about $20 and it worked like a charm.
| Quote: | Harbor freight air grinder and the Vans provided cutoff wheels. If you have a decent air compressor you'll get through it pretty quick, otherwise you are given numerous breaks while the air compressor tries to keep up with the air supply the grinder requires. Once that is done 40, than 60, than 80 grit sandpaper trimming it to fit nicely.
| [b]
davidsoutpost(at)comcast. Guest
The downside to buying the Harbor Freight, or any brand other than the Fein Multimaster, is the blade selection that is important cutting fiberglass. Fein offers an expensive bi-metal cupped blade that lasts just about forever cutting fiberglass. They were $79 for one blade last time we bought one about 8 years ago,,,,but well worth the money because its lasted through the build of 2 Cozy MKIV's and has seen a bit of use on the RV-10 and is still going strong. The mounting system is different for each brand so it would not fit the HF model.
David Clifford
RV-10 Builder
65% Done-95% To Go
N849RV (reserved)
Kelly McMullen
Posted: Tue Dec 21, 2010 6:37 am Post subject: Trimming Fibreglass Cabin Top |
Heck, that makes him closer to the source, maybe can cut out the HF middleman. 8>)
Myron introduced me to a Sears craftsman rechargeable equivalent yesterday:
http://tinyurl.com/28sd4vh
On Tue, Dec 21, 2010 at 7:16 AM, Linn Walters <pitts_pilot(at)bellsouth.net (pitts_pilot(at)bellsouth.net)> wrote:
| Quote: | Most all the replies suggested tools from Harbor freight. Poor Patrick Pulis lives in Adelaide, South Australia ....... maybe he'll let us know if they have HF down under!!!! It reminded me just how much we rely on and use all the cheap, imported Chinese stuff .......
Linn
#avg_ls_inline_popup{position: absolute;z-index: 9999;padding: 0px 0px;margin-left: 0px;margin-top: 0px;overflow: hidden;word-wrap: break-word;color: black;font-size: 10px;text-align: left;line-height: 130%;} [quote][b]
A&P/IA, EAA Tech Counselor
KCHD |
Kellym
Posted: Tue Dec 21, 2010 6:43 am Post subject: Trimming Fibreglass Cabin Top |
But, you can buy almost 10 HF blades for that price, and the HF price
for the tool is about 10% of the Fein. Of course we get what we pay for
and less.
On 12/21/2010 7:17 AM, davidsoutpost(at)comcast.net wrote:
[quote] The downside to buying the Harbor Freight, or any brand other than the
model.
David Clifford
RV-10 Builder
65% Done-95% To Go
N849RV (reserved)
KCHD |
Strasnuts
Joined: 10 Feb 2009 Posts: 502 Location: Salt Lake City, UT
Posted: Tue Dec 21, 2010 6:57 am Post subject: Re: Trimming Fibreglass Cabin Top |
Patrick,
I used a diamond saw blade in a jigsaw for the initial cut then sanded down close with a belt sander. Finally finishing with a hand block sander. I tried a bunch of stuff but if I were to do it again I would stick to these three.
_________________ 40936
RV-10 SB N801VR Flying
780 Hours
SuperSTOL 60 hours |
robin(at)PaintTheWeb.com Guest
Posted: Tue Dec 21, 2010 9:07 am Post subject: Trimming Fibreglass Cabin Top |
Oh… Patrick is Australian…
That’s Australian for Fiberglass Trimming Mate!
Robin
From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) [mailto:owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)] On Behalf Of Linn Walters
Sent: Tuesday, December 21, 2010 6:17 AM
Most all the replies suggested tools from Harbor freight. Poor Patrick Pulis lives in Adelaide, South Australia ...... maybe he'll let us know if they have HF down under!!!! It reminded me just how much we rely on and use all the cheap, imported Chinese stuff .......
Linn
Harbor freight air grinder and the Vans provided cutoff wheels. If you have a decent air compressor you'll get through it pretty quick, otherwise you are given numerous breaks while the air compressor tries to keep up with the air supply the grinder requires. Once that is done 40, than 60, than 80 grit sandpaper trimming it to fit nicely. |
| Quote: | | www.aeroelectric.com | * HomebuiltHELP www.homebuilthelp.com[/b][/quote] w.matronics.com/contribution">http://www.matronics.com/contribution[/b] -Matt Dralle, List Admin.[/b][/quote]=====================[/b][/quote] ,[/b][/quote] ?RV10-List">http://www.matronics.com/Navigator?RV10-List[/b] - MATRONICS WEB FORUMS -[/b]
Checked by AVG - www.avg.com
Version: 10.0.117
25.58 KB |
8880 Time(s) |
Posted: Tue Dec 21, 2010 10:24 am Post subject: Trimming Fibreglass Cabin Top |
glastar(at)gmx.net Guest
Posted: Tue Dec 21, 2010 11:14 am Post subject: Trimming Fibreglass Cabin Top |
Bunnings down under does offer some of the tools HF has but not as many
cheap Chinese brand once then you can choose from
<http://www.bunnings.com.au/products_range_tools-and-hardware_134.aspx>
Werner (#41122 tail)
Linn
Posted: Tue Dec 21, 2010 1:58 pm Post subject: Trimming Fibreglass Cabin Top |
Yes, I'd second that thought assuming you meant by "diamond saw blade"
an abrasive type blade. They last a long time on FG and cut well.
On 12/21/2010 9:57 AM, Strasnuts wrote:
Patrick,
Posted: Tue Dec 21, 2010 2:39 pm Post subject: Trimming Fibreglass Cabin Top |
Many thanks to you all for the advice regarding trimming the cabin top. Robin, I loved your idea the most for expediency!
It was definitely a white Christmas here in Australia last night, wow, talk about dust. I now know why people call this and the door sections, fibreglass purgatory!
I wish you all a very safe and Merry Christmas and most prosperous building new year for those of you who are still building. Those that are flying, I wish you safe and smooth skies.
It sounds as though there is a 'Harbour Freight' franchise opportunity waiting here for the taking down under!
Regards and many thanks
Pat in Oz
