antdea2000(at)yahoo.com.a Guest
Posted: Thu Dec 16, 2010 2:39 am Post subject: Yak 18T Parts |
Hi all,
Does anyone have an air connection cover for my 18T. Also are the other Yak's the same?
Thank you,
Ant.
429.61 KB |
2277 Time(s) |
447.53 KB |
2277 Time(s) |
Posted: Thu Dec 16, 2010 5:45 am Post subject: Yak 18T Parts |
Ant,
You can make your life a lot simpler regarding the external air fill port by installing a Schrader valve fitting (http://www.mcmaster.com/#schrader-valves/=a66ydc), part number 8063K31, on the cover. Remove the valve core because it is not needed. It's a 1/8 NPT Schrader valve fitting. Drill and tap the center of the cover plate. Put a small amount of epoxy around the threads when installing the Schrader valve to prevent leaks. Then you can use a simple Schrader valve coupler attached to the hose going to an air tank, http://www.aircraft-tool.com/shop/detail.aspx?PRODUCT_ID=SK2043C, and you'll never have to find a Russian adapter again.
By installing the Schrader valve fitting on the cover, you can still remove the cover and use a Russian fitting.
Hope this helps.
Dennis
On 12/16/2010 4:36 AM, Anthony Hudacek wrote: [quote] Hi all,
Thank you,
Ant.
Posted: Thu Dec 16, 2010 4:07 pm Post subject: Yak 18T parts |
Thanks Dennis,
But it is the actual cover plate that I am after.
Ant.
Posted: Fri Dec 17, 2010 4:54 am Post subject: Yak 18T parts |
Oh! I misunderstood.
Dennis
On 12/16/2010 6:04 PM, Anthony Hudacek wrote: [quote] Thanks Dennis,
Ant.
