richard.goode(at)russiana Guest
Posted: Mon Dec 13, 2010 3:14 am Post subject: YAK55M modifications |
I suspect that your undercarriage has slightly bent which will reduce the clearace a bit.
There should be no problem to fly with a 250 prop.
You can remove the gear and reset it to restore the correct hight.
Richard
Richard Goode Aerobatics
Rhodds Farm
Lyonshall
Hereford
HR5 3LW
United Kingdom
Tel: +44 (0) 1544 340120
Fax: +44 (0) 1544 340129
www.russianaeros.com
Cliff.Coy
Posted: Mon Dec 13, 2010 5:27 am Post subject: YAK55M modifications |
Landing gear disposition notwithstanding, we have converted several Yak-55M to Cleveland Wheels.
Please contact me off list.
Cheers!
Cliff
kregg(at)balancemyprop.co Guest
Posted: Mon Dec 13, 2010 7:25 am Post subject: YAK55M modifications |
You can also check you main gear "toe" alignment. I have seen some 55's with toe out which will result in spreading the gear, making for reduced prop clearance
Sent from my Samsung Epicâ„¢ 4G
Richard Goode <richard.goode(at)russianaeros.com> wrote:
[quote]I suspect that your undercarriage has slightly bent which will reduce the clearace a bit.
Richard
Rhodds Farm
Lyonshall
Hereford
HR5 3LW
United Kingdom
Posted: Mon Dec 13, 2010 8:12 am Post subject: YAK55M modifications |
Cliff, this is an interesting question.
My YAK-50 was converted to Cleveland wheels AND brakes (hydraulic) when
it was down in Texas after it first arrived in the U.S. in the early
90's. I can take pictures of mine, but I was wondering if you have a
standard kit? It would seem that what would work on a 55, might also
work on any other single seat YAK, or possibly the 52, although that
would be a REAL pain if dual brakes was an option.
Point being, a lot of folks have wanted to duplicate my Hyd Brake and
Cleveland wheel setups and I have not really been able to help them
other than to send pictures. You have a KIT?
Mark Bitterlich
Cliff.Coy
Posted: Mon Dec 13, 2010 8:53 am Post subject: YAK55M modifications |
Mark,
George developed a Hydraulic wheels and brake conversion kit and service bulletin to install Cleveland wheels and brakes into the Yak-52 (see attached).
We haven't received a lot of demand for this conversion.
As such, we didn't make a production run of the lower axle forgings. The one-off price was pretty steep.
To make it reasonable, we'd need to do at least five sets.
The rest of the kit is off-the-shelf items.
Give George a shout for more info.
Cheers!
Cliff
On Mon, Dec 13, 2010 at 11:08, Bitterlich, Mark G CIV Det Cherry Point, MALS-14 64E <mark.bitterlich(at)navy.mil (mark.bitterlich(at)navy.mil)> wrote:
[quote]--> Yak-List message posted by: "Bitterlich, Mark G CIV Det Cherry Point, MALS-14 64E" <mark.bitterlich(at)navy.mil (mark.bitterlich(at)navy.mil)>
Mark Bitterlich
355.38 KB |
4007 Time(s) |
service_bulletin_hydraulic.pdf |
442.04 KB |
542 Time(s) |
William Halverson
Posted: Mon Dec 13, 2010 9:43 am Post subject: YAK55M modifications |
As well as my YAK-55
Posted: Mon Dec 13, 2010 11:17 am Post subject: YAK55M modifications |
Cliff,
How steep is pretty steep? I’m interested in doing this on my 50 and my 52.
Doc Kemp
From: owner-yak-list-server(at)matronics.com [mailto:owner-yak-list-server(at)matronics.com] On Behalf Of Cliff Coy
Sent: Monday, December 13, 2010 10:46 AM
To: yak-list(at)matronics.com
Subject: Re: YAK55M modifications
Mark,
Cheers!
Cliff
Mark Bitterlich
dougsappllc(at)gmail.com Guest
Posted: Mon Dec 13, 2010 11:41 am Post subject: YAK55M modifications |
I converted my first CJ to Clevelands, and yes it is spendy especially if you go with new Double puck Cleveland wheels and brakes rather than used. I had over 3K invested in mine not counting my time. If anyone is looking I do know where there is a set of CJ Clevelands with lower legs (were put on in Texas) which the customer took off and went back to pneumatics.
Best,
Doug
On Mon, Dec 13, 2010 at 11:14 AM, Roger Kemp M.D. <viperdoc(at)mindspring.com (viperdoc(at)mindspring.com)> wrote:
Cliff,
Doc Kemp
From: owner-yak-list-server(at)matronics.com (owner-yak-list-server(at)matronics.com) [mailto:owner-yak-list-server(at)matronics.com (owner-yak-list-server(at)matronics.com)] On Behalf Of Cliff Coy
Mark,
Cheers!
Cliff
Mark Bitterlich
Posted: Mon Dec 13, 2010 5:41 pm Post subject: YAK55M modifications |
Will do, and THANK you for your time!
Mark
yak-list-server(at)matronics.com on behalf of Cliff Coy
Sent: Mon 12/13/2010 11:46 AM
Mark,
Cheers!
Cliff
On Mon, Dec 13, 2010 at 11:08, Bitterlich, Mark G CIV Det Cherry Point, MALS-14 64E <mark.bitterlich(at)navy.mil> wrote:
Mark Bitterlich
