18T issues
radiopicture
PostPosted: Sat Dec 11, 2010 9:51 pm    Post subject: 18T issues Reply with quote
Didier:
It took a while, but here are some pics of the engine compartment heater I improvised. I think I'm going to make a similar one to blow on the oil cooler.
-Eric
[img]cid:1FA9365F-4952-4AA2-B29A-104744859777(at)home[/img][img]cid:E349A8E6-F417-44DF-B209-2E2FAB4E46DD(at)home[/img][img]cid:7AD6423E-42FE-4241-A400-0143A0B054CF(at)home[/img][img]cid:48D2FDA4-08A1-4093-994C-824A29E9EAD8(at)home[/img][img]cid:F1065B00-8E94-4E51-ADB5-C63673108EB0(at)home[/img]
On Sep 16, 2010, at 5:19 PM, Didier Blouzard wrote:
[quote]yeahh would be interested in seeing.
Many thanks if you can post a pic
regards
Didier
2010/9/16 Eric Wobschall <eric(at)buffaloskyline.com (eric(at)buffaloskyline.com)>
[quote]--> Yak-List message posted by: Eric Wobschall <eric(at)buffaloskyline.com (eric(at)buffaloskyline.com)>
Hey, I noticed that farm equipment places have heating pads in all shapes and sizes. Shockingly cheap, and apparently sourced the same as the aviation ones.
I use a Harbor Fright (Halloween coming up) fan driven disc heater with some HVAC items cobbled in such a way that it's funneled into the left side of the cowl. I close the gills and usually plug the left side with some foam. I have it mounted on an old tripod so it can be properly positioned. Heats everything except the oil cooler, which doesn't seem to b3 a problem with the Phillips 25-60. I live near Buffalo, NY. I'll try to post a picture sometime.
On Sep 16, 2010, at 1:29 PM, Bitterlich, Mark G CIV Det Cherry Point, MALS-14 64E wrote:
[quote] --> Yak-List message posted by: "Bitterlich, Mark G CIV Det Cherry Point, MALS-14 64E" <mark.bitterlich(at)navy.mil (mark.bitterlich(at)navy.mil)>
Honestly Olivier, I can't even begin to remember! I got those heating
pads 10 years ago (and they still work by the way).
I think I just went to their web site and talked to their sales agent.
I have one that has two pads. In other words, it has one power cord,
that controls TWO heating pads. Both of those are on the bottom of the
oil tank itself.
Then I have another one that is stuck on the lower sump.
I do not have one on the oil cooler, as Dennis recommended, BUT .... I
have a very unique oil cooler in my YAK-50. It has a thermostat bypass,
so that when the weather is cold, the oil cooler is BY-PASSED.
When it comes to these aircraft, I would listen carefully to anything
Dennis recommends.
Mark
 Filesize:  153.56 KB
 Viewed:  1562 Time(s)
 Filesize:  85.86 KB
 Filesize:  111.84 KB
 Filesize:  65.49 KB
 Filesize:  68.18 KB
f4ffm2(at)roadrunner.com
PostPosted: Sat Dec 11, 2010 10:27 pm    Post subject: 18T issues Reply with quote
Now, that is cool....er, hot, actually.
Roger____________________________
On Dec 11, 2010, at 9:48 PM, Eric Wobschall wrote:
[quote]Didier:
-Eric
<heater1.jpg><heater2.jpg><heater3.jpg><heater4.jpg><heater5.jpg>
regards
Didier
oil tank itself.
Dennis recommends.
Mark
